pilottangocharlie Samba Member
Joined: February 24, 2017 Posts: 83 Location: Newcastle, OK
Posted: Sun Nov 26, 2017 7:44 pm Post subject: Re: My First Beetle Project- 1964 |
Digger89L wrote: |
I'm thinking pilottangocharlie HAS to be a bachelor ....no wife would put up with abusing decent towels like those in the pics !! lol |
That is an actually a very old towel that somehow hasn’t been used on oil covered hands. It does have some holes though. |
Posted: Sun Nov 26, 2017 7:46 pm Post subject: Re: My First Beetle Project- 1964 |
Pruneman99 wrote: |
I bet the removable apron sure makes engine removal pretty easy. The car looks pretty solid except where you found the hole. Looks like tar? around it? I'd scrape it off to see how it looks underneath. |
It made engine removal very easy. It was the first one I had ever removed and took maybe 10 minutes. |
rcooled Samba Member
Joined: September 20, 2008 Posts: 2504 Location: Santa Cruz, CA
Posted: Sun Nov 26, 2017 9:03 pm Post subject: Re: My First Beetle Project- 1964 |
pilottangocharlie wrote: |
If anyone has a lead on a 1200 case/engine around number 79XXXXXX |
I have a 99% complete 1200cc motor (7311072) built in Nov. '62. This is a fresh-air motor as introduced by VW for the '63 model year. The motor ran pretty well when removed from the car but could use a rebuild (excess axial play at the crank pulley) and a good cleaning. PM me if you're interested.
_________________ '63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
'62, '63, '65, '69 Bugs (all long gone) |
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2922 Location: Memphis
Posted: Mon Nov 27, 2017 12:18 am Post subject: Re: My First Beetle Project- 1964 |
I'm looking forward to following your progress. Please don't let it stagnate in the garage as life moves on! _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
Posted: Mon Nov 27, 2017 9:15 pm Post subject: Re: My First Beetle Project- 1964 |
Soon after buying my Beetle I noticed the front shocks were mounted upside down. Anyone have any clues why someone would do this?
I shipped a big cap distributor I purchased through the classifieds out to Glenn to have a complete restoration done. I’m looking forward to seeing it get a new life in this car.
I’ve read good and bad about the AA P/C sets here, but didn’t really find any other options for the 40 horse 1200. I took advantage of a 20% Black Friday discount AA advertised on their site and ordered those. Once those arrive and I find a 6V flywheel and pressure plate I can get the case and parts sent out to a local shop I found that has done much work with VW engines. They will get the case machined to rebuild and everything balanced. Hopefully this will help in building a smooth and reliable running engine. _________________ Tyler |
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Mon Nov 27, 2017 10:04 pm Post subject: Re: My First Beetle Project- 1964 |
Start looking for end play shims now. Just gather whatever you can find. They are not being reproduced. NOS, using old ones that measure out, or creating your own are the only options. I got hung up on a 40 horse build for weeks looking for shims.
I'll be watching your progress as I just recently picked up a '64 sunroof car myself. |
raycer60 Samba Member
Joined: January 15, 2013 Posts: 167 Location: H Town Texas
Posted: Tue Nov 28, 2017 8:11 am Post subject: Re: My First Beetle Project- 1964 |
Soon after buying my Beetle I noticed the front shocks were mounted upside down. Anyone have any clues why someone would do this? |
To collect water samples?...lol
The installer did not care and had a 50/50 chance to get it right. Failed! At least that's an easy fix.
You are doing great progress. _________________ 59 De Luxe Sedan with grafted ragtop |
Posted: Tue Nov 28, 2017 1:10 pm Post subject: Re: My First Beetle Project- 1964 |
raycer60 wrote: |
You are doing great progress. |
They will eventually get swapped for new oil filled shocks so their current condition doesn't concern me too much. I can only imagine the effects of water being held in that cover have had over time.
The progress will slow a little as I get back to work after being on somewhat of a training break. The nice thing about finding parts online is I will still be able to get those coming and do the work on the days that I am at home. _________________ Tyler |
Posted: Tue Nov 28, 2017 1:20 pm Post subject: Re: My First Beetle Project- 1964 |
For anyone following along here with some experience with this, what are the advantages/disadvantages of going with the original style German pressure plate as opposed to the modern diaphragm type? I'm attempting to keep as much of the car as it was originally designed/built. Is this an obvious area where it only makes sense to install the newer style pressure plate? _________________ Tyler |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Tue Nov 28, 2017 1:51 pm Post subject: Re: My First Beetle Project- 1964 |
Is it an Aussie car? |
Posted: Tue Nov 28, 2017 1:58 pm Post subject: Re: My First Beetle Project- 1964 |
KTPhil wrote: |
I have no reason to believe it is. _________________ Tyler |
Posted: Tue Nov 28, 2017 4:28 pm Post subject: Re: My First Beetle Project- 1964 |
...what are the advantages/disadvantages of going with the original style German pressure plate as opposed to the modern diaphragm type? |
The diaphragm version will have a little quicker clutch take-up and require a bit less pedal pressure than the original coil-spring type.
BTW...the Aussie thing was only a joke _________________ '63 Ragtop (current)
vwfreek61 Samba Member
Joined: May 31, 2004 Posts: 350 Location: Green Bay, WI
Posted: Tue Nov 28, 2017 6:42 pm Post subject: Re: My First Beetle Project- 1964 |
Must have been a race car. There's less unsprung weight when they are mounted that way. Bilstein shocks are actually valved to run that way, but they have a rubber dust boot instead of the metal cover for the shaft. _________________ Kenneth
1964 Bug with Saxomat
1976 VW/Harley Trike Autostick
1987 Vanagon Westy w/Subaru EJ25 and reversed 4EAT |
Posted: Sat Dec 09, 2017 3:52 pm Post subject: Re: My First Beetle Project- 1964 |
Not many big items left to get the car completely stripped down.
I pulled the front brake lines out and removed the master cylinder along with the pedal assembly. I should be able to get the rear lines out this weekend as well.
The original fuel line wasn’t being used when I purchased the car, but I’d like to use it once the car is back together. I’m not sure if it was leaking or damaged somewhere in the tunnel, but that will be tackled once the body is off.
Posted: Tue Dec 12, 2017 11:02 am Post subject: Re: My First Beetle Project- 1964 |
There were a couple ads in the classified section here that I was watching as they were things I needed. I gave them a call and as it turned out he (R&D Engineering) was located at a little airport about seventy miles northeast of where I live. While browsing their website I discovered they also did general parts blasting/refinish. I loaded up some parts in the Cessna I needed to have done and was at his shop in twenty minutes or so. It was definitely an aircooled kind of day.
Doug at R&D Engineering showed me around their shop and I picked up a nice set of heater boxes and a refinished crank pulley for the 40 horse.
Doug texted this morning with a shot of the progress he made on the parts I dropped off yesterday.
Late last night the owner of a local VW body shop stopped by the house and we looked over the car and talked a little about what I wanted to have done. Looks like the body should be off and bare before the end of the year!! _________________ Tyler |
Posted: Wed Dec 13, 2017 7:09 pm Post subject: Re: My First Beetle Project- 1964 |
Today we towed “Louise” to the body shop. We pulled the doors off and got the body onto the dolly.
On the way we stopped by the blasting/powder coat shop and laid some plans for having the chassis cleaned up as well as powder coating the wheels. The best plan of action for the wheels was to blast them all bare then to powdercoat the entire wheel the light blue (L289) and then paint the inner wheel black.
For those that have painted their wheels, how is the paint holding up? My main concern is getting the light blue color correct. _________________ Tyler |
Posted: Sun Dec 17, 2017 11:17 am Post subject: Re: My First Beetle Project- 1964 |
Car is bare and pan and body work is soon to begin.
Posted: Wed Dec 27, 2017 11:16 am Post subject: Re: My First Beetle Project- 1964 |
An update on where the project is at. The chassis was brought back to the garage to begin assembly with new/restored parts.
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6595 Location: Houston, Texas
Posted: Wed Dec 27, 2017 5:20 pm Post subject: Re: My First Beetle Project- 1964 |
Nice 64. More people should buy them.
You have an airstrip in your back yard? I've seen a few communities with them. _________________ www.vwnos.com [email protected]
Posted: Thu Dec 28, 2017 10:18 pm Post subject: Re: My First Beetle Project- 1964 |
kawfee wrote: |
You have an airstrip in your back yard? I've seen a few communities with them. |
I wish I had the runway in the back yard. Maybe in a decade or so that will be true, but for now I drive the Rabbit down to the hangar. _________________ Tyler |
