Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2211 Location: UK (South)
Posted: Fri Oct 27, 2017 11:06 am Post subject: Push rod tube seals. Dry, oiled or sealant? |
Hi
Sorry, I know this has been discussed before, but I've not found a definitive answer - When fitting spring-loaded push rod tubes, should the case and head seals be fitted dry, oiled or should I use a sealant?
I fitted Scat big-mouth tubes about 18 months ago, and about half of them leak at the heads or the case.
I saw a tip on here of tapping them home with a screwdriver on the seal-retaining washer, which helped, but a couple of them leak a fair bit, so I'm going to take them out and replace the seals tomorrow.
When I put them back in, what can I do to avoid further leaks?
When I took the old, fixed tubes out (they leaked too), there was sign of grey sealant in the seating sockets in the case and heads that I cleaned off, but the sockets looked slightly rough/uneven, so should I use a sealant, or should the seals conform to any irregularity?
I'm not going to pull the heads and use fixed tubes because whoever built this engine used blue hylomar between the barrels and the case. I don't want to disturb the barrels and have further problems. _________________ Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786 |
Danwvw Samba Member
Posted: Fri Oct 27, 2017 11:13 am Post subject: Re: Push rod tube seals. Dry, oiled or sealant? |
I have been using the CB-Performance Racing tubes the Stainless are nice! Wide mouth. I use silicone grease on mine. Some say dry. I find the grease keeps them able to move with the engine over time. No leaks on 3 engines so far. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Split 66' Samba Member
Joined: October 07, 2010 Posts: 1257 Location: Bay Area, California
Posted: Fri Oct 27, 2017 3:35 pm Post subject: Re: Push rod tube seals. Dry, oiled or sealant? |
I bought a set of Jaycee PR tubes about 7 years ago, not one drop of oil has leaked from them since. Just lubricated the included silicon seals with the oil I'm using (VR1), on installation. That was the last time I thought about my PR tubes.
Seem like they'll last a lifetime:
https://www.cbperformance.com/Original-JayCee-Push-Rod-Tubes-s/127.htm _________________ "OG = Original German" -- TheSamba.com dictionary |
Joey Samba Member
Joined: August 12, 2005 Posts: 5366 Location: Nova Scotia - Canada
Posted: Fri Oct 27, 2017 3:37 pm Post subject: Re: Push rod tube seals. Dry, oiled or sealant? |
I've always used a thin coat of wheel bearing grease. _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Fri Oct 27, 2017 3:51 pm Post subject: Re: Push rod tube seals. Dry, oiled or sealant? |
Oil and make sure the case/head seal surfaces are smooth. Wet/dry 300 grit sandpaper if need be to polish those areas. _________________ In Stereo, Where Available! |
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
Danwvw Samba Member
Posted: Fri Oct 27, 2017 5:29 pm Post subject: Re: Push rod tube seals. Dry, oiled or sealant? |
Yeah it is course! But it would be perfect for this job. You could follow up on the 300 with 400! _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Posted: Fri Oct 27, 2017 5:38 pm Post subject: Re: Push rod tube seals. Dry, oiled or sealant? |
easy e wrote: |
Is 300 grit really a polishing step?... seems coarse. |
Well you are not shooting for mirror finish with cigarette ash as the last step, like some folks will do for making a telescope lens.
Still you want a smooth enough surface so that the slides into place and does not tear as one torques down the heads.
merriam-webster.com list "Polish" as:
1 :to make smooth and glossy usually by friction :burnish
2 :to smooth, soften, or refine in manners or condition
3 :to bring to a highly developed, finished, or refined state :perfect
So we mean #2. _________________ In Stereo, Where Available! |
easy e Samba Member
Posted: Fri Oct 27, 2017 5:56 pm Post subject: Re: Push rod tube seals. Dry, oiled or sealant? |
Heh.. ok. I didn't really think you left off a zero.
3,000 grit seems like it would be overkill (and I don't think I've ever seen wet/dry that fine of a grit) _________________ aka: Evan
Searchable, click-navigable 1958 Bus Parts List |
Danwvw Samba Member
Posted: Fri Oct 27, 2017 6:13 pm Post subject: Re: Push rod tube seals. Dry, oiled or sealant? |
You could polish it to a finish but that would make it sticky to the silicone seals. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Posted: Sat Oct 28, 2017 10:14 am Post subject: Re: Push rod tube seals. Dry, oiled or sealant? |
Thanks all. I used some grease and so far so good. One of the No.4 cylinder tubes might be weaping, but I need to clean it again and run it some more tomorrow. The tube sockets were actually pretty good. I must have cleaned them up more than I thought when I fitted these tubes the first time.
I also realised that the metal washer on these tubes which acts as a 'back stop' for the seals needs to be manipulated to get it square to the head.
The tube sockets in the head and in the case are offset relative to each other.
With stock tubes; the concertina must make up the offset so the end of the tube can sit perpendicular to the case or head (another reason to expand the concertina before fitting).
On spring-loaded tubes, they can't flex like that and the washer wants to stay square to the tube, not the head, so it pinches/pushes the seal in more on one side than the other.
Once in place, a gentle press on the foremost side of the washer at the head end and rearmost side at the case end with the end of a screwdriver squares them up to the case or head, so they press evenly on the seal.
While I'm updating this, I asked Scat to confirm which way round the tubes should go (I've seen people saying fat end to the case or fat end to the head to give more clearance for the pushrods on bigger engines). They said...
Quote: |
The larger diameter tube goes against the case
the smaller one goes up against the head
this way when oil drains back down the tube, oil will not puddle where the the two tubes slide together
this keeps the oil from trying to leak past the o rings
I suggest to put some oil or marvel mystery oil on the o rings to prevent them from sticking to the tubes where they slide togther
and when you put the pushrod tube seals against the case and the head, don’t put them on dry, use some moly grease against the seal surface
to prevent leakage |
