Bluggy Samba Member
Joined: September 12, 2017 Posts: 151 Location: Caribbean
Posted: Thu Nov 02, 2017 5:47 pm Post subject: Shortening steering column |
Hi Guys, I have read a bit here and did not come up with much of a solution.
Is there a practical way of shortening the steering column? I have not taken off my tub as yet, but it seems as though there are two collapsible sections on mine.
Looking at my column bearing section, it could be easily remounted lower (shorter) if i had a shorter steering column, has anyone every tried cutting and welding the column? I will have mine realigned dead straight before welding/joining.
I would like to shorten the steering maybe by 2 inches or so which will lower it too.
Thanks.
Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5305 Location: Central Florida
Posted: Thu Nov 02, 2017 6:16 pm Post subject: Re: Shortening steering column |
One of the POs on mine just cut and welded it. Think they may have been drunk when they did it as it’s not particularly straight. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine |
Bluggy Samba Member
Posted: Thu Nov 02, 2017 7:05 pm Post subject: Re: Shortening steering column |
Sharp64 wrote: |
One of the POs on mine just cut and welded it. Think they may have been drunk when they did it as it’s not particularly straight. |
Man there are butchers doing botch jobs everywhere, the worst I have seen is when kids with no mechanical or electrical knowledge buys a car to "fix up" and sell
You might want to cut and re-weld or is it not that bad that it affects the rubber coupling?
I will look at mine when the tub is off, I will check to see if there is any badly rusted part to cut off. I am a bit tall and have taken out the bare fiberglass seats it had, replacing them with Sparcos. My buggy has the 2 seater short tub so no room to move the seats further back, necessitating shortening and lowering of the steering column.
Cheers and thanks for the reply. |
Posted: Thu Nov 02, 2017 7:10 pm Post subject: Re: Shortening steering column |
Unfortunately I haven’t learned to weld yet. Plan is to start gathering welding equipment after the beginning of the year hopefully and trying my hand at it. Not sure if it affects it or not. It’ll be something I address at some point. Finding a few issues that have to be done. Bit by bit. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
Bluggy Samba Member
Posted: Thu Nov 02, 2017 7:16 pm Post subject: Re: Shortening steering column |
If has a fair amount of wobble it might add some stress to the steering rubber coupler. As for welding, you should try out a MIG welder. Most huge retailers or service guys will give you some practice and demo, but MIG welding is faily easy.
If you do, try using solid wire with Co2 or Argo Sheild 75% Argon/25% Co2. There are lots of great tutorials online and people always willing to teach, do pay all the attention to safety and protection.
I currently have a Millermatic 211 with spool guns for aluminum. You can buy used as well from reputable sellers with warranty.
Cheers. |
Bluggy Samba Member
Posted: Thu Nov 02, 2017 7:48 pm Post subject: Re: Shortening steering column |
Cool. I welded with gas enough in high school to pass shop but that’s about it. And that was 3 decades ago. I’ll most likely just start out with something like an Eastwood and if I need to upgrade at some point cross that bridge then. I’ll buy a lot of things used but welding equipment is out if my wheelhouse so I’d rather buy new knowing at least I’m getting something that’s complete. I’ll check the vids out.[list=][/list] _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20365 Location: Just a tiny bit west of Yosemite Valley
Posted: Thu Nov 02, 2017 7:55 pm Post subject: Re: Shortening steering column |
This guy is as good or better then Chuckie....
http://weldingtipsandtricks.com
slalombuggy Samba Member
Posted: Thu Nov 02, 2017 9:49 pm Post subject: Re: Shortening steering column |
Your steering shaft is what links you to control of your car, it isn't the place to practice welding.
I have shortened columns before. I cut the length I want out of the column. I then drill 2 - 1/4" holes 90* from each other about an inch apart 2" up from the cut on both pieces. I also grind a taper on the cut ends for better penetration. Then I drive in a rod that is a tight fit inside the shaft to keep it straight. I then button weld the column through the 1/4" holes as well as the joined shafts ends.
brad |
Bluggy Samba Member
Posted: Fri Nov 03, 2017 5:51 am Post subject: Re: Shortening steering column |
slalombuggy wrote: |
Your steering shaft is what links you to control of your car, it isn't the place to practice welding. brad |
I dont think he would have done that Brad
brad |
That's a great technique Brad, ensuring its straight and button welded to hold it straight until its welded. This will also ensure that the metal does not pull out of position with the heat while welding. The inner rod/tube will help to reinforce the joint too.
I will put mine on a lathe with two steady rests, cut and weld on the lathe then machine the weld bead to a uniform finish.
I like your technique though, thats great...will note and save that.
Bluggy Samba Member
Posted: Fri Nov 03, 2017 5:54 am Post subject: Re: Shortening steering column |
He is good too Dale, I like his vids, he covers everything professionally.
Cheers. |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16754 Location: State College, PA
Posted: Fri Nov 03, 2017 9:56 am Post subject: Re: Shortening steering column |
If you can use an early style (non collapsible) center shaft, there is no welding needed. Just cut it to length, grind the slot and the detent for the bolt. BUT not sure what you will run into at the bearing end at the top. BUT in general, an early style column/switch assembly looks cleaner IMHO anyway. Ponder that.
And assuming you have a collapible now, the wobble is most likely due to the collapsible section being bent.
Now - real important. A lot of times the steering column angle is different than stock. What you want to do is change the steering box angle to line up better so you are not stressing the hell out of the steering coupler. However, I would not nail that down until you determine if you are using caster shims on the beam. Same deal, adding those will change the angle. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Fri Nov 03, 2017 11:11 am Post subject: Re: Shortening steering column |
Your steering shaft is what links you to control of your car, it isn't the place to practice |
Easy big guy. No where did I say I was going to practice on my steering shaft. Mines actually the earlier type so not sure why someone welded it to begin with as Andys idea makes more sense.
Back on topic. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
KAmes Samba Member
Joined: February 16, 2014 Posts: 876 Location: Illinois
Posted: Fri Nov 03, 2017 5:00 pm Post subject: Re: Shortening steering column |
I chose to weld mine like this.
I just tacked it in one spot, then carefully manipulated it frequently rechecking with a straight edge. When satisfied I welded it up. Yes that is two different diameters/years/models welded together. |
Bluggy Samba Member
Posted: Fri Nov 03, 2017 7:56 pm Post subject: Re: Shortening steering column |
Thanks for the info and pic guys, noted all.
Cheers. |
JiI Samba Member
Joined: February 18, 2006 Posts: 1844 Location: Michigan
Posted: Thu Nov 16, 2017 11:47 am Post subject: Re: Shortening steering column |
I cut , drilled 2 holes in each end, sleeved a piece inside, put them together, welded through the holes and then around the two pieces. Pretty solid.
Jeff |
joescoolcustoms Samba Member
Posted: Thu Nov 16, 2017 12:56 pm Post subject: Re: Shortening steering column |
andk5591 wrote: |
If you can use an early style (non collapsible) center shaft, there is no welding needed. Just cut it to length, grind the slot and the detent for the bolt. |
I have done that several times on buggies. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Bluggy Samba Member
Posted: Fri Nov 17, 2017 1:54 pm Post subject: Re: Shortening steering column |
Thanks for all the replies and input guys. i am now doing the repairs/mods to the body after which, the roll cage and tub will be taken out.
There is a lot of work to be done to the chassis etc., just wish I was back in Canada to just order and replace everything I possibly could. |
