Vanagon Nut Samba Member
Posted: Wed Oct 25, 2017 11:46 am Post subject: Hobart 140 Teflon or Nylon Liner? |
Hi folks.
I'm new to this forum but am quite active on the Vanagon forum here.
My Hobart Handler 140 lists aluminum but reading here it seems that at minimum, I need Argon shielding gas and a soft liner. (teflon, nylon). I just contacted Hobart. They do not sell a soft liner for the 140
Has anyone found a soft liner that fits this MIG gun/cable? Miller part?
Thanks
1988 West DIY 50º ABA
VE7TBN |
Posted: Wed Oct 25, 2017 12:52 pm Post subject: Re: Hobart 140 Teflon or Nylon Liner? |
.... another reply from Hobart suggested HTP as a possible source.
I see this from USAweld. Ad references to the Hobart 140 along with others:
http://www.usaweld.com/Aluminum-Welding-Kit-p/aluminumweldingkit.htm _________________ 1981 Westy DIY 15º ABA
VE7TBN |
CiderGuy Samba Member
Joined: December 23, 2013 Posts: 1351 Location: Bucks County, Pa
Posted: Thu Oct 26, 2017 4:07 am Post subject: Re: Hobart 140 Teflon or Nylon Liner? |
Have you called your local welding\gas place ? They usually are very helpful and if there is such a part have it or can get it for you. Also best to find one which represents your brand of welder. _________________ ----------------------
Cars Currently Owned:
1970 Karmann Ghia Coupe
1973 Karmann Ghia Coupe - Project car for sale
1970 Karmann Ghia Convertible (Body off restoration)
Timing is everything |
Posted: Thu Oct 26, 2017 12:08 pm Post subject: Re: Hobart 140 Teflon or Nylon Liner? |
CiderGuy wrote: |
Have you called your local welding\gas place ? They usually are very helpful and if there is such a part have it or can get it for you. Also best to find one which represents your brand of welder. |
Yes. Just yesterday, spoke with a fellow at local hardware/etc. place. We spoke of the "push-pull" or spool gun options. And yes, he was quite helpful. From what I've read here and elsewhere, w/o a push-pull or spool gun, a MIG can be used for aluminum but even with a teflon/nylon liner, gun cable has to be straight, usually a thicker wire is used and of course theres the limits of a 110 VAC 140 Amp MIG in terms of metal gauge.
I realize this is a body/paint forum, so I appreciate list patience, but my plan is to fabricate an intake manifold. All things considered, I'm thinking I'll make it out of steel. (aluminized)
VE7TBN |
theKbStockpiler Samba Member
Joined: July 07, 2012 Posts: 2316 Location: Rust Belt
Posted: Thu Oct 26, 2017 2:24 pm Post subject: Re: Hobart 140 Teflon or Nylon Liner? |
The machine has to be 'Spool Gun' ready or there are conversions for them.
Your limitations are going to revolve around the power of your welder. A guess off the top of my head is that a 140 amp machine (if it's named by it's current max) is going to be 3/16ths of an inch and under. If you don't want limitations with welding Aluminum you have to break the 225 amp threshold.
You also need U Grooved Driver Rollers. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask. |
Posted: Thu Oct 26, 2017 3:05 pm Post subject: Re: Hobart 140 Teflon or Nylon Liner? |
It seems there are push-pull units that could be incorporated. But as you say, limited on thickness of work and yes, most likely 3/16".
If I ever delve into aluminum I think TIG will be the way to go. But then I'll have to convince the landlord to let me run new cable to the shop. ..... I think. Anyhow.....
VE7TBN |
Posted: Sat Oct 28, 2017 10:56 am Post subject: Re: Hobart 140 Teflon or Nylon Liner? |
I made a type O on the aluminum thickness. I meant to type 3/32 of an inch. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Posted: Sat Oct 28, 2017 11:53 am Post subject: Re: Hobart 140 Teflon or Nylon Liner? |
Thanks. No problem; I make edits on the samba all the time.
My mind has been focused on thickness/design of intake flange at head so had that thickness in mind. _________________ 1981 Westy DIY 15º ABA
VE7TBN |
modok Samba Member
Joined: October 30, 2009 Posts: 26788 Location: Colorado Springs
Posted: Mon Oct 30, 2017 3:30 am Post subject: Re: Hobart 140 Teflon or Nylon Liner? |
Hobart sells a spool gun, in many cases they include it or give a discount on it with the 180-200 amp models, because I bet a lot of guys have the same idea you do, but it's mostly pie in the sky, they don't get used much. So maybe you can get a used one for cheap. the 180 and 140 probably use the same gun and cable, which is the same as miller. I "think" Mine are, but my stuff is older. |
Posted: Mon Oct 30, 2017 11:29 am Post subject: Re: Hobart 140 Teflon or Nylon Liner? |
thanks modok.
I may look into that option. Finding 1.25" exhaust pipe locally is proving futile. We'll see. Cost of setting up for aluminum in any way vs losing ~ 2" ground clearance by sticking with the stock intake.....
VE7TBN |
modok Samba Member
Posted: Thu Nov 02, 2017 3:54 am Post subject: Re: Hobart 140 Teflon or Nylon Liner? |
Perhaps looking for aluminumized?
1.25 tubing is commonly used for bicycles and racecars.
to the thrift store! |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Thu Nov 02, 2017 11:53 am Post subject: Re: Hobart 140 Teflon or Nylon Liner? |
I'm guessing that you should be able to weld 3/16" as well as 3/32" aluminum with a proper 140 etc aluminum setup? _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Thu Nov 02, 2017 2:52 pm Post subject: Re: Hobart 140 Teflon or Nylon Liner? |
Here's Millers Welding AMP calculator.
https://www.millerwelds.com/resources/weld-setting-calculators/mig-solid-core-welding-calculator
With their rules a 140 is enough but Welder Manufacturer's rate their products higher than what they can do. Is a Hobart 140 spool gun ready? _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
modok Samba Member
Posted: Thu Nov 02, 2017 7:49 pm Post subject: Re: Hobart 140 Teflon or Nylon Liner? |
the way I read it, their calculator says it won't work.
Look at the voltage. Not enough volts to reliably get into spray transfer.
There is a chart in the owners manual showing the amps/volts curves
It's same as my beloved 130xp miller, that's why I have it memorized |
Posted: Fri Nov 03, 2017 12:28 pm Post subject: Re: Hobart 140 Teflon or Nylon Liner? |
Excellent point made Modok!
I researched this before I bought a TIG and the consensus was that you need 180 Amps+ to weld aluminum. If you start out with a modest MIG then you have to make a big jump up in equipment to have aluminum capabilities later on. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Posted: Sat Nov 04, 2017 12:10 pm Post subject: Re: Hobart 140 Teflon or Nylon Liner? |
Interesting and helpful comments here. Thanks. At this point I've ruled out building a custom intake. Its clear I'll need to get into a 220 Volt TIG to do any decent work. Of course I could do all the fabricating then, with any luck, adapt my Hobart with a nylon sleeve, argon, etc tac the parts then get a weldor to finish it. Maybe.... At some point I need to weigh cost and time VS lost ground clearance due to OEM cross flow intake.
VE7TBN |
Posted: Sat Nov 04, 2017 1:29 pm Post subject: Re: Hobart 140 Teflon or Nylon Liner? |
With your current equipment I would only get the liner and see how much pre-heating helps. You can see if all the birdnesting stories are true. Some of the big MIG's have high open voltage and stub into the workpiece a lot less but still do it. I would set the drivewheel pressure so the wire barely feeds and definately use U grooves.
I have a Chinesse TIG which works fine but they are not concerned with service or parts after the sale. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Posted: Sat Nov 04, 2017 6:51 pm Post subject: Re: Hobart 140 Teflon or Nylon Liner? |
So the Trimix I currently have would suffice for tac welds eh? I could live with "being out" a roll of wire and new liner should that setup not work.
VE7TBN |
Posted: Sat Nov 04, 2017 9:04 pm Post subject: Re: Hobart 140 Teflon or Nylon Liner? |
Some of this stuff is not experimented with because it is out of range with what is supposed to work.
Miller states that 'Short Circuit' transfer is not recommended which is what will happen if your voltage is too low. The wire will stub into the work and the feeder will birdnest. With Spray Transfer it does not repeatedly stub into the work. If the feeder slips and or the Stick Out gets too short the wire is said to get welded to the Tip.
The explanations of Constant Current and Constant Voltage welders are not complete so unless you look at a welder schematic it's hard to theorize on it. If the Open Voltage is higher than 'running voltage' it seems reasonable that the voltage does drop as current is increased like most other electrical devices. This would mean that if your current is maxed out the voltage will be way too low and it won't Spray Transfer.
I guess If I were to try it I would preheat ,have minimal driveroll tension and practice keeping the Stick Out as long as possible.
Here's a link on Stick Welding Aluminum
http://hildstrom.com/projects/stickaluminum/
Real men ,stick weld. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
