r1ver_rat Samba Member
Joined: February 27, 2015 Posts: 72 Location: United States
Posted: Fri Nov 03, 2017 10:26 am Post subject: 1964 13 window 240hp rwhp dyno pull |
56reddy Samba Member
Posted: Fri Nov 03, 2017 2:08 pm Post subject: Re: 1964 13 window 240hp rwhp dyno pull |
Very nice. That engine sounds smooth. _________________ New Vintage Specialist.
1974 ghia convertible
1981 Vanagon Westfalia
Making VW’s Fun Again.(MVFA) |
Posted: Fri Nov 03, 2017 2:24 pm Post subject: Re: 1964 13 window 240hp rwhp dyno pull |
56reddy wrote: |
Very nice. That engine sounds smooth. |
Thanks Brother!!! |
AndrewS85 Samba Member
Posted: Fri Nov 03, 2017 8:52 pm Post subject: Re: 1964 13 window 240hp rwhp dyno pull |
Awesome bus bro! |
Posted: Fri Nov 03, 2017 9:17 pm Post subject: Re: 1964 13 window 240hp rwhp dyno pull |
AndrewS85 wrote: |
Awesome bus bro! |
Thanks Bro!!! Much appreciated |
Rustyscrew Samba Member
Posted: Sat Nov 04, 2017 4:52 am Post subject: Re: 1964 13 window 240hp rwhp dyno pull |
Awesome I love it. Any pics? |
Skim Rants Master
Joined: April 15, 2001 Posts: 17082 Location: GFK 31 Year Vet
Posted: Sat Nov 04, 2017 5:40 am Post subject: Re: 1964 13 window 240hp rwhp dyno pull |
This bus is killer. Those 16x8's in the back are the shit! I love it. _________________ GFK
1953 Kabriolet
1954 Sunroof
1959 Lowlight Ghia vert
1963 Deluxe Turkis Walk Thru 15 Window OG Paint |
Posted: Sat Nov 04, 2017 6:38 am Post subject: Re: 1964 13 window 240hp rwhp dyno pull |
Rustyscrew wrote: |
Thanks Brother!. Look up on Instagram R1ver_rat bunch of pics there. Here are a couple
Posted: Sat Nov 04, 2017 6:41 am Post subject: Re: 1964 13 window 240hp rwhp dyno pull |
[quote="Skim"]This bus is killer. Those 16x8's in the back are the shit! I love it.[/quote
Thanks Brother! Good eye with picking out the 16x8's. You're the first to know the size by looking at them. Had to narrow the rear end 1 1/2" on each side to get them to fit. |
Braukuche Samba Member
Posted: Sat Nov 04, 2017 8:50 am Post subject: Re: 1964 13 window 240hp rwhp dyno pull |
Very cleanly done, like how it's all packed in there giving a slightly modified look to it. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Posted: Sun Nov 05, 2017 11:34 am Post subject: Re: 1964 13 window 240hp rwhp dyno pull |
Braukuche wrote: |
Very cleanly done, like how it's all packed in there giving a slightly modified look to it. |
Thanks Brother!! |
GLHTurbo Samba Member
Joined: March 30, 2009 Posts: 1376 Location: New Jersey
Posted: Sun Nov 05, 2017 5:47 pm Post subject: Re: 1964 13 window 240hp rwhp dyno pull |
sweet bus, nice pull. What's the specs on the engine/turbo? _________________ 1957 Beetle
1966 Bus |
Posted: Mon Nov 06, 2017 7:52 pm Post subject: Re: 1964 13 window 240hp rwhp dyno pull |
GLHTurbo wrote: |
sweet bus, nice pull. What's the specs on the engine/turbo? |
Thanks Brother! It's a 2180cc auto lines aluminum case with 10mm studs, SIR cam,
5.4 H Beam VW rods, forged 92mm thick bore piston 94/94, Steve Timms stage 2 heads with turbo prep, 1.25 rockers, 6550 valve springs, CB Performance crank trigger, Garrett T3/T4 Hybrid turbo. 15lbs boost, Holley 570cfm carb, Kennedy stage 2 clutch. |
Posted: Sun Nov 12, 2017 4:13 pm Post subject: Re: 1964 13 window 240hp rwhp dyno pull |
NUTSFORBUSES Samba Member
Joined: December 08, 2016 Posts: 560 Location: I don't recognize it anymore
Posted: Mon Nov 20, 2017 10:54 pm Post subject: Re: 1964 13 window 240hp rwhp dyno pull |
WHO screwed that together for you? How do you cool it? _________________ kaiser kills kids.com |
Posted: Tue Nov 21, 2017 12:08 am Post subject: Re: 1964 13 window 240hp rwhp dyno pull |
NUTSFORBUSES wrote: |
WHO screwed that together for you? How do you cool it? |
Screwed?? Was a collaboration of people in the industry. But to keep it cool I'm running a 1 1/2 quart deep sump, run Amsoil 20/50 Synthetic V Rod oil which is high in Zinc. Also running the doghouse cooler with an external oil cooler with an electric fan set 160°. Ran in in Los Angeles traffic about 60 miles 1 way and no heating issues. Under low speeds your never in boost and with a lower CR to run boost you are running cooler than a carved motor under vacuum. |
Posted: Tue Nov 21, 2017 7:51 am Post subject: Re: 1964 13 window 240hp rwhp dyno pull |
Just stunning job! Love the color too, same as my 21.
About the boost, does it come-on like a tornado, or gradual (The hybrid Turbo?) I had a Turbo Porsche, it was nothing like the newer ones, it just came-on so fierce, it was hard to control. _________________ kaiser kills kids.com |
Posted: Wed Nov 22, 2017 12:40 pm Post subject: Re: 1964 13 window 240hp rwhp dyno pull |
About the boost, does it come-on like a tornado, or gradual (The hybrid Turbo?) I had a Turbo Porsche, it was nothing like the newer ones, it just came-on so fierce, it was hard to control. |
Thanks for the love!! As for the boost, if I just floor it you get a that noticeable lag then the tornado effect you talked about. Of you are gradual it's not that bad. For most everyday driving I'm barely in boost as you can see on this graph when I start to make boost and when it told out at 15.5lbs
Posted: Wed Nov 22, 2017 12:52 pm Post subject: Re: 1964 13 window 240hp rwhp dyno pull |
Here on the dyno pull you can see how the motor makes its power from when the boost kicks in.
