GenXer Samba Member
Joined: January 09, 2015 Posts: 106 Location: Merritt Island
Posted: Sat Oct 21, 2017 7:33 pm Post subject: Non running '84 Scirocco - what am I getting into? |
I found a deal locally on an '84 Scirocco. It's not running and the only info I have gotten on it is that it broke down coming home from work one day. The first thought I had was maybe a timing belt broke and then wondered if an '84 Scirocco has an interference or non interference engine. According to a site I found it looks like the '84 is a non-interference engine. The price seems right at $200. I figure it's worth it in parts. Any thoughts of things to be aware of if I pull the trigger? |
Joined: August 31, 2013 Posts: 12861 Location: North Carolina
Posted: Sat Oct 21, 2017 7:50 pm Post subject: Re: Non running '84 Scirocco - what am I getting into? |
Almost all of the early 8v were non interference but there were a couple of engine codes that were (mostly European examples). $200 is a good price point, you could recoup that at the crusher. The only concern would be is how long it sat, over 1.5 years & it starts getting sketchy (& expensive) in terms of the fuel system. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Sat Oct 21, 2017 11:39 pm Post subject: Re: Non running '84 Scirocco - what am I getting into? |
I'll agree with above post. A good place to start is the timing belt like you thought and then fuel pump. When those go on a CIS motor, they shutoff like you turned the key off. Not enough residual pressure like an efi motor. After converting my CIS motor to MS, I could pull the FP fuse and it would idle for another 30 seconds or so. Less run time under load. but not the drastic shutoff like a CIS motor. |
GenXer Samba Member
Posted: Mon Oct 30, 2017 3:10 pm Post subject: Re: Non running '84 Scirocco - what am I getting into? |
I always hate it when OPs abandon topics so in that vein, I decided to pass. He had sold the wheels. I was going to have to score four wheels, find a car hauler and then deal with having a junker in my driveway for an indeterminate time. It was probably still worth it but just figured I would wait for another opportunity. As a little bit of background, I grew up around VWs as a kid but I have never owned one. The closest I came was I almost got a '68 Squareback for my first car (back in '85). It was mostly dents and faded paint. I've been looking off and on over the years for a fun old vw project. Hopefully in the next year or so I will find one. |
