Big Wave Dave69 Samba Member
Joined: November 07, 2017 Posts: 9 Location: FOLSOM, CALIF
Posted: Tue Nov 07, 2017 3:07 pm Post subject: 61 VW Buggy rebuild Alameda body |
Decided to sell my custom Harley Davidson and buy a Dune Buggy, since it has been 40 years since my last one. Everything I was looking at was rusted and put together in the most "back yard" fashion. I found one tht caught my eye in Ceres, Calif but needed some work. Well, a lot of work. But it wasn't until we got into it that we found all the rust and that fact the frame had about 2 inches of weld left before it would crack in half. Thus, the build begins. I will get some pictures and if you have some ideas I may have not thought of, feel free to chime in. I can't wait to get it done. And don't let the paint and pics fool you (it did me). When I got to see it, the paint had been rolled on with a interior roller for house paint!!!! It was trashed.
[/img] |
gtrplyr Samba Member
Joined: November 10, 2014 Posts: 101 Location: kansas
Posted: Tue Nov 07, 2017 4:46 pm Post subject: Re: 61 VW Buggy rebuild Alameda body |
Looks like a real good start, some start with much less! Keep us posted with your progress. |
Posted: Wed Nov 08, 2017 4:10 pm Post subject: Re: 61 VW Buggy rebuild Alameda body |
We puled the body off and found more rust than we expected. But the worst part was the frame welds where they put it together. It was a hack job and had cracked all around, except for maybe 2 inches holding the buggy together. We cut it out, made new 1/4 inch plates, got rid of all the rust, and pulled the pans completely. We now have new pans in, undercoating, new painted floors, custom seats and mounts, etc. Feel like at this pace we may have it done in 3 months!!! More pics to follow.
BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6767 Location: Northern California
Posted: Wed Nov 08, 2017 5:19 pm Post subject: Re: 61 VW Buggy rebuild Alameda body |
You are totally transforming that buggy. Very impressive! It should be done for the Manx Club run at Lone Pine next October.
They have parking brake brackets you can weld into your tunnel. Also make sure the parking brake cable guide tubes are all in place.
http://www.acmecarco.com/berrien-buggy/fabrication-station
Also while the body is off, make sure the clutch cable guide tube anchor brackets and welds are all solid. Its a lot harder to repair once the body is on.
You should put an adjuster on the end of the shift rod. It makes adjusting your shifter simple and precise. Its the best $10 upgrade you can make |
Posted: Fri Nov 10, 2017 9:33 am Post subject: Re: 61 VW Buggy rebuild Alameda body |
Just put on the tires and rims to check for fit. Also, used Polaris RZR seats so they would be comfortable and could adjust back and fourth.
Posted: Thu Feb 22, 2018 4:27 pm Post subject: Re: 61 VW Buggy rebuild Alameda body |
hillmotorsports Samba Member
Joined: December 27, 2014 Posts: 432 Location: Morrisburg, Ontario, Canada
Posted: Thu Feb 22, 2018 10:16 pm Post subject: Re: 61 VW Buggy rebuild Alameda body |
What brand/size are the rear tires? On what size rim?
Love the cage reinforcement ad rear bumper, esp the license plate mount.
Paul _________________ Rosemarie and Paul Hill
Morrisburg, Ontario
(With way more projects than spare time!) |
BIGMIKEY Samba Member
Joined: September 24, 2007 Posts: 1105 Location: North East Pennsylvania
weasel_ugs Samba Member
Joined: March 16, 2012 Posts: 721 Location: Prescott Valley,Az.
Posted: Fri Feb 23, 2018 6:19 pm Post subject: Re: 61 VW Buggy rebuild Alameda body |
BIGMIKEY wrote: |
Cool directional Vee tread pattern on those tires.
Mike T |
Check for arrows on the sidewall, they might need to be changed from side to side. |
cdnltded Samba Member
Joined: March 13, 2015 Posts: 381 Location: Pincher Creek, Alberta
Posted: Fri Feb 23, 2018 10:16 pm Post subject: Re: 61 VW Buggy rebuild Alameda body |
And you might get more power if you get ride of those dual trumpets.
But with that fancy rear bumper you might not be able to |
LesbleuBuggy Samba Member
Posted: Mon Feb 26, 2018 12:10 am Post subject: Re: 61 VW Buggy rebuild Alameda body |
That's a mean looking back end |
Posted: Mon Mar 12, 2018 8:35 am Post subject: Re: 61 VW Buggy rebuild Alameda body |
Here are the latest pics. From what was about as much of a basket case to what this will actually be (with all the fabrication), it should be one hot street machine. Stroker motor is being built as we speak!!! This is my new dash and rear enclosure for storage and stereo speakers. Both will be covered with black vinyl to match the seats.
Posted: Mon Mar 12, 2018 8:37 am Post subject: Re: 61 VW Buggy rebuild Alameda body |
And the exhaust will be built to support the horse power when we get the new motor in. Just need to figure out what works and the look we like. |
Posted: Mon Aug 06, 2018 2:44 pm Post subject: Re: 61 VW Buggy rebuild Alameda body |
Car will be done in about a month. Taken over a year, most items hand built, and will be going to Bug O Rama (I Hope) with it. Pics will come up soon. |
Posted: Mon Aug 06, 2018 2:49 pm Post subject: Re: 61 VW Buggy rebuild Alameda body |
Also, pulled the stock 1600 motor, even though it ran great and has a cam (dual port), but bought a brand new 2110 Stroker Motor to move those rear tires. |
Posted: Mon Aug 06, 2018 2:59 pm Post subject: Re: 61 VW Buggy rebuild Alameda body |
mcdoc2000 Samba Member
Posted: Sun Aug 12, 2018 6:01 pm Post subject: Re: 61 VW Buggy rebuild Alameda body |
Looks great, hope to see it at the Bugorama |
