Longmont1302 Samba Member
Joined: October 01, 2015 Posts: 324 Location: Longmont, CO
Posted: Sat Oct 21, 2017 5:20 pm Post subject: Trouble Removing an Inside Door Handle |
I'm trying to remove the inside passenger side door handle from our 1961 standard. The big blue Bentley Workshop Manual says to "Press the escutcheon plate of inside door handle inwards, drive out the pin..."
In the thread below Aaron offers similar advice: "push the door panel and handle bezel against the the door, look in the space between the handle and the bezel, you'll see a pin." https://www.thesamba.com/vw/forum/viewtopic.php?t=137688
I'm not even sure what the "escutcheon" plate is. The handle itself doesn't seem to have a set screw. Between the handle and the door panel is a really hard white thing that seems pretty stationary. My guess is that this white thing is supposed to be pliable enough to push aside, to get to a set screw, but these are rock hard. What am I missing? Here's what my passenger door handle looks like:
And here's what the driver's door looks like, where the handle is gone, but the hard white thing remains:
Any suggestions welcome! |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51125 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Oct 21, 2017 5:37 pm Post subject: Re: Trouble Removing an Inside Door Handle |
The "hard white thing" is the escution plate, push it towards the door compressing the spring under the door panel to expose a small gap between the ring and the handle so the pin in the handle is visible. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20271 Location: Sandpoint, ID
Posted: Sat Oct 21, 2017 5:56 pm Post subject: Re: Trouble Removing an Inside Door Handle |
I posted in the latter part of this thread about having issues accessing the pin. Though I have not remedied the situation, and the bus in question is a little older, one of the photos shows the pin that you need to drive out in order to remove the handle.
https://www.thesamba.com/vw/forum/viewtopic.php?t=366458&highlight=handle _________________ nothing |
Posted: Tue Oct 24, 2017 9:00 pm Post subject: Re: Trouble Removing an Inside Door Handle |
On my driver's side, I eventually broke the escutcheon plate trying to push it and the panel and the spring. Now I at least have a nice clear view of the remaining problem:
Despite the unobstructed view, I can't get the pin (if that's what it is in there) to budge. I'm trying to tap it up from the bottom. I've soaked it in penetrant and have tried a couple of different-sized punches. It doesn't budge.
What's next? Some heat?
Scott |
Posted: Tue Oct 24, 2017 9:10 pm Post subject: Re: Trouble Removing an Inside Door Handle |
A few heat/cool cycles may help. Also, as far as I know, that pin can be driven in either direction. Try tapping it from the opposite side to see what happens. _________________ nothing |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14258 Location: Casa de Oro, California
Posted: Wed Oct 25, 2017 9:37 am Post subject: Re: Trouble Removing an Inside Door Handle |
Longmont1302 wrote: |
Scott |
Do you have a helper than can back-buck the shaft between the door and your pin with a 1/4" plate steel piece while you tap on the pin? A heavy file like a horse-hoof file or bastard will work too using the head. |
Riff Raff Shivering Sambian
Joined: October 25, 2004 Posts: 3096 Location: Alberta
Posted: Wed Oct 25, 2017 10:19 am Post subject: Re: Trouble Removing an Inside Door Handle |
This helps a lot^^^
Also, if you don't have a drift the right size for that little roll pin, a finishing nail head can be the right size. Hold the nail with a pair of needle nose pliers while tapping and it can be an effective tool. _________________ The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin |
Just us buses Samba Member
Joined: April 27, 2004 Posts: 195 Location: Where the nuthatch winters
Posted: Wed Oct 25, 2017 4:23 pm Post subject: Re: Trouble Removing an Inside Door Handle |
I used to use a broken crochet hook _________________ It doesn't matter where you start, it all comes together; it all falls apart. |
flendershirebu Samba Member
Posted: Fri Nov 23, 2018 7:02 pm Post subject: Re: Trouble Removing an Inside Door Handle |
Hey guys I’m having the same problem but I’m not even seeing the pin and there’s no spring just this piece of foam there’s that screw in the middle but it’s still stuck on there when I take it out I wanted to double check with someone before I started prying on the plastic any help/advice would be appreciated
BarryL Samba Member
Posted: Fri Nov 23, 2018 7:30 pm Post subject: Re: Trouble Removing an Inside Door Handle |
That kind you take off the Phillips screw. I you unscrew the screw a couple threads proud of flush then hit the head of the screw with a piece of wood while holding outward against the beauty ring it should pop free. |
Clara Samba Member
Posted: Sat Nov 24, 2018 5:53 am Post subject: Re: Trouble Removing an Inside Door Handle |
Yes the last pic shows a screw in the middle of the handle. Unscrew it to remove the handle. This kind was used from dec 1963, on buses that had the push button outer front door handles
On the earlier kind with the pin. I find it works better to tap the pin up to remove it.
I am pretty sure there is another thread on this with pics. |
Posted: Mon Nov 26, 2018 7:20 am Post subject: Re: Trouble Removing an Inside Door Handle |
Hey guys thanks for the info I really appreciate it . It makes sense that the handles should come off with just that screw but boy was it stuck I only managed to get the driver side off I’m gonna have to keep working the passenger side. I sprayed some penetrating oil in it to let it sit hopefully that does it
sgellis Samba Member
Joined: July 06, 2016 Posts: 2013 Location: SW Nova Scotia, Canada
Clara Samba Member
Posted: Tue Nov 27, 2018 6:26 pm Post subject: Re: Trouble Removing an Inside Door Handle |
Yes, sometimes they get stuck on. After it is off, I generally use a wire brush to clean up any rust on the splines, and make sure the handle slides on/off easily. I use a dab of grease on the splines before fixing the handle back on, as an anti-rust. |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Tue Nov 27, 2018 8:25 pm Post subject: Re: Trouble Removing an Inside Door Handle |
If you think getting the handle OFF is challenging wait until you're ready to re-install it! _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
redhotgto Samba Member
Posted: Tue Dec 18, 2018 7:38 pm Post subject: Re: Trouble Removing an Inside Door Handle |
I have an early 64 van with handles that have no screw showing, I have busted the esct plate and can see behind the knob but cannot see a pin ?
what now? also this is a plastic handle ,thx for any help |
Thompson2 Samba Member
Joined: June 06, 2018 Posts: 659 Location: Portland, OR
Posted: Tue Dec 18, 2018 9:47 pm Post subject: Re: Trouble Removing an Inside Door Handle |
There’s a 3mm pin tucked in there. If it’s particularly grungy you may want to run a small fire brush or Emory cloth over the base of the handle so you can see it.
Some pics that will hopefully clarify.
Posted: Wed Dec 19, 2018 12:09 pm Post subject: Re: Trouble Removing an Inside Door Handle |
maybe I need glasses !!! cant see it will look again tonite |
Clara Samba Member
Posted: Wed Dec 19, 2018 3:28 pm Post subject: Re: Trouble Removing an Inside Door Handle |
Posted: Thu Jan 17, 2019 5:40 pm Post subject: Re: Trouble Removing an Inside Door Handle |
finally got my handles off, there was mud or something packed in the holes so I couldn't see it, dug them out and boom they came off, thx guys |
