gimmesomeshelter Samba Member
Joined: May 08, 2004 Posts: 1466 Location: San Carlos, CA
Posted: Tue Nov 07, 2017 10:06 pm Post subject: Modifying a 180mm flywheel to use a 200mm clutch |
My machinist tells me that a should run something a bit more robust than a stock 180mm pressure plate. I've looked at the Kennedy pressure plates, but I have to admit that I like the feel of a diaphragm PP. I've read that it's possible to modify a 180mm pressure plate to run a 200mm clutch. Has anyone done this? Who did the work? How much did it cost?
Cheers,
Paul _________________ "I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman |
Jacks Samba Member
Joined: July 15, 2006 Posts: 2347 Location: San Clemente, Ca.
Posted: Wed Nov 08, 2017 7:29 pm Post subject: Re: Modifying a 180mm flywheel to use a 200mm clutch |
Yes, that's what I was planning on installing.
I also have a NOS german PP, but it only has six springs.
Cheers,
Richard Feynman |
Jacks Samba Member
Posted: Thu Nov 09, 2017 12:54 am Post subject: Re: Modifying a 180mm flywheel to use a 200mm clutch |
gimmesomeshelter wrote: |
Cheers,
Paul |
Why did you say this? _________________ Jack Staggs
Actual name |
Posted: Thu Nov 09, 2017 1:03 am Post subject: Re: Modifying a 180mm flywheel to use a 200mm clutch |
Over the years I've used diaphragm style PP's, lever style PP's, and even a stage 1 PP from Kennedy. I found the stock diaphragm PP to be responsive and easy on the foot. The lever style was usable, but I found the diaphragm style to be much more comfortable. The Kennedy was much stiffer than stock, but not intolerable. The biggest problem with the Kennedy is that it greatly accelerated the failure of my pedal assembly (the bushings wore out).
Cheers,
Richard Feynman |
Jacks Samba Member
Posted: Thu Nov 09, 2017 1:14 am Post subject: Re: Modifying a 180mm flywheel to use a 200mm clutch |
I completely agree, but then why did you say THIS?
Cheers,
Paul |
Actual name |
RichardinNZ Samba Member
Joined: September 16, 2011 Posts: 280 Location: Auckland, New Zealand
Posted: Thu Nov 09, 2017 8:37 pm Post subject: Re: Modifying a 180mm flywheel to use a 200mm clutch |
Is the Sachs PP on your link different to the usual Sachs PP?
I managed to kill my new Sachs PP by adjusting the pedal to the factory spec; apparently the diaphragm type needs less movement than the finger type. The longer arm on later transmissions apparently sorted this (although at this moment after a long day at work I can't figure out the logic of this but sure it made sense at the time). I still have a short arm so am currently adjusting my pedal to the point at which things just work.
Thanks _________________ Richard
'58 Beetle; NZ Assembled
Dual Carb 36hp
My Car https://www.thesamba.com/vw/forum/album_page.php?pic_id=1750253 |
Mr.Ragtop Samba Member
Joined: February 04, 2010 Posts: 46 Location: colorado
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Sun Nov 12, 2017 6:45 pm Post subject: Re: Modifying a 180mm flywheel to use a 200mm clutch |
Wow .. for the price, that looks mighty sweet. Anyone here using it? _________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
JeeWee Samba Member
Joined: February 05, 2011 Posts: 120 Location: Garijp, the Netherlands
Posted: Tue Nov 14, 2017 8:53 am Post subject: Re: Modifying a 180mm flywheel to use a 200mm clutch |
I am using this 180mm PP clutch on my car, it is a 6volt 36hp based engine with okrasa setup, 58hp on the dyno. no problem!
it is the 9 spring heavy duty version, standard is 6.
This was a recommended upgrade back in the days when you have increased your engine output... it is featured in the 'jetzt mache ich ihn schneller' book, and most likely in other old manuals.
Totally vintage speed approved! |
Posted: Tue Nov 14, 2017 5:06 pm Post subject: Re: Modifying a 180mm flywheel to use a 200mm clutch |
I got tired of looking for a 9 spring 180mm pressure plate so I just ordered a Kennedy PP from John at AirCooled.net (http://vwparts.aircooled.net/180mm-Kennedy-Engineering-Racing-Clutch-Kit-p/kep180.htm)
I also just ordered an extra long clutch arm.
Cheers,
Richard Feynman |
