Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22410 Location: Kimball, Mi
Posted: Wed Aug 07, 2019 10:31 am Post subject: Re: Hello new Square!!!! |
oxsign wrote: |
Ok so, I did the jumper thing on the sending units on the MC and not brake lights. I checked the “bridge/jumper” at the back by the motor and still no brakes. I do have tail lights, turn signals, hazards, and reverse lights. I just don’t have any brake lights. Fuses all are good and making proper contact.
I guess the next thing would be to try and chase the wire(s) and see if there’s a brake in there somewhere?? |
Do you have power (12V) on the black wire? If not, you won't get brake lights. You can also jump the switch, and see if you have power on the black w/red stripe wire going to the rear of the car (for the brake lights). There's a 3 way connector under the cardboard just under the brake rez, that you can check for power (MUST have the key on).
Look at the fuse box to make sure you don't have a blown fuse. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
oxsign Samba Member
Joined: February 19, 2006 Posts: 607 Location: Sanford, FL
Posted: Wed Aug 07, 2019 3:00 pm Post subject: Re: Hello new Square!!!! |
Bobnotch wrote: |
oxsign wrote: |
Look at the fuse box to make sure you don't have a blown fuse. |
I'll have to check power to the blk wire.
I'm not familiar with the 3 way connector but I'll look for that as well.
Fuses I went through and replaced all the "bad" ones. I will look behind the fuse panel though and see if there is anything that looks out of place there as well.
Thanks for the things to look for. I'm off tomorrow and i'll be tackling that. _________________ 1971 Squareback, fully bagged, 1776.
Build thread here.....
https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34002 Location: Conejo Valley, CA
Posted: Wed Aug 07, 2019 4:17 pm Post subject: Re: Hello new Square!!!! |
oxsign wrote: |
I'm not familiar with the 3 way connector but I'll look for that as well. |
I went years without knowing about that connector. It was used to aid assembly in the factory, but today it makes a damn convenient check point when troubleshooting those circuits! |
oxsign Samba Member
Posted: Wed Aug 07, 2019 4:36 pm Post subject: Re: Hello new Square!!!! |
KTPhil wrote: |
oxsign wrote: |
Yup, first i've heard about it honestly and I did a search too, lol. That's where I read about using a jumper between the sending units at the MC. Never thought of that either. It's definitely a good place with good people to trouble shoot with, lol. _________________ 1971 Squareback, fully bagged, 1776.
KTPhil Samba Member
Posted: Wed Aug 07, 2019 5:03 pm Post subject: Re: Hello new Square!!!! |
There is such a gawdawful Medusa's Head of wiring under the left dash inside (my least favorite part of the Type 3 design), so having easy access to those circuits in the frunk makes finding an open or short so much easier. Otherwise you pull two more wires loose while pulling one on the inside to get a continuity or voltage reading. |
oxsign Samba Member
Posted: Wed Aug 07, 2019 5:11 pm Post subject: Re: Hello new Square!!!! |
KTPhil wrote: |
EXACTLY!!!!! I'd much rather work on the wife's Ghia because of that, lol. _________________ 1971 Squareback, fully bagged, 1776.
oxsign Samba Member
Posted: Wed Aug 07, 2019 5:57 pm Post subject: Re: Hello new Square!!!! |
On another note, I did get a temp tag last week and enjoyed driving around. I went to a big show on Saturday and even got a mini shoot (real pix later) with a model that asked for my car. Then I went through a Hot Rod show at Hooters on Sunday. These are all the pix I've been tagged in from both shows. Car got A LOT more attention than I ever thought it would, lol.
notchboy Samba Member
Joined: April 27, 2002 Posts: 22448 Location: Escondido CA
Posted: Wed Aug 07, 2019 6:43 pm Post subject: Re: Hello new Square!!!! |
Those mixed shows are the best kind to go to with an air cooled Vdub. The ladies love VW's _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
oxsign Samba Member
Posted: Thu Aug 08, 2019 9:32 am Post subject: Re: Hello new Square!!!! |
notchboy wrote: |
Those mixed shows are the best kind to go to with an air cooled Vdub. The ladies love VW's |
it is pretty fun. The last 15yrs or so I really got in to mini trucks/bags/etc. so a lot of these shows I’ll be going to will be a lot of that. It’s cool though cause at least it’ll be something different there, lol. It’s hasn't been but the last 4yrs or so I’ve slowly gotten back in to VWs once again. _________________ 1971 Squareback, fully bagged, 1776.
oxsign Samba Member
Posted: Thu Aug 08, 2019 9:53 am Post subject: Re: Hello new Square!!!! |
I want to make sure I’m checking the right thing. ‘71 square, this is the correct splitter I need to be checking right?? I’ve read in some threads that it’s a 4way. This one is a 3way.
Posted: Thu Aug 08, 2019 10:04 am Post subject: Re: Hello new Square!!!! |
oxsign wrote: |
That's the back up lights connector. The 3 way connector I was talking about, looks like 3 singles connected together as 1 piece. It's for joining 3 sets of wires from inside the car, to the master cylinder. I think 1 of the wires feeding the top side, also powers the horn on 72-73's (you'd have to ask a 72-73 owner to know for sure). Like I said, it should be located below the master cylinder on the left side near the top corner of the fuel tank. Probably under the trunk liner if it's still there. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
oxsign Samba Member
Posted: Thu Aug 08, 2019 10:32 am Post subject: Re: Hello new Square!!!! |
Ok, checked this one and no power to it on any of them.
I’m under the fuse block now and checking there....... _________________ 1971 Squareback, fully bagged, 1776.
oxsign Samba Member
Posted: Thu Aug 08, 2019 10:38 am Post subject: Re: Hello new Square!!!! |
oxsign Samba Member
Posted: Thu Aug 08, 2019 10:43 am Post subject: Re: Hello new Square!!!! |
So looking at the diagram on that 3way (6way) under the hood.
Blk wire is power supplied from the fuse panel.
Red/blk goes to MC to rear.
Red goes to brake light on dash.
So I have no power to it, I’ll go to the fuse panel and see what’s going on there.
Side note/question, switching to an alt (actual bug alt) wouldn’t have an affect on the light would it?? _________________ 1971 Squareback, fully bagged, 1776.
KTPhil Samba Member
Posted: Thu Aug 08, 2019 11:09 am Post subject: Re: Hello new Square!!!! |
That connector is labeled T3 in the wiring diagram, next to the fusebox (click to enlarge).
The horn uses one of the tabs as a power tap (black with yellow stripe). Keep in mind the horn has power with key on, and sounds when it is grounded through the steering wheel button. Source for this power is the same fuse as for the brake lights (third from right). So if you have no power with the key on, check that fuse first.
oxsign Samba Member
Posted: Thu Aug 08, 2019 11:11 am Post subject: Re: Hello new Square!!!! |
So both of these wiring diagrams are posted here under 1971 and they don’t match each other. Worse yet, it doesn’t look like mine matches either of them. I’m afraid to move/change anything on mine cause it did work before. wiring is the worst thing, lol. All I can do is laugh.......
KTPhil Samba Member
Posted: Thu Aug 08, 2019 11:13 am Post subject: Re: Hello new Square!!!! |
The first diagram is a supplement showing other devices we are not concerned with here, so ignore it.
The second one is correct for '71. What is your chassis number (first half dozen digits will tell)? |
oxsign Samba Member
Posted: Thu Aug 08, 2019 11:16 am Post subject: Re: Hello new Square!!!! |
KTPhil wrote: |
3612164136 _________________ 1971 Squareback, fully bagged, 1776.
KTPhil Samba Member
Posted: Thu Aug 08, 2019 11:18 am Post subject: Re: Hello new Square!!!! |
Ok, so definitely a '71, not an early one. Just curious, does yours have a bunch of extra wires for the diagnostic connector in the engine bay? That can complicate things. Another midyear change was to the brake check light wiring. Earlies made you press the dash button to test; later ones changed the lamp to include a diode and are wired differently.
This might have introduced changes like for the '72, that are not in the diagram for your model year, including the wiring of that triple connector, the warning light, and which fuse powers it. I'm not sure just when the change was made.
It may help to make a diagram of how your 3-connector is wired; it's hard to tell the exact pinout and wire color from the photo. We can then check if it's wired right (I wonder if it was changed since someone added a zip tie there?), and then know which should have power and when.
oxsign Samba Member
Posted: Thu Aug 08, 2019 11:24 am Post subject: Re: Hello new Square!!!! |
KTPhil wrote: |
Ok, so definitely a '71, not an early one. Just curious, does yours have a bunch of extra wires for the diagnostic connector in the engine bay? That can complicate things. Another midyear change was to the brake check light wiring. Earlier made you press the dash button to test. I think later ones changes the lamp to include a diode and may be wired differently. This might have introduced changes not in the diagram, including the wiring of that triple connector.
It may help to make a diagram of how your 3-connector is wired; it's hard to tell the exact pinout and wire color from the photo. We can then check if it's wired right (I wonder if it was changed since someone added a zip tie there?), and then know which should have power and when. |
I’ll try that out. I’m also going through the grounds to see if there’s a bad one somewhere. I put that zip tie there myself actually. Don’t remember why, I think it’s when I was cleaning and trying to keep it all together out of the way. Lol. _________________ 1971 Squareback, fully bagged, 1776.
