EverettB Administrator
Joined: April 11, 2000 Posts: 69824 Location: Phoenix Metro
73sparks Samba Member
Posted: Tue Sep 11, 2018 5:51 pm Post subject: Re: Bringing back to life my1960 swr kombi |
the tab on back of light.
and ground cable lights up bright filament. |
western auto Samba Member
Posted: Tue Sep 11, 2018 7:40 pm Post subject: Re: Bringing back to life my1960 swr kombi |
I had a set of junk housings, I cut everything off the back roloc disc sanded everything down smooth , ran a unibit thru them and used 32-34 ford replacement dual filament parking lamp bulb sockets, they drop in install supplied spacer and nut....... early ford store part # B-13075-2, I did modify the depth of the bulb retainer channel on one side of the light socket a bit for 1157 bulb to fit best pair of taillights ever |
Posted: Tue Sep 11, 2018 8:48 pm Post subject: Re: Bringing back to life my1960 swr kombi |
you are very creative and it sounds like a great idea.
But i am just not into putting more time and money into this bus.
I have decided to bleed brakes and make her a roller and clean her up to sell.
She needs some work on A pillars and lower inner outer valence, I have a new lower nose also if they want to replace it or button her up and go.Dog legs are screwed in and ready to weld after they fix A pillars.
This will be a sweet bus for someone who has the skills and knowledge
to get her road ready. |
Posted: Sun Sep 16, 2018 1:47 pm Post subject: Re: Bringing back to life my1960 swr kombi |
Cleaned up rear light housing,used salt and vinegar.
then cleaned off with baking soda and air pressure.
big improvement driving lights and brake lights work now.
still no rear turn signals, maybe in turn signal housing.
also grounded lights from battery ground much better. |
Posted: Mon Sep 17, 2018 1:11 pm Post subject: Re: Bringing back to life my1960 swr kombi |
Have all lights working except right rear turn signal.
traced back to switch and I am getting no power to black red wire (HR)
when signal is used.
No way to get to inner workings, any ideas.
thanks
BarryL Samba Member
Joined: November 01, 2004 Posts: 14269 Location: Casa de Oro, California
Posted: Mon Sep 17, 2018 6:49 pm Post subject: Re: Bringing back to life my1960 swr kombi |
Wash that whole thing in paint thinner while operating the lever. Then try to grease as much as you can with a toothpick and non wheel bearing grease.
See if that works. |
velvetgreen Samba Member
Posted: Mon Sep 17, 2018 6:54 pm Post subject: Re: Bringing back to life my1960 swr kombi |
Dielectric grease would be a good idea |
Posted: Mon Sep 17, 2018 7:23 pm Post subject: Re: Bringing back to life my1960 swr kombi |
I am going to try some contact cleaner(electric grade). spray in and blow out with air to dry. |
Posted: Fri Sep 21, 2018 1:38 pm Post subject: Re: Bringing back to life my1960 swr kombi |
getting bus ready to test drive this weekend. |
Posted: Sun Sep 23, 2018 6:24 pm Post subject: Re: Bringing back to life my1960 swr kombi |
well the fun just keeps on coming,the front shift rod is original to bus
rear long one is new wolfsburg west and both connectors are new also.
my question is the front shift rod is banged up and looks like it might be out of alignment with long shaft to rear, I am having a very tight shifter in
all gears .and reverse also is not very smooth.Tranny was working well before I put in bus.
can that mis alignment up front be the issue.
also any pics on correct lock out plate alignment would help. |
Posted: Mon Sep 24, 2018 8:08 am Post subject: Re: Bringing back to life my1960 swr kombi |
what is the difference between this coupler and the front one
other then they look different,why is rear one designed differently . this does not seem to fit well
in the space ,the one like on the front connector would fit so much better. |
Posted: Mon Sep 24, 2018 9:39 am Post subject: Re: Bringing back to life my1960 swr kombi |
Ya I will wire them , at this point I may have to redue things so waiting. |
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
Posted: Mon Sep 24, 2018 11:12 am Post subject: Re: Bringing back to life my1960 swr kombi |
There have been some shift couplers produced that do not align correctly.
They could be bolted up... but caused shifting problems.
Yours may be OK... but... maybe check to see if the screws are aligned.
It looks like they may be a fuzz off.... might just be perspective though?
The orange line is what I thought was in parallel with the center of of the rods.
I think the green line can be offset from the orange line... (due to perspective)... but I think the green line should be parallel with the orange line.
_________________ aka: Evan
Searchable, click-navigable 1958 Bus Parts List |
Posted: Mon Sep 24, 2018 11:46 am Post subject: Re: Bringing back to life my1960 swr kombi |
yep looking at the pic it does look offset, i will get under and look again.
also ordered a new front shift rod to replace old original one.
Have you heard if other guys saying that rear coupler fits very snuggly
almost touching metal.
I actually bumped metal up a little to make room above coupler.
Thanks for info. |
easy e Samba Member
Posted: Mon Sep 24, 2018 3:24 pm Post subject: Re: Bringing back to life my1960 swr kombi |
great pics and they really shpw how much better german og parts are made.
really good info, thanks . |
Posted: Mon Sep 24, 2018 8:11 pm Post subject: Re: Bringing back to life my1960 swr kombi |
Well I dont know how this got installed in my bus with out noticing
the bend in it.
that cant be correct, I hope.
Cannot find a pic of one not installed any ideas. |
Posted: Mon Sep 24, 2018 8:38 pm Post subject: Re: Bringing back to life my1960 swr kombi |
just checked one in my stash ......yours is fucked |
