oxsign Samba Member
Joined: February 19, 2006 Posts: 607 Location: Sanford, FL
Posted: Wed Dec 22, 2021 7:46 am Post subject: Re: Hello new Square!!!! |
QRP wrote: |
Nice work on that tank Ox.
Although I would do something a little different with the vent filter, connect a small diameter hose to it and run it out under the car. |
thanks, I think he did a great job on it in the week it took him to build it. The vent isn’t final. I actually just put it on there for the pictures. The end will probably be as you said with a hose exiting out somewhere. 👍🏼 _________________ 1971 Squareback, fully bagged, 1776.
Build thread here.....
https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 |
QRP Samba Member
Joined: April 27, 2008 Posts: 1701 Location: NORTH HOLLYWOOD,CA
Posted: Tue Dec 21, 2021 8:54 pm Post subject: Re: Hello new Square!!!! |
oxsign Samba Member
Posted: Tue Dec 21, 2021 11:00 am Post subject: Re: Hello new Square!!!! |
Was looking for a stock gas tank since mine went bad (old mechanic used a liner, it started coming undone and clogging everything up) and after searching for a while I just asked my fabricator buddy if he could just make me a custom one.
I used a piece of the neck from an old tank with the VW cap. It sits 2” taller and is raised to clear the air bag & fitting. It’s right at 11.5gal total now vs 10gal stock. Overall I’m very happy with it and the work he did for me. _________________ 1971 Squareback, fully bagged, 1776.
oxsign Samba Member
Posted: Wed Dec 15, 2021 5:49 pm Post subject: Re: Hello new Square!!!! |
marchi wrote: |
looking at that same one for my build, which shade of tan is that for the headliner? |
honestly I just went with the option that they offer. They just have the one tan option for it. It’s a nice shade in person though. _________________ 1971 Squareback, fully bagged, 1776.
marchi Samba Member
Joined: August 10, 2005 Posts: 646 Location: Abilene, Texas
Posted: Wed Dec 15, 2021 4:17 pm Post subject: Re: Hello new Square!!!! |
looking at that same one for my build, which shade of tan is that for the headliner? _________________ I drive my VW or I walk
'70 Squareback
'21 Tiguan (daughters)
SOLD
'69 Fastback (Flamer) |
oxsign Samba Member
oxsign Samba Member
Posted: Mon Sep 27, 2021 8:47 am Post subject: Re: Hello new Square!!!! |
VWporscheGT3 wrote: |
Nice! if you have a welder i would maybe fill in the cut areas at the corners on your rear support.. but Im probably being overly cautious. |
Thats exactly what we have planned to do. We are also adding a strip on the backside to help strengthen what we cut out too. Like you said, over caution but better to be safe than sorry. _________________ 1971 Squareback, fully bagged, 1776.
VWporscheGT3 Samba Member
Joined: September 01, 2006 Posts: 2066 Location: Gardnerville, NV
Posted: Mon Sep 27, 2021 8:07 am Post subject: Re: Hello new Square!!!! |
oxsign Samba Member
Posted: Sun Sep 26, 2021 6:00 pm Post subject: Re: Hello new Square!!!! |
So building a 3rd motor (I’ll go into details later about that) with a new mechanic and while we were at it we decided to do a full flow setup. Brass fittings for mock up while we figure out how we are going to set it up. Trimmed the mustache bar some and once we’re done we’ll clean it all up. Also got the VS exhaust wrapped.
oxsign Samba Member
Posted: Tue Jun 29, 2021 8:53 am Post subject: Re: Hello new Square!!!! |
Czar1500 wrote: |
Those wheels look sharp. |
Thanks, my second favorite wheel. if I ever get a chance, I'd be running porsche cookie cutters. _________________ 1971 Squareback, fully bagged, 1776.
Czar1500 Samba Member
Posted: Mon Jun 21, 2021 9:45 am Post subject: Re: Hello new Square!!!! |
oxsign Samba Member
Posted: Sun Jun 20, 2021 7:25 am Post subject: Re: Hello new Square!!!! |
jeremydoc wrote: |
looks really good, bud. would love to see the air ride suspension system in greater detail. what size tires are you running? I have mine currently dropped with the similar set up as what you had, 3 clicks up front and 2 in the rear. |
What would you like to see from the setup? Running a Viair 444 comp on a 5gal tank all mounted in the spare tire well. I had a friend 3D print a radio bezel that houses my dual needle air gauge and 2 manual rocker switches under the dash. I'm running an Valley Autowerks bag beam narrowed 3" (would do 2") with link/king pin drop spindles that were modded to fit type3 disk brake setup. Welded a cross/support bar between the 2 rear shock towers and welded the bag brackets to that and the lower control arms. Cut & trimmed the shock towers on the outside to clear the left springs. I eliminated the rear torsions and maintained the shocks both front & back. I want to trim some more in the rear since I want it to sit lower there. The front sits on the pan already. _________________ 1971 Squareback, fully bagged, 1776.
jeremydoc Samba Member
Joined: March 14, 2013 Posts: 113 Location: Gardena, CA
Posted: Fri Jun 18, 2021 10:57 pm Post subject: Re: Hello new Square!!!! |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17961 Location: Eugene, OR
Posted: Thu Oct 22, 2020 10:37 am Post subject: Re: Hello new Square!!!! |
No, my set of 4 went to Finland. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
oxsign Samba Member
Posted: Wed Oct 21, 2020 6:04 pm Post subject: Re: Hello new Square!!!! |
Mike Fisher wrote: |
Pan dragger for sure! Are those the bumpers you bought from me? |
those actually went with the Fastback I had before this. I wish I could find a decent pair of bumper guards for this one though. You got a pair, or maybe the one I’m missing on the front by chance?? _________________ 1971 Squareback, fully bagged, 1776.
Posted: Wed Oct 21, 2020 5:31 pm Post subject: Re: Hello new Square!!!! |
Pan dragger for sure! Are those the bumpers you bought from me? _________________ https://imgur.com/user/FisherSquareback/posts
oxsign Samba Member
oxsign Samba Member
Posted: Mon Jun 29, 2020 2:24 pm Post subject: Re: Hello new Square!!!! |
Bobnotch wrote: |
The wrap came out looking really good. Quicker and easier than paint too. |
Easier & cheaper to change colors when I get bored of it too, lol. _________________ 1971 Squareback, fully bagged, 1776.
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22328 Location: Kimball, Mi
oxsign Samba Member
Posted: Mon Jun 29, 2020 1:17 pm Post subject: Re: Hello new Square!!!! |
OK, back with a few more updates. For my birthday, my wife got me a set of Cosmic wheels (love her for that, lol). I wrapped the roof of the SB in a pearl tangerine. I've sealed and put Fatmat throughout the car. I used some polish and buffed it all out. Night & day difference. I found some OG mud flaps for it but still need to fab up some brackets for them. Built a 4th order sub box for a single 10" sub. I'm still enjoying the hell out of it and someone got a pic from a local hotrod show I rolled through a couple weeks back.
Still got a few more things to do to it, but it's all "little by little" right? _________________ 1971 Squareback, fully bagged, 1776.
