VWAL Samba Member
Posted: Mon Oct 30, 2017 2:55 pm Post subject: MK1 Turn Signals and 4-Ways |
My 1984 Jetta turn signals as well as 4-way flashers come on and stay on without blinking. Indicator light on dash gives a quick flash as you turn the switch on. All bulbs are working. Does this indicate a faulty flasher? If so, where is the flasher located? Thanks. |
Joined: August 31, 2013 Posts: 12816 Location: North Carolina
Posted: Tue Oct 31, 2017 7:36 am Post subject: Re: MK1 Turn Signals and 4-Ways |
It could be the flasher relay (on the relay panel, above the fuses), could be a turn signal switch, it could be the flasher switch, or a fuse, or maybe someone put the wrong bulbs in the light housing (for some unknown reason, people stuff 1156 single element bulbs into the 1157 style dual element holders, I've seen this at least 80 times.). _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
MrPapageorgio Samba Member
Joined: May 26, 2014 Posts: 27 Location: Surrey, British Columbia, Canada
Posted: Tue Oct 31, 2017 11:33 pm Post subject: Re: MK1 Turn Signals and 4-Ways |
Check Your fuses... Mine does the same thing |
VWAL Samba Member
Posted: Wed Nov 01, 2017 3:54 am Post subject: Re: MK1 Turn Signals and 4-Ways |
It was the flasher! All fixed. Thanks! |
