davidw99 Samba Member
Joined: September 04, 2003 Posts: 696 Location: Boston, MA
Posted: Sun Oct 22, 2017 11:08 am Post subject: Outer Spring Plate Bushing Replacement |
Can the outer (round) spring plate bushings be replace by only removing the spring plate cover? Pry the old one out, push the new one in. They are right underneath the cover. Or, will the tension on the spring plate make it impossible? _________________ Dave
'73 Saturn Yellow Sports Bug that has undergone a full pan off restoration. "Herbert IV."
'67 Sedan. "Bellamy." Currently being "refreshed" and recently repainted. |
johneliot Samba Member
Joined: August 29, 2005 Posts: 2189 Location: Chico, CA
Posted: Sun Oct 22, 2017 11:13 am Post subject: Re: Outer Spring Plate Bushing Replacement |
Yes, it can be done as you say. What you might find though is the the inner one has never been replace and when that happens they tend to get deformed. You might see the torsion bar no longer sitting in the middle of the tube. That might make it hard to get the outer bushing back on. _________________ John
There is no distinctly American criminal class - except Congress.
Mark Twain
69 bug - "The Grey Ghost" |
mark tucker Samba Member
Posted: Sun Oct 22, 2017 2:20 pm Post subject: Re: Outer Spring Plate Bushing Replacement |
jack it up it shpould go on eazer. but you realy should change all 4 of them.other wize your supporting only the end of the bar's and the drinks may just slide off when they have had too much....beer. do all 4. the spring plate tool isant expensive. dont ferget to mark your bars&plates.you dont want to be all wonkey. |
