Joined: August 31, 2013 Posts: 12848 Location: North Carolina
Posted: Mon Nov 13, 2017 4:26 pm Post subject: Re: The Bi- Coastal Bi Polar Bus. |
Cheapest thing to do is to create an exhaust leak & see if it performs better, if so, then you know that it's a back pressure issue. If it is then maybe you have a beetle type stock muffler laying around & toss that on, it's got twice the exhaust port, run it around the block with the apron off & see if it helps. You have changed everything EXCEPT the exhaust, no?
Anytime I have ever heard a vehicle get louder and NOT go any faster when the accelerator is depressed, it's either due to overadvanced cam timing or a restriction in the exhaust. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
wcfvw69 Samba Purist
Posted: Mon Nov 13, 2017 4:28 pm Post subject: Re: The Bi- Coastal Bi Polar Bus. |
Well hell.. Maybe it's time to buy Colin a plane ticket for a late season itinerant visit.
I'm not sure there's anyone more versed in all things VW buses than him.. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Mon Nov 13, 2017 4:37 pm Post subject: Re: The Bi- Coastal Bi Polar Bus. |
Tram wrote: |
Read my fingers: THE. EXHAUST. IS. NOT. PLUGGED.
Damn. |
But if it's not a NOS VW muffler then maybe it's just a restrictive aftermarket POS & you've been chasing your tail & replacing everything else because of it. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22711 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Mon Nov 13, 2017 4:38 pm Post subject: Re: The Bi- Coastal Bi Polar Bus. |
TDCTDI wrote: |
Anytime I have ever heard a vehicle get louder and NOT go any faster when the accelerator is depressed, it's either due to overadvanced cam timing or a restriction in the exhaust. |
Actually, the roaring louder symptom stopped completely when I changed the trans. It's now revving better, rolling freer, and will hit 60 rather than 50 then a struggle to hit 55.
But it's topping out at just above 60.
When I saw that other post about the stock exhaust robbing power and lopping 10 MPH off the top end I was just thinking "That's this Bus!"
I wish I DID have a different exhaust around to try but all my parts stash is Type 3 and that dog won't hunt on a Bus.
If I'm going to have to pull this mother apart AGAIN I'm going with an NOS West German muffler and resonator. If I could find a header that didn't sound obnoxious and had a REAL preheat I wouldn't mind it but I'm not sure this exists.
Yep, changed everything except the exhaust, heads, and cooling tin.
So this "VW" muffler is a fuckin' Jopex. Swell.
Damn Columbo the Bus... _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Mon Nov 13, 2017 4:43 pm Post subject: Re: The Bi- Coastal Bi Polar Bus. |
Tram wrote: |
Damn Columbo the Bus... |
The only issue I saw with this Jopex muffler is the fresh air elbows don't line up for shit at the heater boxes. The muffler fit well and lined up nicely with heat risers. Oh, and the factory paint burned off rather quickly but in dry Arizona, I don't care. _________________ Contact me at [email protected]
Posted: Mon Nov 13, 2017 4:50 pm Post subject: Re: The Bi- Coastal Bi Polar Bus. |
wcfvw69 wrote: |
Tram wrote: |
The only issue I saw with this Jopex muffler is the fresh air elbows don't line up for shit at the heater boxes. The muffler fit well and lined up nicely with heat risers. Oh, and the factory paint burned off rather quickly but in dry Arizona, I don't care. |
Yeah, and GEX occasionally builds a good engine. I specifically ordered a stock muffler to avoid aftermarket bullshit and because that's what the customer wanted. In fact, I never even knew Dansk was now Jopex. I've never seen a Dansk or Ernst or Leistritz with VW part numbers stamped like that, so I thought it was an original. I guess I need to get out more. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Mon Nov 13, 2017 5:09 pm Post subject: Re: The Bi- Coastal Bi Polar Bus. |
Tram wrote: |
I guess I need to get out more. |
Clearly! Gosh!
I don't know what I was thinking. I should of bought an NOS German muffler just so the fresh air cubes lined up correctly with the heater boxes. Hell, I may still do that too though this muffler is ok for now. _________________ Contact me at [email protected]
Posted: Mon Nov 13, 2017 5:50 pm Post subject: Re: The Bi- Coastal Bi Polar Bus. |
wcfvw69 wrote: |
Tram wrote: |
Clearly! Gosh!
I don't know what I was thinking. I should of bought an NOS German muffler just so the fresh air cubes lined up correctly with the heater boxes. Hell, I may still do that too though this muffler is ok for now. |
And the funniest part of that is that the fresh air tubes on this one line up perfect. In fact, earlier my wife and I were out playing with our old Garmin GPS checking the speedo in it on a highway run and she was aghast at how good the heat is in it- she even made me shut it off.
It's like the guy in the stock exhaust swap says. If only I could get another 10 MPH out of it I would be damn happy. The Type 3 distributor cleared up the boat anchor acceleration.
This actually makes total sense if these new "stock" Malaysian exhausts are restrictive. Vacuum signal can't be anywhere close to correct if the engine has asthma. No wonder the stock distributor sucks. Or would that be "blows" in this case?
"Uh... just one more thing." _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
D/A/N Samba Member
Posted: Mon Nov 13, 2017 5:53 pm Post subject: Re: The Bi- Coastal Bi Polar Bus. |
So who sells a known good exhaust? Bus Depot? Other? |
Posted: Mon Nov 13, 2017 6:20 pm Post subject: Re: The Bi- Coastal Bi Polar Bus. |
D/A/N wrote: |
About that... Check yer email... _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Mon Nov 13, 2017 8:07 pm Post subject: Re: The Bi- Coastal Bi Polar Bus. |
wcfvw69 wrote: |
Tram wrote: |
Clearly! Gosh!
Do me a favor... seriously. Could you measure the ID of your tailpipe? _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Tue Nov 14, 2017 11:54 am Post subject: Re: The Bi- Coastal Bi Polar Bus. |
OK, so any feedback from the Bay group on what is a suitable exhaust for this Bus? We need one reasonably quiet with heat risers that isn't a choker for a SP 1600, bone stock.
I've located a candidate at Bus Depot that looks good but I'd like to know if anyone has experience with their European stock mufflers. Other suggestions appreciated too. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Tue Nov 14, 2017 12:05 pm Post subject: Re: The Bi- Coastal Bi Polar Bus. |
Find a real German NOS. If you want heat risers and quiet. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
Posted: Tue Nov 14, 2017 12:10 pm Post subject: Re: The Bi- Coastal Bi Polar Bus. |
Spike0180 wrote: |
Find a real German NOS. If you want heat risers and quiet. |
Been looking... found a good candidate that says it's for 1971- 73 Bus but the pics are of a stale air 1200 when I look closely.
Yeah, I know '72 on is a Type 4 engine but 1600 was available in Europe to the end of production so I didn't question that too much. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Tue Nov 14, 2017 12:25 pm Post subject: Re: The Bi- Coastal Bi Polar Bus. |
Here's another thing. It seems that around the early 1990s there was indeed a "part number consolidation"... my research suggests that the correct part number should be a 211 251 051 F , but that one is impossible to find outside of Europe, it seems. Everyone including the sellers of the NOS mufflers lump 1963-71 together in one group.
It seems impossible that a muffler that's correct for a 1200 is also correct for a 1600. It seems to me that I recall 1200 being its own thing and 1500-1600 being a different P/N.
UNLESS the NOS ones were made to 1600 flow specs and retrofitted back to 1200, which is typical of what VW used to do with parts.
Maybe I am overthinking this and I should just assume that anything NOS VW that has a tag saying it fits 1963-71 is OK and just go for it. Can you tell I'm in the "once- bitten- twice- shy" zone on this Bus? _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12721 Location: on a bike ride somewhere
Posted: Tue Nov 14, 2017 12:32 pm Post subject: Re: The Bi- Coastal Bi Polar Bus. |
Not sure if this helps, but 70 mph is doable on flat ground with this guy. (1584 single port, 30pict3, 205t, stock Resolit cam.) I haven’t pushed it above 72 though; I feel like it would max out at 75. No VW part number, but it did have the Liestritz Sound Star sticker on it when I found it on eBay years ago. The VHT ceramic coat has about 50k miles and one lap of the country on it.
Robbie
_________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
Posted: Tue Nov 14, 2017 12:55 pm Post subject: Re: The Bi- Coastal Bi Polar Bus. |
asiab3 wrote: |
Robbie
06/ 76 build date. Those were the days, brother. That's top quality shit right there. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Tue Nov 14, 2017 12:57 pm Post subject: Re: The Bi- Coastal Bi Polar Bus. |
Tram-
Bugcity-
https://bugcity.com/shop/shop.htm?-session=BugCitySess:4BA7038C1b33923894wP274BF44A
Muffler, Bus Type II, 66-71, Nos German Leistritz HJS
Item#: 211251051EGR
Exit designed for left side.
Search under NOS muffler- The link is not working. _________________ Contact me at [email protected]
richparker Samba Member
Joined: November 24, 2011 Posts: 6980 Location: Durango, CO
Posted: Tue Nov 14, 2017 2:17 pm Post subject: Re: The Bi- Coastal Bi Polar Bus. |
That thread doesn't seem to have any real conclusion... or am I missing something? _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
