shizzon Samba Member
Joined: July 25, 2006 Posts: 596 Location: Boulder, CO
Posted: Thu Feb 02, 2012 10:49 am Post subject: How to remove headliner |
Hi
I want to remove the headliner from above the front seats in my westy. I can't seem to find a simple description of the removal process. Does one just unscrew it and it falls out, or are there any tricks to it? It kind of looked like one would need to remove the rail above the sink/stove area in order to get that corner of the headliner out.
thanks! _________________ 1989 Bostig Syncro Westy |
werksberg Samba Member
Joined: February 08, 2005 Posts: 2151 Location: Prescott Valley, AZ
Posted: Thu Feb 02, 2012 11:02 am Post subject: |
I take it the wood Westy head liner? Unscrew all screws, visor and anything else and bend / flex to get it out of the J rails on the sides. _________________ Werksberg Products....Products that work!
Follow my new products on my Facebook Werks Berg
Click the below ADs link for products & feedback.
Search "werksberg" on Photobucket for products photos & Please remember to buy "American made products!" |
madspaniard Samba Member
Posted: Thu Feb 02, 2012 12:01 pm Post subject: |
werksberg wrote: |
I take it the wood Westy head liner? Unscrew all screws, visor and anything else and bend / flex to get it out of the J rails on the sides. |
in my Westy, you need to remove screws in the front of the "J rails" too, at least in the one over the sliding door, there is a metal bracket in the front under the rail, screws go from the railk, throught the baccket and the bedliner and into the metal to support the rail. Look at the Bentley too. _________________ 1991 Westy auto w/ Peloquin TBD
"The only difference between me and a madman is that I'm not mad” - Salvador Dali |
Posted: Mon Feb 06, 2012 11:19 am Post subject: |
I don't know if it's wood or not, but I think so.
Does the rail over the sink/kitchen area need to be removed in order to remove the headliner, or is it really as simple as unscrewing everything and having it just drop down? _________________ 1989 Bostig Syncro Westy |
downshifting1984 Samba Member
Joined: September 28, 2017 Posts: 11 Location: Montréal QC
Posted: Thu May 24, 2018 6:21 am Post subject: Re: How to remove headliner |
Just pulled mine out of my 84 westy. just remove the rear facing trim, all screws and the gutter above the sink. and then you can gently pry it out, one side at a time...gently. good luck! |
Posted: Thu May 24, 2018 6:23 am Post subject: Re: How to remove headliner |
oh yeah, and pull out the driver-side light fixture and unplug the wires. unplug your batteries. |
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3803 Location: VA/TN
Posted: Thu May 24, 2018 7:42 am Post subject: Re: How to remove headliner |
What fabric/referbishing should you do while headliner is removed?
Maybe dynamat on roof? _________________ Brandon
Instagram @joannthevan |
Posted: Thu May 24, 2018 8:13 am Post subject: Re: How to remove headliner |
Well, my insulation was perfect, so all i am doing is scraping the chipped paint off my headliner and painting it. but lots of people have had mice living up there, so lots of cleaning and new insulation.
good luck on your project! |
