CV Axle Pop after Raising any ideas?
DrVW
DrVW is offline
PostPosted: Fri Sep 16, 2016 11:40 am    Post subject: CV Axle Pop after Raising any ideas? Reply with quote
So what do you do if you've rsised your thing and the CV's pop. You like the way it sits and would rsther not have to lower it. Is there a bolt on fix??
Gas prices killing you too? A VW Bug still holds up to today's cars with it's awesome gas mileage!
View user's profile Send private message Send e-mail Visit poster's website Facebook Twitter Classifieds Feedback
Shoyrtt
Shoyrtt is offline
PostPosted: Fri Sep 16, 2016 4:42 pm    Post subject: Re: CV Alxe Pop after Raising any ideas? Reply with quote
I have a set of these spacers on the transmission side of one of my cars. Maybe it will help with the binding on your car. I guess it just depends on how severe of an angle you are running.
http://www.pacificcustoms.com/ac501920gr.html
Edit: Also this is a good thread on various types of CVs you might want to look into:
http://www.thesamba.com/vw/forum/viewtopic.php?t=579678&highlight=cv+binding
It's a play thing
It's a play thing is offline
PostPosted: Fri Sep 16, 2016 7:57 pm    Post subject: Re: CV Axle Pop after Raising any ideas? Reply with quote
The fix is 930 cvs, what has happened is you have to much angle in the CV joint. you can lower the car or install new CV's.
It's not the size of your shop, it's what comes out of it that counts.
I've been playing with my thing ever since I got it...
kubelmann
kubelmann is offline
PostPosted: Fri Sep 16, 2016 8:44 pm    Post subject: Re: CV Axle Pop after Raising any ideas? Reply with quote
Play Thing offers good advise and here are the numbers that support his help
Degrees of non binding articulation.
Type 1 is 12 degrees
Type 2 is 17 degrees
Type 4 is 22 degrees
930 is 25 degrees
Diameter of CV
Type 1 = 94mm
Type 4 = 100mm
Type 2 = 100mm
930 = 108mm
It's a play thing
PostPosted: Fri Sep 16, 2016 9:00 pm    Post subject: Re: CV Axle Pop after Raising any ideas? Reply with quote
Great add-on, very helpful, thanks
kubelmann
PostPosted: Fri Sep 16, 2016 9:12 pm    Post subject: Re: CV Axle Pop after Raising any ideas? Reply with quote
Thanks... Glad its useful.. I have jsut been helping a few folks decide how to rig their various rear suspension to gain the best combo for their desired use.
Bus/Type 2 (100mm) Thing/Type4 (100mm)
Although the Type 2 and 4 Cvs have the same diameter the type 4 gains 5 degrees of articulation due to using a larger inner CV knuckle and smaller CV balls Hence the best reason to not use type 2 CVs on a Type 4 vehicle.
DrVW
DrVW is offline
PostPosted: Sat Sep 17, 2016 10:43 pm    Post subject: Re: CV Axle Pop after Raising any ideas? Reply with quote
Lowered the back popping stopped. Ill live with it. Thanks for the useful info.
limon
limon is offline
PostPosted: Sun Nov 12, 2017 9:46 am    Post subject: Re: CV Axle Pop after Raising any ideas? Reply with quote
I installed an imported axle/CV combo thinking I'd stay cleaner and have some spare parts too.
The new axle/CVs were binding horribly (I've raised my Thing one "tooth" on the spring plates).
Bought a Rockford boot kit from a type 2 supplier and reinstalled my originals so now everything is fine.
Inspecting the Chinese axle; it wasn't indexed correctly when it was assembled, I don't know if reindexing will fix the binding, or if the knockoffs just can't handle the same angles as originals.
