MConstable Samba Member
Joined: May 04, 2004 Posts: 1822 Location: Saint Charles IL
Posted: Tue Oct 31, 2017 5:16 am Post subject: Heater/defrost question |
Quick troubleshooting question....
I just replaced my heater box levers and put a new thermostat and flaps in (po just wired everything open), I have heat but no defrost, this one has me puzzled.
Thanks in advance |
mondshine Samba Member
Joined: October 27, 2006 Posts: 2769 Location: The World's Motor Capital
Posted: Tue Oct 31, 2017 9:07 am Post subject: Re: Heater/defrost question |
Take a look at this drawing...
Notice the little diverter flaps which are located inside the "Y tubes" under the rear seat bench. The flaps are operated by a cable connected to the lever closest to the driver's seat.
Here's a photo from the gallery:
Good luck, Mondshine |
Posted: Tue Oct 31, 2017 10:18 am Post subject: Re: Heater/defrost question |
Thanks for the quick reply.
Those flaps are working and I’m only getting heat out of one side.
On defrost mode the tube going from the floor to the dash used to get almost too hot to hold, not so anymore.
I’m thinking a disconnected heater hose or bellows or too much play in my heater box levers where they barrel clamp to the cabin cables? |
FV195 Samba Member
Joined: February 19, 2005 Posts: 480 Location: carlisile, pa
Posted: Wed Nov 01, 2017 4:07 pm Post subject: Re: Heater/defrost question |
Once you get heat flowing, you’re counting on fan speed to blow air, I added a 12v booster fan inline above the tunnel. It even pulls heat into cabin and will stand streamers up the windshild |
74 Thing Samba Member
Posted: Wed Nov 01, 2017 10:21 pm Post subject: Re: Heater/defrost question |
Got any photos? |
FV195 Samba Member
Posted: Thu Nov 02, 2017 7:29 am Post subject: Re: Heater/defrost question |
Not at this time, my car is in storage at the local navy base, I’ll try to get some ASAP, fan came with a 4 position switch, off low, med, high. Now it’s wired to a on off switch, high only |
Posted: Thu Nov 02, 2017 1:17 pm Post subject: Re: Heater/defrost question |
Pull things apart and get the mice nest out of there. Standard VW annual maintenance, should be shown in the manual as it is way more important than a lot of this they do tell you to do. |
