Clatter Samba Member
Joined: September 24, 2003 Posts: 7544 Location: Santa Cruz
Posted: Thu Nov 09, 2017 1:49 pm Post subject: DIY Brake Lines |
Anyone ever bend up their own hard brake lines?
I'm using a stock master and 944 calipers,
But so many things are in a different enough location,
That it would be best for me to just bend them all up from scratch..
Can you just order 'murrican car stuff and go to town?
Is there a special metric size for the hard lines?
What material do you like to use, and why?
Always liked Eastwood, and they have so many choices..
http://search.eastwood.com/search?w=brake+line
Thanks in advance.. _________________ Bus Motor Build
What’s That Noise?!? |
RLFD213 Samba Member
Posted: Thu Nov 09, 2017 2:06 pm Post subject: Re: DIY Brake Lines |
Here is just my 0.02 on brake lines. Use the hard line to go from the MC to the rear T. The rest get braided lines for. Less lines, they’re flexible and you will be able to bleed the system very easily. |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21519 Location: Oklahoma City
Posted: Thu Nov 09, 2017 3:00 pm Post subject: Re: DIY Brake Lines |
RLFD213 wrote: |
All braided lines....even Teflon core braided lines have a lifespan for the swaged areas alone if for nothing else.
Teflon lines especially also cannot be allowed to flop around. The Teflon core cracks VERY easily. They have lousey bend radius. They are excellent for the short low flex sections between the steel pigtail line to a caliper and the main steel chassis hard line...but should not be used anywhere else....except perhaps for a hydraulic clutch slave connector.
Clatter....you can by SAE steel lines that are "close" with correct metric couplings that will work just fine ...at many FLAPS.
The actual metric brake line IS slightly different but will not cause a problem.
On many VW's like type 3 and 4...the hard brake lines are 4.7mm. This is 0.18503"....and 3/16" brake line is 0.1875"...a difference of 0.00247".
So if you can buy the correct fittings for the MC and calipers/wheel cylinders you will be fine with those and bending your own. Ray |
Brian_e Samba Member
Joined: July 28, 2009 Posts: 3292 Location: Rapid City, SD
Posted: Thu Nov 09, 2017 3:03 pm Post subject: Re: DIY Brake Lines |
I used to plumb tube chassis rockcrawlers from scratch all the time. I had better luck going to the local parts store and getting straight sticks of tube. The rolls of tube are hard to get straight, kink easy, and often damaged in shipping. You will need metric. Its usually green. Each stick will come with both ends flared with a fitting. They come in lots of different lengths.
This is the only bender worth using. The others make large radius sloppy bends.
http://www.radwell.com/Shop?source=GoogleShopping&IgnoreRedirect=true&ItemSingleId=61429619
I have had good luck with a cheap generic metric bubble flare tool. I have also used one of these, and they are worth the money if you think you will be doing more jobs in the future.
http://www.eastwood.com/professional-brake-tubing-flaring-tool.html
Use all the stock hose mounts and plumb the new hardlines into them. The part store hardline fittings will work perfect with stock VW hoses.
You will waste a few sticks of tube learning to get your bends in the right spot, but they are cheap and easy to do over. Start with one factory flared end, bend up your tube, cut it, and re-flare to fit your needs.
Nothing shows a quality in a car build like well done neatly thought out plumbing and wiring.
Brian |
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4278 Location: deepest, darkest Switzerland
Posted: Thu Nov 09, 2017 3:06 pm Post subject: Re: DIY Brake Lines |
I wouldn't use braided anything on my brake system unless I could afford to replace them every 2-3 years, cuz how you going to inspect for cracks?
VW parts places sell pre-cut and flared kits, someone here will chime in. Try Aircooled.net? CB?
The difficulty is avoiding pinching when you do the bends. You can do them by hand, if you're careful, and a mini pipe-bending thingy can be useful:
https://www.ebay.com/itm/Tubing-Tube-Bender-Alumin...1712744849
These are the brakes, so be safe! |
UK Luke 72 Samba Member
Joined: September 07, 2011 Posts: 2867 Location: Little Britain
jason Samba Member
Posted: Thu Nov 09, 2017 3:54 pm Post subject: Re: DIY Brake Lines |
X2 cunifer. Same as copper nickel stuff. Like that it has more corrosion resistance. You can get the hard line and hose cheap. Make a tool to straighten the coils of tube. When I make bends I first make them with coat hangers. Then bend with your hand to the shape of the hanger. Bend against it. Tape the tube to the hanger as you go. Will steady everything as you go. Use round things like sockets and whatnot when bending hanger. You will get professional looking lines. If you lived closer you could use my flare tools. Here is my homemade straightener. Make sure to use the right ends. DIN/ISO bubble flare.
Krochus Samba Member
Joined: January 01, 2017 Posts: 892 Location: NW Arkansas
Posted: Thu Nov 09, 2017 4:25 pm Post subject: Re: DIY Brake Lines |
When I completely redid the lines on my street rail I bought a package of metric bubble flare to 3/16 ivf adaptors due to ease of obtaining hard lines by the stick and a 77 F100 master cylinder. I love my VW’s but any and all variations of the stock master cylinder is absolute crap
A 80’s dodge caravan rear brake hose is about 13” long and has standard 3/8 female inverted flare fittings on both ends I used these for my rear soft lines and they are very easy to work with.
Front EMPI kit, rear Mercedes W123 discs |
Posted: Thu Nov 09, 2017 4:42 pm Post subject: Re: DIY Brake Lines |
Brian_e wrote: |
Brian |
Yes.....most FLAPS carry the green metric tubes.
If they do not have what you need on hand.....more than a few also usually have wome on hand that are SAE tube with metric flares. Different color code as well. Those are the ones I was speaking of. You can do fine with them if you cant get anything else.
Nice bending tool!
Ray |
Lo Cash John Samba Member
Joined: February 06, 2004 Posts: 2246 Location: Jacksonville, FL
Posted: Thu Nov 09, 2017 5:48 pm Post subject: Re: DIY Brake Lines |
I bought this kit a while back.
https://www.amazon.com/OTC-4504-Stinger-Bubble-Flaring/dp/B0015PMZMU
I've had great results BUT it will not do stainless lines. I think at some point I'll upgrade to the nice kit Eastwood sales and pass the old kit on to one of my other VW buddies. _________________ www.LoCashRacing.org
More brains than bucks...Believe it or not!!
If you actually drive your VW, you need www.AirMapp.com
My boss told me I need to work on my mutli-tasking. So now when I use the bathroom at work I surf The Samba on my iPhone. |
Posted: Sat Nov 11, 2017 8:49 pm Post subject: Re: DIY Brake Lines |
Thanks for the tips, guys.
Love this forum (sometimes..).
Especially Brian - That tip of getting a bunch green line at the FLAPS was golden.
Some good fun today with the toys!
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6616 Location: Houston, Texas
Posted: Sat Nov 11, 2017 10:00 pm Post subject: Re: DIY Brake Lines |
I had a brake line rust through that went from the MC to the rear. I did it myself. It was the first time I did it and it came out fine. Make sure you put the correct flares on the ends. Loosen the MC a bit so that you can get the flare nut screwed on. That was really the hardest part, screwing the nut onto the MC. You have to get the bend perfect. _________________ www.vwnos.com [email protected]
Rome Samba Member
Joined: June 02, 2004 Posts: 9653 Location: Pearl River, NY
Posted: Sun Nov 12, 2017 1:17 pm Post subject: Re: DIY Brake Lines |
Quote: |
Use Cunifer and male m10x1 fittings. |
Does everybody know the meaning of Cunifer? It's derived from the alloy's elements used to make the tubing: Cu = copper, ni = nickel, fer = ferrous (metal). |
Nando_b63 Samba Member
Posted: Mon Jul 25, 2022 5:56 pm Post subject: Re: DIY Brake Lines |
Clatter wrote: |
Where you get those green brake lines?
Thank you |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9767 Location: Oregon
Posted: Mon Jul 25, 2022 6:53 pm Post subject: Re: DIY Brake Lines |
Nando_b63 wrote: |
Thank you |
FLAPS = Friendly Local Auto Parts Store.
Depending where you live. The store can be around the corner from you. Or in the next county away.
The green brake line tube is metric. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Mon Jul 25, 2022 6:59 pm Post subject: Re: DIY Brake Lines |
Nando_b63 wrote: |
Clatter wrote: |
Thank you |
I have found them at "most" auto parts stores over the years. THat being said, because a lot less people are working on their own stuff...some of the store chains are carrying less in stock.
But, typically in most districts the large NAPA main warehouse has the green ones ...usually in both metric with metric threads and in SAE tube with metric or SAE threads. But you may have to ask.
Just last week I bought a 1 foot section of steel metric (4.76mm OD) brake line with double flares at each end with correct metric 10mm nuts on it....but it is zinc plated....which is fine....just like stock. I got it at NAPA.
By the way....the green line comes in two varieties. The most common one now is metric and the green is an outer cast plastic coating in olive green. But, there is another one that is somewhat less common in a tannish green that is actually zinc chromated. Its a "mil-spec" line. If its metric both will work fine. Ray |
Posted: Mon Jul 25, 2022 7:10 pm Post subject: Re: DIY Brake Lines |
Thank you both. |
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Mon Jul 25, 2022 8:08 pm Post subject: Re: DIY Brake Lines |
At the parts store it’s best to just go back there and get the lines you need
They have several different lengths that are identical or close to original. On a Beetle, I have never had to cut the ends off and flare…but I imagine it could be required on a Bus or Type3
You can also buy SS kits from Wolfsburg West…correct lengths and ready to bend/install |
jimmyhoffa Samba Member
Joined: February 16, 2014 Posts: 1058 Location: St. Louis
Posted: Tue Jul 26, 2022 6:52 am Post subject: Re: DIY Brake Lines |
Of the tedious car building tasks, brake lines are one of the more therapeutic for me. I like to make the shapes and stuff.
I did the whole car in Cunifer on the last prep, and it was super easy. You don't even need a bender, just bend it over your roll cage or whatever round object you find. Absolutely no point in a bender.
The stainless work pictured was with an AutoZone line bendy tool and AN 37° flare tool. Gotta have a bender for SS line. _________________ 1974 Chenowth 2RL #1244 Street Legal
My other car isn't ridiculous. |
txoval Samba Member
Posted: Tue Jul 26, 2022 8:10 am Post subject: Re: DIY Brake Lines |
I hate working on brake lines
Your lines look nice |
