Danwvw Samba Member
Posted: Sun Nov 05, 2017 12:52 pm Post subject: Zenith Manifolds vs Weber DCNF manifold for Zenith NDIX 32 Carbs |
I can find a few ad's for Vintage Scat DCNF Manifolds but none for a pair of real Zenith 32 VW manifolds.
What is the difference? I have been reading and know the angle is a little different but I think the Zeniths would clear the fan housing ok on the DCNF manifolds but when I measure my Zenith Carburetor NDIX 32 carb base I get slightly different measurements. Has anyone ran them? Will they work?
Zenith Gaskets
(DCNF Gasket) vs (Zenith Base)
85mm--------------83.5mm = 1.5mm mismatch?
52mm--------------48mm = 5mm mismatch?
Classic Carbs DCNF Gasket:
Zenith NDIX 32 P010 Base
_________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Jacks Samba Member
Joined: July 15, 2006 Posts: 2348 Location: San Clemente, Ca.
Danwvw Samba Member
Posted: Mon Nov 06, 2017 3:55 pm Post subject: Re: Zenith Manifolds vs Weber DCNF manifold for Zenith NDIX 32 Carbs |
Thanks Jack, I saw those. The SS ones and Scat linkage with the carbs look ideal but I already have carbs and linkage. That is a good deal though! Any input on DCNF manifolds? I'ed get these if they work on both type of carbs, Be fun to try the DCNF carbs too. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Jacks Samba Member
Posted: Mon Nov 06, 2017 11:04 pm Post subject: Re: Zenith Manifolds vs Weber DCNF manifold for Zenith NDIX 32 Carbs |
Port matching at both ends of the manifold matters. _________________ Jack Staggs
Actual name |
Danwvw Samba Member
Jacks Samba Member
Posted: Wed Nov 08, 2017 1:07 am Post subject: Re: Zenith Manifolds vs Weber DCNF manifold for Zenith NDIX 32 Carbs |
Those Splat ones look like a better match _________________ Jack Staggs
Actual name |
Danwvw Samba Member
Lowlightmafia Samba Member
Posted: Mon Mar 11, 2019 1:35 pm Post subject: Re: Zenith Manifolds vs Weber DCNF manifold for Zenith NDIX 32 Carbs |
Did the DCNF manifolds fit the carbs base properly? |
Danwvw Samba Member
Posted: Mon Mar 11, 2019 2:05 pm Post subject: Re: Zenith Manifolds vs Weber DCNF manifold for Zenith NDIX 32 Carbs |
The Gasket Holes are 34mm, Zenith Carb 32mm, Scat Weber DCNF Manifolds flare to 40mm at carb end. Carb-Manifold, It leaves .75mm ledges on the inside edges only of the Scat DNNF manifolds.
