Zundfolge1432 Samba Member
Posted: Wed Oct 25, 2017 6:43 am Post subject: What's going on? |
Can you spot the anomaly in this picture, it's fairly obvious.
sb001 Samba Member
Posted: Wed Oct 25, 2017 7:00 am Post subject: Re: What's going on? |
That looks familiar _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Wed Oct 25, 2017 7:01 am Post subject: Re: What's going on? |
cam plug installed wrong for auto stick _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Posted: Wed Oct 25, 2017 7:38 am Post subject: Re: What's going on? |
60ragtop wrote: |
cam plug installed wrong for auto stick |
Yes and one more. These were before pics we caught the discrepancies |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9960 Location: Huntington Beach, CA
Posted: Wed Oct 25, 2017 7:40 am Post subject: Re: What's going on? |
No gland nut! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Posted: Wed Oct 25, 2017 7:42 am Post subject: Re: What's going on? |
VW_Jimbo wrote: |
No gland nut! |
Ok yes but we were in process of disassembly. There's at least one more. |
Mikedrevguy Samba Member
Joined: October 15, 2008 Posts: 2237 Location: Medford, OR
Posted: Wed Oct 25, 2017 8:37 am Post subject: Re: What's going on? |
Not familiar with autostick motors, but do they normally have 6 dowelpins mating crank to the torque converter/flywheel? _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
"The wise speak because they have something to say; while the foolish speak because they have to say something." Plato
Illigitimi non-Carborundum!! |
sb001 Samba Member
Loctite residue that was used on the gland nut _________________ I'm the humblest guy on this board.
1600 SP engine
Posted: Wed Oct 25, 2017 8:38 am Post subject: Re: What's going on? |
Mikedrevguy wrote: |
Not familiar with autostick motors, but do they normally have 6 dowelpins mating crank to the torque converter/flywheel? |
Good question actually those are threaded to use bolts to walk the plate off without prying |
vwoldbug Samba Member
Posted: Wed Oct 25, 2017 8:41 am Post subject: Re: What's going on? |
Rivets loose |
Posted: Wed Oct 25, 2017 8:45 am Post subject: Re: What's going on? |
vwoldbug wrote: |
Rivets loose |
Yes rivets are loose, you can see oil stains from centrifugal force around the holes. In this case it was quicker and cheaper to source another flex plate. |
sb001 Samba Member
Posted: Wed Oct 25, 2017 8:48 am Post subject: Re: What's going on? |
Zundfolge1432 wrote: |
vwoldbug wrote: |
Rivets loose |
Followup- was I supposed to order those replacement rivets for you?
https://www.thesamba.com/vw/classifieds/detail.php?id=1540503
If so I will get right on that. _________________ I'm the humblest guy on this board.
1600 SP engine
Posted: Wed Oct 25, 2017 8:49 am Post subject: Re: What's going on? |
Did it rattle |
Posted: Wed Oct 25, 2017 8:55 am Post subject: Re: What's going on? |
vwoldbug wrote: |
Did it rattle |
unknown engine came out for another reason. I've got a rivet gun and an assortment of bucking bars. I've done steel rivets before, heck I've got a micro shaver and a counter bore to make the upset head look uniform when done.
Last edited by Zundfolge1432 on Wed Oct 25, 2017 9:00 am; edited 1 time in total |
sb001 Samba Member
Posted: Wed Oct 25, 2017 8:57 am Post subject: Re: What's going on? |
vwoldbug wrote: |
Did it rattle |
Well what happened was, I dropped a torque converter bolt down into the bell housing while installing that engine (this was on the 72 super I bought last year.) I had done that before on my 69 and when I started the engine it simply spat the bolt out. But on this one it jammed the flex plate and locked the engine. Those rivets loosened up as a result. Surprisingly, no harm done to block and internals (although we did replace the bearings.) _________________ I'm the humblest guy on this board.
1600 SP engine
sb001 Samba Member
Posted: Wed Oct 25, 2017 8:58 am Post subject: Re: What's going on? |
vwoldbug wrote: |
Did it rattle |
unknown engine came out for another reason. I've got a rivet gun and an assortment of bucking bars. I've done steel rivets before, heck I've got a micro shaver and a counter bore to make the upset head look uniform when done. |
Wait--was this not the one off my 72 super? _________________ I'm the humblest guy on this board.
1600 SP engine
Posted: Wed Oct 25, 2017 9:05 am Post subject: Re: What's going on? |
Yes it's same one |
