12gofast Samba Member
Posted: Thu Oct 26, 2017 6:00 am Post subject: Spring Plate Issues |
Whats wrong with these pics? Getting ready to replace the spring plate bushings and noticed on the passenger side there were only 2 bolts going through the spring plate -1st pic.
After disconnecting the arm, i found the bolt hole is on the bottom of the arm, and the slot is on the top of the spring plate 2nd pic.
Wrong spring plate? Its a Desert Fox Spoiler on a 74 beetle chassis.
Drivers side had 3 bolts which lined up correctly 3rd pic.....any thoughts?
manxdavid Samba Member
Joined: November 24, 2003 Posts: 1841 Location: David Jones, Anglesey, North Wales, UK. Manxclub #678.
Posted: Thu Oct 26, 2017 6:40 am Post subject: Re: Spring Plate Issues |
Someone has wrongly replaced the right side spring plate with a left hand side one by the look of it. |
bigfatloser Samba Member
Joined: July 27, 2014 Posts: 94 Location: High Desert Calif
Posted: Thu Oct 26, 2017 4:34 pm Post subject: Re: Spring Plate Issues |
I think you have a single plate trailing arm on a dual plate spring plate. I ran into the same issue on the pan I bought. I just drilled and tapped a new hole. _________________ DMZFAB.COM |
Posted: Thu Oct 26, 2017 5:25 pm Post subject: Re: Spring Plate Issues |
bigfatloser wrote: |
I think you have a single plate trailing arm on a dual plate spring plate. I ran into the same issue on the pan I bought. I just drilled and tapped a new hole. |
Are there any dimensional differences between single plate vs. Double plate trailing arms? |
Posted: Thu Oct 26, 2017 6:25 pm Post subject: Re: Spring Plate Issues |
No clue, but I would imagine not. _________________ DMZFAB.COM |
