Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17961 Location: Eugene, OR
Posted: Fri Jul 26, 2019 10:45 am Post subject: Re: Hello new Square!!!! |
LYNX is headquartered in Australia, but they do have the merchandise!
https://www.lynxauto.com.au/ramflo-air-filters.html _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
oxsign Samba Member
Joined: February 19, 2006 Posts: 607 Location: Sanford, FL
oxsign Samba Member
Posted: Fri Jul 26, 2019 4:21 pm Post subject: Re: Hello new Square!!!! |
Ok, I have to upload the pix here but I got it lowered finally. 2 clicks out back and 3 up front. With a 205/70/15, it hits the inner rear fender. So I ordered a pair of air shocks (since I need shocks anyways) and that’ll give me the slight lift I need for clearance and still have a nice ride on the rear. I’ve ordered the white Empi gas filled “shorty” shocks for the front. _________________ 1971 Squareback, fully bagged, 1776.
Build thread here.....
https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 |
oxsign Samba Member
rustyfastback Samba Member
Posted: Fri Jul 26, 2019 6:27 pm Post subject: Re: Hello new Square!!!! |
Dang that square looks good after the slam job! |
oxsign Samba Member
Posted: Fri Jul 26, 2019 7:12 pm Post subject: Re: Hello new Square!!!! |
rustyfastback wrote: |
thank you. Can’t wait to take it out and get it settled. Should be a fun drive. _________________ 1971 Squareback, fully bagged, 1776.
T3Yoshi Samba Member
Joined: November 06, 2016 Posts: 158 Location: Sonoma County
Posted: Fri Jul 26, 2019 8:28 pm Post subject: Re: Hello new Square!!!! |
That 205/70 looks really good on the rear!
My car had air shocks when I bought it but I ended switching to KYB's because I wanted a static height anyways. Did you consider adjustable spring plates? I think they might cost a bit more than air shocks, but could be better for a static height if you're not planning on adjusting your ride height once you have the rear up a little bit. Just a thought.
Looking good |
oxsign Samba Member
Posted: Sat Jul 27, 2019 6:07 am Post subject: Re: Hello new Square!!!! |
T3Yoshi wrote: |
Looking good |
Thanks. I have considered them, but for now I figured I needed new shocks due to the lowering and figured the air shocks, once sent would be fine and ride good. I have them in my lifted Avalanche for towing and it also helped the ride quality as well. _________________ 1971 Squareback, fully bagged, 1776.
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22328 Location: Kimball, Mi
oxsign Samba Member
Posted: Sat Jul 27, 2019 10:32 am Post subject: Re: Hello new Square!!!! |
Bobnotch wrote: |
The altitude adjustment really helped. Looks good. |
Thanks, I thought so as well, lol. Funny thing is, it's still got the same rake, just a lot lower, lol. _________________ 1971 Squareback, fully bagged, 1776.
MonT3 Samba Member
Joined: January 07, 2012 Posts: 1988 Location: South Dakota
oxsign Samba Member
Posted: Sun Jul 28, 2019 5:42 am Post subject: Re: Hello new Square!!!! |
MonT3 wrote: |
Squares looking good and congrats on your lowering job! the little victories will win teh battle and get the car back on the road the way you want |
Thanks, and that they are. The biggest one so far (and not done by me) is the engine. I was loosing motivation again because of the work I was doing just felt like it was for nothing. I know it wasn't, but that's how I felt. Now, for the most part anything else that needs done can be done while driving and enjoying. Getting that "instant" gratification helps, lol. _________________ 1971 Squareback, fully bagged, 1776.
Posted: Sun Jul 28, 2019 12:41 pm Post subject: Re: Hello new Square!!!! |
oxsign wrote: |
Bobnotch wrote: |
Thanks, I thought so as well, lol. Funny thing is, it's still got the same rake, just a lot lower, lol. |
Just remember to check and reset the toe in. It DOES change when lowering. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
oxsign Samba Member
BSQUARE Samba Member
Joined: November 05, 2004 Posts: 1876 Location: Feeling, Minnesota
Posted: Sun Jul 28, 2019 6:54 pm Post subject: Re: Hello new Square!!!! |
oxsign wrote: |
P.S. I need to cut that tow hook off. You can hear it hitting everything lol.
It'll grind itself off
or, it won't take you take 10 minutes to jack it up, cut it off and squirt a bit of paint on it. |
Posted: Mon Jul 29, 2019 2:14 pm Post subject: Re: Hello new Square!!!! |
oxsign wrote: |
Got the air shocks on the rear so I can move it. Took it for a drive around the block and ran out of gas at the gate, LMAO. 😂🤣
https://youtu.be/IiNqqdWDBEk |
I was meaning the front will change. It'll go toe out.
The tow hook is your new positive stop. It'll grind itself off, or you can cut it off with a die grinder or Metabo blade in a 4 1/2" grinder. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
oxsign Samba Member
Posted: Mon Jul 29, 2019 6:17 pm Post subject: Re: Hello new Square!!!! |
Bobnotch wrote: |
oxsign wrote: |
The tow hook is your new positive stop. It'll grind itself off, or you can cut it off with a die grinder or Metabo blade in a 4 1/2" grinder. |
Got the hook all taken care of today.
oxsign Samba Member
Posted: Mon Jul 29, 2019 6:20 pm Post subject: Re: Hello new Square!!!! |
I also decided to clean and lay out some Fatmat in the engine compartment to help some with the noise and heat. I'll be doing the underside of the lid tomorrow. I'll probably put a second layer on as well. I love this stuff. I added it to the Ghia (roof, doors, panels, floor, etc. Also did all 4 doors of my Avalanche as well. Light and easy to work with.
oxsign Samba Member
Posted: Tue Jul 30, 2019 1:13 pm Post subject: Re: Hello new Square!!!! |
Bobnotch wrote: |
Looks good. Nice clean up before laying the mat down too. |
Thx. I used POR15 greaser and metal treatment. Then I painted it all with Rustolium "rust prohibitor" paint just to seal it before laying down the Fatmat. Seems to work good. _________________ 1971 Squareback, fully bagged, 1776.
