t3rrybmx Samba Member
Posted: Thu Nov 09, 2017 7:53 pm Post subject: Re: 81 1.6 diesel pickup stalling after timing belt change |
Posted: Thu Nov 09, 2017 7:59 pm Post subject: Re: 81 1.6 diesel pickup stalling after timing belt change |
In other news my interior came out good. Got 2017 Chevy Cruze adjustable leather seats mounted in. Some guy who works at GM was throwing them out down the street from me. Guys at the paint shop mixed up a vinyl paint so the doorcards match. whole new floor and cross support. the other cross member was to high for the seats plus it was to far gone. Looks good and the seats slide all the way forward and are height adjustable. |
Posted: Tue Dec 19, 2017 6:39 pm Post subject: Re: 81 1.6 diesel pickup stalling after timing belt change |
ok so i went to retime the truck today. like i said before the belt was riding to the side of the injection pump pulley. So I take the belt off and wiggle around the injection pump pulley, its got a lot of play in it. So what, a bearing is shot? Also i took the nut off the pulley and the gear slid over what would seem to be the exact amount it needs to be to be in the correct position. So when I tighten the nut back up the gear slides in closer to the injection pump arm or mounting plate or whatever you want to call it. That doesnt seem correct as when tightened down its no more than a mm from the mounting plate. Im going to start searching on the forums now unless some one wants to point me in the right direction. Thanks |
Posted: Tue Dec 19, 2017 7:03 pm Post subject: Re: 81 1.6 diesel pickup stalling after timing belt change |
Everything Im reading is saying its the IP mainshaft bearing. Any info on how to replace that? Thanks |
Posted: Sat Dec 30, 2017 2:11 pm Post subject: Re: 81 1.6 diesel pickup stalling after timing belt change |
truck runs thanks |
