Fer Samba Member
Posted: Sun Oct 22, 2017 1:53 pm Post subject: 25HP engine case serial number |
Somebody know about this case serial number?
_________________ Oct.1971 Deluxe Microbus
May.1964 Variant Panel Van
http://surfinbus.blogspot.com.es/ |
volksair Samba Member
Posted: Sun Oct 22, 2017 5:47 pm Post subject: Re: 25HP engine case serial number |
According to the technical info section, it appears to be February 1952. |
janerick3 Samba Member
Posted: Sun Oct 22, 2017 6:42 pm Post subject: Re: 25HP engine case serial number |
This looks like an early 1960s replacement case, used for a factory rebuild (the square stamp is a dead giveaway).
The particular stamp set used to stamp the 6-digit number was used at the factory between 1956 and at least 1961.
What are the dates cast into the case halves?
Please include photos of the boss on the right side of the generator stand and of the part numbers below the pushrod tube holes on each side. _________________ Thanks,
Jan K. |
splitjunkie Samba Member
Posted: Sun Oct 22, 2017 6:52 pm Post subject: Re: 25HP engine case serial number |
janerick3 wrote: |
This is likely an early 1960s replacement case, used for a factory 36hp rebuild (the square stamp is a dead giveaway). Since the A-------X series of numbers for rebuilt 36hp engines started in 1964, this rebuild is probably from ~1961-63.
What are the dates cast into the case halves? |
Its an old 25 hp case. The later 36 hp style 25 hp replacement case had the larger protrusion on the right of the generator stand for attaching the oil filler. This has the original small protrusion. The numbers do look wrong so it was probably an older replacement case with the original number restamped. _________________ Chris
oldsplitvw Samba Member
Posted: Sun Oct 22, 2017 9:23 pm Post subject: Re: 25HP engine case serial number |
What are the casting dates on each case half?
That number looks like a really bad grind-down and restamp.
Will |
Fer Samba Member
Posted: Mon Oct 23, 2017 1:48 am Post subject: Re: 25HP engine case serial number |
Posted: Mon Oct 23, 2017 4:43 am Post subject: Re: 25HP engine case serial number |
These numbers on the generator pedestal suggest 18 February 1952, first shift production. |
Fer Samba Member
Posted: Mon Oct 23, 2017 6:58 am Post subject: Re: 25HP engine case serial number |
Woow...thanks, good news 👍 _________________ Oct.1971 Deluxe Microbus
56samba Samba Member
Posted: Tue Oct 24, 2017 8:28 am Post subject: Re: 25HP engine case serial number |
volksair wrote: |
always thought the 2 means second shift and the 1 indicates it as a 1951 case |
Posted: Tue Oct 24, 2017 11:43 am Post subject: Re: 25HP engine case serial number |
56samba wrote: |
volksair wrote: |
Yes, that could very well be, so perhaps it was a February '51 case, restamped as a February '52. Either way, it does appear to be 25hp. |
Fer Samba Member
Posted: Wed Oct 25, 2017 3:08 pm Post subject: Re: 25HP engine case serial number |
Mr. Okrasa Original Old Speed
Joined: May 20, 2000 Posts: 727 Location: Eastside, Costa Mesa. So. Califas...Loco's ;-)
Posted: Sat Oct 28, 2017 11:11 pm Post subject: Re: 25HP engine case serial number |
56samba wrote: |
volksair wrote: |
volksair is correct! This side of the block was cast on Feb. 2, 1951 on second shift. How much is it worth? It has the wrong number font and sequence. _________________
See my Instagram: https://www.instagram.com/okrasa/
1959 VW Karmann Ghia Coupe / Bamboo-Green / Denzel 1300cc / OG. owner, paint
Denzel engine running. See this link: https://youtu.be/DgUlsQDTXTE
VW www.Okrasa.com
356 www.PreA356.com |
2003nbc Samba Member
Posted: Sun Oct 29, 2017 3:28 pm Post subject: Re: 25HP engine case serial number |
If the number stamp shown is a KD engine number sequencing (VW exchange engine serial number as suggested by the square stamp) then based upon the list found in the June 2001 VVWCA newsletter it was rebuilt in March 1960. |
