Posted: Mon Oct 23, 2017 7:44 pm Post subject: Cleaning the inside of the headlight lens, how to |
I have a pair of the headlights being sold by Bus Depot that are maybe 5-6 years old at this point in time:
https://www.busdepot.com/0301600118
The lenses have gotten pretty foggy on the inside so I was wondering what others have done to clean them.
Thanks, WT |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21519 Location: Oklahoma City
Posted: Mon Oct 23, 2017 8:20 pm Post subject: Re: Cleaning the inside of the headlight lens, how to |
It skunds crude....but it works. I use a pair of long harbor freight hemostats clamped onto a rolled up piece of soft, clean cotton cloth....a classic yellow dust cloth actually....wet with non ammonia glass cleaner like windex crystal rain. Wet it all down and then use a dry one tk polish. Takes several passes. Ray |
Terminatez Samba Member
Joined: June 07, 2015 Posts: 340 Location: Sun Valley, CA
Posted: Mon Oct 23, 2017 8:47 pm Post subject: Re: Cleaning the inside of the headlight lens, how to |
Windex without ammonia.
Stopped by a VW shop a while back and some guy was spraying them with clear coat. He said it prevented them from becoming foggy/yellow. Not sure if it's the same foggy you may be speaking of though. _________________ 1972 Westfalia P30 hardtop Campmobile [On-going Restoration]
aeromech wrote: |
I don't think I've ever seen an engine in worse shape. |
Posted: Mon Oct 23, 2017 10:46 pm Post subject: Re: Cleaning the inside of the headlight lens, how to |
I think....or assumed......he is speaking of the fog that appears over time on the inside of the glass lenses and on the reflectors of any lamp that has a removeable bulb assembly....H1, HB2,H3, H4 etc.
Ray |
Dana Champion Samba Member
Joined: July 06, 2012 Posts: 633 Location: Ventura County, CA
Posted: Mon Oct 23, 2017 11:38 pm Post subject: Re: Cleaning the inside of the headlight lens, how to |
I've used rubbing alcohol inside of H4's
A little tricky getting to all areas. |
Posted: Tue Oct 24, 2017 12:52 am Post subject: Re: Cleaning the inside of the headlight lens, how to |
raygreenwood wrote: |
Ray |
Yes that is what I am talking about. For the lights I bought from BD the problem seem pretty extreme. Looking at the BD lenses it seems impossible that one could drive safely at night at all, the 26-35 year old lenses on my Vanagons being no where near as bad. IIM, the problem seemed to have occurred very quickly over the last few months. |
Posted: Tue Oct 24, 2017 7:29 am Post subject: Re: Cleaning the inside of the headlight lens, how to |
Wildthings wrote: |
Ray |
I have never figured out exactly where this greasy film comes from. I "think" it is plasticizers that have leached out of the rubber cover/boot.....or may be from the adhesive that is used for assembly.
I have some new from the 80s Hella H4 and HB-2 driving lights in the box that are really foggy....and the four on my car are fovgy and need cleaning. Ray |
SGKent Samba Member
Posted: Tue Oct 24, 2017 8:21 am Post subject: Re: Cleaning the inside of the headlight lens, how to |
soapy (dishsoap ) warm water, followed by clean water, and some soft towels pushed around by something soft then let them air or blow a hair dryer in on low. Even really clean compressed air. I am guessing you are talking about CIBIE, Hella's etc.. I'd avoid ammonia and/or alcohol only because I have seen finishes stripped by both. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Tue Oct 24, 2017 9:33 pm Post subject: Re: Cleaning the inside of the headlight lens, how to |
Regular isopropyl....or as I and others have noted....amonnia free windex work fine.
At least on Hella products....the old school lnes...70% isopropyl will not hurt anything. The reflectors are vapor coated steel. Nothing but something abrasive will hurt those. Cant vouch for new stuff. The lenses are lead crystal.
The problem with this fog/film is that its oily.
I would tend to say dishwashing ljquid as well....but be careful because on newer types.....dishwashing liquid can defeat the lens to reflector adhesive if its git any pores. Dilute it well. Ray |
SGKent Samba Member
Posted: Wed Oct 25, 2017 10:15 am Post subject: Re: Cleaning the inside of the headlight lens, how to |
A very expensive diving watch leaked on a dive. I put it in mild alcohol per the standard practice of the day until it could go to the shop. Oops. Lifted all the clear coating on the face. Really careful with alcohol these days because many glues and coatings are alcohol based instead of HC solvent based. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Wed Oct 25, 2017 10:35 am Post subject: Re: Cleaning the inside of the headlight lens, how to |
SGKent wrote: |
A very expensive diving watch leaked on a dive. I put it in mild alcohol per the standard practice of the day until it could go to the shop. Oops. Lifted all the clear coating on the face. Really careful with alcohol these days because many glues and coatings are alcohol based instead of HC solvent based. |
Oh man...thats a fact!
Its not so much that they are alcohol based...even some of the solvent/HC based coatings, paints, inks etc....have this issue with "most" alcohols. it has to do with the actual binder and not the carrier solvent per-se....and the strength of the alcohol.
For instance...70% isopropyl is actually more damaging to some of these coatings...because it has water in it. Its literally water diluted. Water by itself...aside from causing rust....may not touch some of these coatings...but mixed will alcohol its solvency is multiplied. On many of these coatings stronger...but pure 99% isopropyl alcohol (isopropanol) may not hurt it at all.
Ray |
70Crew Samba Member
Joined: June 12, 2006 Posts: 776 Location: Grand Rapids, MI
Posted: Sun Nov 05, 2017 3:46 pm Post subject: Re: Cleaning the inside of the headlight lens, how to |
I just bought these Hella H4 headlights from Bus Depot. Even out of the box, the inside surface of the lens has a milky film.
Reading through the descriptions on how to clean the lens made sense… until I tried to do it. See the photo below. There is a metal cage in the hole that blocks direct forward light from the bulb. That cage would make it virtually impossible to get any sort of rag inside there and do a thorough job. Is this a different style than everyone else has? If not, did you remove the cage? It looks like I could, but the metal is thin and I am afraid I will break something.
_________________ 1970 Crew Cab |
SGKent Samba Member
Posted: Sun Nov 05, 2017 3:53 pm Post subject: Re: Cleaning the inside of the headlight lens, how to |
can't you fish strips of a diaper or something in there, swish with a mild soap and water then invert and get the strips out and rinse with really clean water - maybe even distilled water? I know that some of the milky color is a result of particulates in the air, but some is also due to the dies not being as good as they were in 1970. I use Cibie myself and they don't seem to be as milky as the Hellas. 7" round just isn't that popular anymore for factories to invest in new dies. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
70Crew Samba Member
Posted: Sun Nov 05, 2017 7:26 pm Post subject: Re: Cleaning the inside of the headlight lens, how to |
Thanks Steve, I followed your suggestion to the letter and it worked great. After the distilled water I ran a hair dryer on warm and the did a final pass with a clean cloth. Big difference. Shame I have to spend an hour of my Sunday cleaning a brand new part, but that's another topic. _________________ 1970 Crew Cab |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12722 Location: on a bike ride somewhere
Posted: Sun Nov 05, 2017 7:58 pm Post subject: Re: Cleaning the inside of the headlight lens, how to |
70Crew wrote: |
I just bought these Hella H4 headlights from Bus Depot. Even out of the box, the inside surface of the lens has a milky film. |
I noted this on mine too, but I was in a hurry when I installed them. (Detroit, October 2016, Kate's house… )
I don't recall how long it took to burn off, but they're crystal clear now. Anybody else note how long theirs took?
www.airschooled.com |
Posted: Sun Nov 05, 2017 8:28 pm Post subject: Re: Cleaning the inside of the headlight lens, how to |
My '78 has Bosch (motorcycle) lights from Bus Depot that I installed at some point as I was working on the TDI conversion. So they've been there for roughly 3 years. With relays and the upgraded 90/100w bulbs, the high beams are so bright you can see into the future!
But they still have haze in there.
Later (2015ish), I installed the Bus Depot upgrade kit that they sell for round-light Vanagons in my '73. It includes Hella lenses. Again with the beefy bulbs. Certainly an improvement over stock headlights, but not quite as bright or defined beam as the setup in the '78.
They might have a little bit of haze, not sure... I cannot see the swirl like I can in the '78.
I need to change the bulbs in the '78 (both beefy bulbs burned out on a recent trip-that was an adventure-I replaced with stuff from the FLAPS but just ordered new bulbs.) Maybe then I'll try washing them. With what? Maybe a little Dawn and warm water? _________________ Dave Cook
1973 Wild Westerner
My Thing |
SGKent Samba Member
Posted: Sun Nov 05, 2017 9:17 pm Post subject: Re: Cleaning the inside of the headlight lens, how to |
glad it worked out _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
70Crew Samba Member
Posted: Mon Nov 06, 2017 5:40 am Post subject: Re: Cleaning the inside of the headlight lens, how to |
vwwestyman wrote: |
I need to change the bulbs in the '78 (both beefy bulbs burned out on a recent trip-that was an adventure-I replaced with stuff from the FLAPS but just ordered new bulbs.) Maybe then I'll try washing them. With what? Maybe a little Dawn and warm water? |
I used Ivory dish soap and hot water, and chased it with a couple good rinses with distilled water. Worked great. _________________ 1970 Crew Cab |
Posted: Mon Nov 06, 2017 6:05 am Post subject: Re: Cleaning the inside of the headlight lens, how to |
70Crew wrote: |
vwwestyman wrote: |
I used Ivory dish soap and hot water, and chased it with a couple good rinses with distilled water. Worked great. |
Good deal-did you use anything else--strips of diaper or other cloth to swish around in there, or just the soap? _________________ Dave Cook
1973 Wild Westerner
My Thing |
