ALANSD Samba Member
Joined: April 16, 2015 Posts: 341 Location: Woodstock, GA
Posted: Sun Oct 29, 2017 6:04 am Post subject: help needed, please |
since I had a stroke in August, my thing has been sittibg in the garage until Friday when we needed it out to catch a big rat snake living in there. My wife (who has never driven it before,) pulled it out and turned it around to go back in before the weekend rain. 'It would not go into any gear, and puttiing it in first then starting it, made it pop out of gear.
The critter guy who was here to get the snake said he was a longtime vdub owner and this was a conmon failure of the gland nut. he said I will have to pull the engine and replace the nut. of course I can do nothing until maybe spring time, but does this sound likely? i thought it might be lack of clutch fluid ibn the cylinder, but truly have no clue, it was running and driving great before this event, now sitting in the yard under a tarp. the guy says sitting unused for a few months can cause this to fail. he did get the 5 foot snake out though, _________________ foirmer pro guitarist with 80s band Atlanta
had vws since 1968.buses.ghia,thing....love 'em |
EDragnDean Samba Member
Joined: July 13, 2005 Posts: 1148 Location: Vancouver, WA
ALANSD Samba Member
Posted: Sun Oct 29, 2017 11:26 am Post subject: Re: help needed, please |
A friend came over, got it in reverse then first and drove it into my garage. _________________ foirmer pro guitarist with 80s band Atlanta
ALANSD Samba Member
Posted: Mon Oct 30, 2017 5:15 am Post subject: Re: help needed, please |
a fiend is coming to check the coupler for me _________________ foirmer pro guitarist with 80s band Atlanta
Posted: Mon Oct 30, 2017 10:08 am Post subject: Re: help needed, please |
A bad pilot bearing (gland nut bearing) will make it hard to get into gear at a stop. It can also cause the vehicle to suddenly surge when in gear.
A failing clutch cable will also cause it to be hard to get into gear and you should be able to detect the excess free play and the lighter force needed to push the pedal down.
If the problem is in the shift rod/coupling the shifter should have abnormal play in it. |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
FV195 Samba Member
Joined: February 19, 2005 Posts: 480 Location: carlisile, pa
Posted: Wed Nov 01, 2017 4:15 pm Post subject: Re: help needed, please |
Being a stroke survivor myself, best of luck! My thought leans to pressure plate rusted to flywheel, broken Bowden tube, arms bent on clutch fork,
All require engine removal, rusted plate could have caused other problems. Best bet is have one person step on clutch pedal and someone else looking in wheel well to see if arm is moving. Could be as simple as a stretched cable. I know having a stroke takes you out of the wrenching game, but through hard work, you should be able to work back into it. Good luck |
Posted: Wed Nov 01, 2017 4:24 pm Post subject: Re: help needed, please |
I will throw in that the lever arm on the clutch release shaft can crack and keep the clutch from releasing, while the welds for the arms on the fork can crack and cause the same problem. As FV195 mentioned you may well have to pull the engine to figure out exactly what is wrong. |
