Subaru Throttle Body
hogan029
hogan029 is offline
PostPosted: Wed May 23, 2018 7:25 pm    Post subject: Subaru Throttle Body Reply with quote
Hi all,
Just wondering with the conversion fellas around here. When your gas pedal is pushed down to the floor, is your throttle body 100% open? I noticed that mine is only about 80% open.. I have tried to adjust the cable with zero success.. any tips or mods at the front end?
Thanks
11BC2
11BC2 is offline
PostPosted: Wed May 23, 2018 7:39 pm    Post subject: Re: Subaru Throttle Body Reply with quote
What year and model throttle body are you using?
hogan029
hogan029 is offline
PostPosted: Wed May 23, 2018 7:56 pm    Post subject: Re: Subaru Throttle Body Reply with quote
It's from a 98 EJ25
11BC2
11BC2 is offline
PostPosted: Wed May 23, 2018 9:58 pm    Post subject: Re: Subaru Throttle Body Reply with quote
Hmmmm...I will look at one in the morning, when I get to the shop.
syncrodoka
syncrodoka is offline
PostPosted: Wed May 23, 2018 10:08 pm    Post subject: Re: Subaru Throttle Body Reply with quote
I use the burley motorsports throttle conversion kit on my ej22s. No problem getting full throttle, been verified a few times.
mackaymanx
mackaymanx is offline
PostPosted: Wed May 23, 2018 10:20 pm    Post subject: Re: Subaru Throttle Body Reply with quote
[url=http://www.vw-mplate.com/mplate2-18600.png]Click to view image[/URL]
dobryan
dobryan is offline
PostPosted: Thu May 24, 2018 5:02 am    Post subject: Re: Subaru Throttle Body Reply with quote
Some conversions do not open the throttle fully. Vanaru was like that and may still be. It is not the cable, it is the lack of full leverage/movement on the body that causes it.
Dave O
The Western Syncro build
hogan029
hogan029 is offline
PostPosted: Thu May 24, 2018 5:44 am    Post subject: Re: Subaru Throttle Body Reply with quote
Ah okay makes sense. I don't know if I want to drop 100$ on the bracket from Burley. I keep trying to adjust things and then my idle is a little off cause of too much tension.. may just have to let things lie.
jberger
jberger is offline
PostPosted: Thu May 24, 2018 8:12 am    Post subject: Re: Subaru Throttle Body Reply with quote
If I remember correctly, you can simply change the attachment point of the cable at the pedal lever under the cabin floor. It's been a while since I did my last one but I don't remember having to weld it... just drill it further out. This does make the pedal feel a bit more stiff though.
J
Rorke
Rorke is offline
PostPosted: Thu May 24, 2018 9:55 am    Post subject: Re: Subaru Throttle Body Reply with quote
Hogan,
When you take your foot off the gas, does the RPM stay high?
hogan029
hogan029 is offline
PostPosted: Thu May 24, 2018 10:27 am    Post subject: Re: Subaru Throttle Body Reply with quote
No it goes back down to idle when I take my foot off the gas.
