SSWesty Samba Member
Joined: August 20, 2008 Posts: 732 Location: Bellevue
Posted: Thu Nov 09, 2017 1:12 pm Post subject: Re: Prototyping Vanagon Aero Wing |
pingora - You move at a much faster pace than I do on my projects. I am curious how your first test will go. There is a get to together up here in Seattle this Sunday. It would be pretty cool if you showed up with that wing on the back of your van. |
mellowslow Samba Member
Joined: July 31, 2009 Posts: 278 Location: Vacationland
Posted: Thu Nov 09, 2017 2:13 pm Post subject: Re: Prototyping Vanagon Aero Wing |
Abscate wrote: |
The naysayers on mods like this are usually (>95%) correct...stuff like this... |
There is an automotive subculture of naysayers that is built around this very subject
https://www.google.com/search?q=shopping+cart+wing...01#imgrc=_ _________________ '87 WBWE FAS Gen V |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Thu Nov 09, 2017 3:06 pm Post subject: Re: Prototyping Vanagon Aero Wing |
Abscate wrote: |
Quote: |
That van with the bustle belonged to Bob Parsons who had also closed the top of the luggage rack. He achieved 28 mpg on the high plateau in New Mexico. |
doesn't help your case. If you think aerodynamics on a car will lift you from 20 to 28 mpg, carry on.
My case? And speaking ill of the dead is pretty bush league, professor. _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
Pingora Samba Member
Joined: September 10, 2017 Posts: 50 Location: Portland
Posted: Thu Nov 09, 2017 5:00 pm Post subject: Re: Prototyping Vanagon Aero Wing |
I may move somewhat fast, but not fast enough for this weekend! Maybe if I didn't have a normal job.... _________________ 1990 Vanagon Carat
2002 Suby 2.5 Mizu Bokusa
17" wheels, 26.5" diameter tires |
Merian Samba Member
Posted: Fri Nov 10, 2017 12:08 pm Post subject: Re: Prototyping Vanagon Aero Wing |
newly minted PhDs are supposed to be ineducable, not ones still working on a degree
nonetheless, I wish you good luck _________________ .... |
Abscate Samba Member
Posted: Fri Nov 10, 2017 12:33 pm Post subject: Re: Prototyping Vanagon Aero Wing |
Jake de Villiers wrote: |
Abscate wrote: |
My case? And speaking ill of the dead is pretty bush league, professor. |
One of the Bush' died? I missed that. Is that right? Or should it be Bussh' like busses' _________________ .ssS! |
Posted: Sat Nov 11, 2017 12:45 pm Post subject: Re: Prototyping Vanagon Aero Wing |
Abscate wrote: |
Abscate wrote: |
One of the Bush' died? I missed that. Is that right? Or should it be Bussh' like busses' |
No, Bob Parsons the Vanagon aero guy.
https://localwiki.org/denton/Robert_Carroll_Parsons _________________ '84 Vanagon GL 1.9 WBX
Posted: Sat Nov 11, 2017 6:26 pm Post subject: Re: Prototyping Vanagon Aero Wing |
The Dacron is all on, time to work on the side fairings...
pinetreeporsche Samba Member
Joined: June 11, 2009 Posts: 752 Location: Falls Church, VA
Posted: Sun Nov 12, 2017 7:31 pm Post subject: Re: Prototyping Vanagon Aero Wing |
Pingora wrote: |
0 Carat which has the front air dam. ... Also have you noticed that almost every boxy modern minivan or SUV has some sort of rear spoiler/wing/whateveryouwantacallit? |
I just today saw a very sharp looking rear spoiler on a very recent model Subaru Outback. Whether it would improve our gas mileage can only be established by mounting it or a similar one on one of our vans for testing/data collection. |
Posted: Tue Nov 14, 2017 2:15 pm Post subject: Re: Prototyping Vanagon Aero Wing |
I think I saw the spoiler you are talking about on a newer Outback as well while I was going for a run. It looks really similar to the one I saw on a Lexus. It looks to me a very similar working principle to the one I'm trying out. The underside scoops in a downward direction to draw air down the backside instead of it separating. I think the wing design I'm working with is a more exaggerated version of it, that would of course never fly (har har) on a production model SUV. _________________ 1990 Vanagon Carat
Posted: Thu Nov 16, 2017 11:53 am Post subject: Re: Prototyping Vanagon Aero Wing |
I had a chance to test fit the wing. My marine epoxy hasn't arrived so it's not waterproof yet, but I was able to back it in to the shop at work briefly to get the rear out of the rain. It fits almost perfect. It has aluminum angle with gasket that gets compressed by the hatch, and the wood sides get pushed against the back of the car. Those will have gasket as well.
I bet that the height it sits above the back will be pretty critical, but I could be wrong. As it is, it looks like it sits high, but it's still lower than the high point on the van, so no added frontal area. I'll be able to adjust this as needed.
Once I get the epoxy I can finish it and make the sides more permanent and it should be sturdy enough after that for a test run.
Posted: Thu Nov 16, 2017 2:36 pm Post subject: Re: Prototyping Vanagon Aero Wing |
Jake,
I think it's supposed to snag that flow, before it gets turbulent and direct it down to energize the air on the underside. I'll find out though!
D _________________ 1990 Vanagon Carat
dobryan Samba Member
Joined: March 24, 2006 Posts: 16508 Location: Brookeville, MD
Posted: Thu Nov 16, 2017 3:27 pm Post subject: Re: Prototyping Vanagon Aero Wing |
I guess I didn't quite mean laminar flow. I'm thinking "smooth-ish" flow, as compared to the giant wake that starts to happen after tripping off the back end usually.
Plus you always have to think of the entire flow as one cohesive unit. Changing part of the shape might very well cause laminar flow or different flow further upstream. If I remember right from fluid dynamics class the only time this can't happen is in supersonic flow, since there's no time for the flow downstream to effect the flow upstream. _________________ 1990 Vanagon Carat
Posted: Fri Nov 17, 2017 8:41 am Post subject: Re: Prototyping Vanagon Aero Wing |
Pingora wrote: |
Jake,
D |
Okay, I get it.
I remember Bob Parsons saying not to think of the Vanagon as too tall for its length but rather not long enough for its height! _________________ '84 Vanagon GL 1.9 WBX
furrylittleotter Samba Member
Joined: May 19, 2008 Posts: 1506 Location: West Seattle
Posted: Mon Nov 20, 2017 9:31 pm Post subject: Re: Prototyping Vanagon Aero Wing |
Pretty fun project. You are correct the tapered tale that I put on my van completely illuminated crosswind interference with handling. Somebody claimed that there were no jetties off the back of a vanagain. I cannot think of a more ridiculous statement to make. Just because they’re not pictured in the aerodynamic photograph does not mean they don’t exist. Also the idea that the front end cannot be helped with an aerodynamic fixture is ludicrous. I fitted one and the results were dramatic. Unfortunately I never got past making the test model. Enjoy your project I think it looks cool looks kind a bat like. Id paint it black. And yes the naysayers are still on here in full force. I see the safety patrol even stopped by. welcome to thesomber, er I mean thesamba😏
Neil2 |
Posted: Tue Nov 21, 2017 5:24 am Post subject: Re: Prototyping Vanagon Aero Wing |
I think the impact is dramatic , it's just the topic of the drama might be different.
You won't get 40% improvement in economy as alluded to above, given that aero forces are at max 30% of total at highway speeds. Math is kind of cool thing that way.
Impressive workmanship on that fairing, that takes talent to work materials like that. _________________ .ssS! |
OddN Samba Member
Joined: August 19, 2010 Posts: 690 Location: Northern Norway
Posted: Tue Nov 21, 2017 6:34 am Post subject: Re: Prototyping Vanagon Aero Wing |
Have you made some calculations on what amount of lift that will create on the rear wheels? Too much lift in the rear would result in some interresting (=dangerous) handling. _________________ 1991 VW Multivan syncro 1,9 TD |
