h00drat Samba Member
Posted: Tue Nov 14, 2017 11:49 am Post subject: Re: 2.0 ABA Swap Planning |
danfromsyr wrote: |
Do you have Power steering?
the oem PS pump location will interfer with the PS 50* engine carrier bar
requiring relocating the PS pump with new bracketry and maybe hoses/belt.
some have cut/sectioned the engine carrier bar.. |
Yes to power steering. I would like to keep the AC compressor if I can too.
That sucks about relocating the PS pump, or modifying the bars.
Per the above thread, it sounds like 83+ carrier bars may help with transmission modification, or am I reading that wrong? I was under the impression I would have to flip the front trans mount to move the transmission forward. However if the 83+ carriers mount the engine further back, can I get away without shifting the transmission forward?
Would any of the above challenges be remedied by going with the syncro carrier bars from someone like Tony, or will all carrier bars have issues with the power steering pump?
Lastly, with syncro bars dropping the engine lower, this may resolve the 2.0 ABA head + engine cover issues. _________________ <<Tyler>>
1987.5 Wolfsburg Weekender / CHC / 2.0 ABA
CHC Top Thread
Engine Conversion Thread (2.0 ABA Swap)
ABA Swap - Image Gallery
Auto Trans Rebuild - Image Gallery |
Vanagon Nut Samba Member
Posted: Tue Nov 14, 2017 12:41 pm Post subject: Re: 2.0 ABA Swap Planning |
The later style passenger side bar should allow room for the Mk3 PS pump. Of note, I may end up using a 90コ coolant pump elbow. That elbow interferes with the Mk3 PS bracket at block. I've read that material can be clearance on that bracket, but, depending on amount removed, I'd wonder about long term longevity of that bracket.
I now see your comments on fabrication, shop space.
For a 2wd 4 speed manual transmission WBX Vanagon:
'83 bar mount brackets are positioned to accommodate a VW I4 (up to '99?) engine mounted to the WBX transmission position. i.e. the arms of the ABA would line up with the diesel mounts. '82 style bar mount brackets are positioned further forward. They'd need to be cut, moved rearward to accommodate the VW I4 to the WBX transmission position.
There's a 'crate Tiico' build here. It shows the passenger side carrier bar and how it allows room for the Mk3 PS pump. If I'm not mistaken, it uses the '83 style bar. On that bar, the rear end sweeps hard right (as you look down, standing behind the van)
You should be able to find an ABA accessory bracket that accepts an AC compressor. There should be examples of AC/PS swaps here.
Neil.
Tiico install. Looks like the later style diesel bar. Looking down from rear, passenger side
This is my ABA swap in progress. V belt shown is a mock up. Image shows 90コ coolant elbow I plan to use
_________________ 1981 Westy DIY 15コ ABA
1988 West DIY 50コ ABA
VE7TBN |
Posted: Tue Nov 14, 2017 1:12 pm Post subject: Re: 2.0 ABA Swap Planning |
h00drat wrote: |
Here are some things that I feel like I need to do to the 2.0 while it's on the stand. Anything else you'd do?
2. Water pump
If possible, source a water pump with the cone shaped impeller. I got one from Van-cafe.com "Tiico" part.
The FLAPS type pump works ok but I think the other one might move coolant better especially at idle.
Neil.
coolant pump housing. You can see how the cone type impeller would most likely be more efficient.
difference between my FLAPS type pump and pump with cone shaped impeller. If I'm not mistaken, the ABA c/w a cone type pump from factory.
VE7TBN |
Posted: Wed Nov 15, 2017 9:31 am Post subject: Re: 2.0 ABA Swap Planning |
Progress. Got the wiring harness & ECO pulled from the FOX last night.
Oddly, it appears to be a Digifant 1 model (California?). Not sure exactly how this will differ from the DF2, which is what I expected it to be.
Next step, I need to get the 1.8 motor out of the Fox to scavenge some parts from it. Then, I need to start working on the 2.0 motor.
Questions for this morning...
1. Any brand or source preferred for timing belt?
2. Should I replace the timing belt tension pulley while I'm at it?
3. Going to replace rubber seals/oring on the front of the motor, as well as the rear main seal. Preferred brand/source for this?
CHC Top Thread
Posted: Wed Nov 15, 2017 12:43 pm Post subject: Re: 2.0 ABA Swap Planning |
The VW part number on ECU shows hits for Digifant I California and early 90's VW Fox. You could compare ECU connector wires to the left hand column table to be sure:
http://www.a2resource.com/electrical/management/digifant1.html
Gates makes good belts. Contitech too.
Yes. Replace timing belt tensioner. VW updated the tensioner stud. I think it has a larger OD at tensioner end. To check timing marks before removing belt, turn engine by crank bolt only. (not cam).
After replacing the crank seal, replace the crank pulley bolt. A tool can be made out of thick plate or box steel, nuts bolts, old sockets, to hold cam or IM shaft pulley when removing their bolt. With engine on stand I used a wood post with legs to brace tool. I will torque crank bolt with engine installed, in gear, brake on. My engine stand didn't have room for flywheel.
This is a field repair, I just used bolts on tool but gives you the idea of tool to steady cam and IM shaft pulley.
VE7TBN |
Posted: Wed Nov 15, 2017 2:21 pm Post subject: Re: 2.0 ABA Swap Planning |
I don't know why I am having such a hard time pulling the trigger on parts for this conversion. Maybe it's A - because they're really expensive, or B - because there are so many options, and so many opinions floating around.
I am basically ready to purchase the carrier bars/mounts and an oil pan. However, I'm still torn between syncro carrier bars and standard carrier bars. Syncro bars will cost me a bit more, but allow more clearance for the 2.0 cross flow head. Looking at anywhere from $600 - 800 for this stuff. $600 for 2wd, probably close to $800 for syncro bars (including oil pan).
EDIT: I guess there is always the option of dropped the carriers with spacers rather than spending the extra $$$ on syncro bars.
I want to buy the stuff to recondition the 2.0, but again, not sure what to buy, or where from. I have an email in to tektronics. Hoping they can help out. Here is my list for the 2.0...
1. Timing Belt
2. Timing Belt Tensioner
3. Water Pump
4. Thermostat
5. The three seals and oring on the front of the motor
6. A PTFE rear main seal
7. Distributor adapter to put the 1.8 distributor on the 2.0 motor - (I think it's this part - http://techtonicstuning.com/main/index.php?main_pa...s_id=1371)
Just don't want to buy the wrong stuff, or cheap stuff _________________ <<Tyler>>
CHC Top Thread
Posted: Wed Nov 15, 2017 3:46 pm Post subject: Re: 2.0 ABA Swap Planning |
An engine conversion usually takes a lot of thought and planning and typically takes longer than planned. And, things can change. In as much as I planned ahead, when a free complete ABA came my way ("hey lets learn how to rebuild an engine! Time to bug list for block honing info!" ) then a $500 CND complete 1.8 + early style diesel parts donor showed up, my plans changed. The engine position choice can be a challenge. BTDT. But here's how I now see this; on my current daily driver 15コ ABA, even with a 4" engine lid tub and minimal ground clearance, I've had a LOT of great trips over different terrain and it still runs great. i.e. On my pending 50コ swap, I won't sweat a ~ 2" loss [edit: or whatever it will be] and a small bump in the engine lid.
check out these images:
https://vanagolf.shutterfly.com/310
One shows what is likely an early style diesel bar and theres an image of hump at engine cover.
Heres another ABA swap showing a bunch more detail and images of same "hump". IIRC, this was a factory diesel Vanagon. Images have comments posted by author:
https://get.google.com/albumarchive/10420199252568...source=pwa
The pump, belts, seals are pretty standard stuff. Have a look around rockauto.com and azautohaus.com Check out the various brands and prices. The price can be a strong indicator. e.g. I think its "Uro" that is not a great brand and this is reflected in the pricing. For the most part, some brands you'll be dealing with are Meyle, Febi, Gates, Contitech; those brands are common to many European vehicles. Parts quality can run the gamut regardless of brand name.
I'm sure you've seen this but if not, check out parts and DIY kit pricing for Foreign Auto Supply, various 1.8T kits. e.g. $3K vs way more! That should put things into perspective. Another way to look at this; some of the money you will save doing this swap yourself can be put toward any other needed repairs; a swap is only as good as its' ancillary components!
IIRC, since you have access to shop and tools, I'd suggest that most anything can be made to work. At some simple level, its just time and metal the latter of which is pretty cheap.
Neil. _________________ 1981 Westy DIY 15コ ABA
VE7TBN |
tristessa Samba Member
Joined: April 07, 2004 Posts: 3992 Location: Portland, OR
Posted: Wed Nov 15, 2017 3:59 pm Post subject: Re: 2.0 ABA Swap Planning |
In addition to the parts listed, I'd also replace the valve cover and oil pan gaskets, and make sure you get the front seal housing-to-block gasket as well. Change the seal on the oil warmer/cooler above the filter unless you delete it for a true oil cooler with a thermostatic sandwich adapter.
If you make a trek into Portland, Halsey Import Parts should have everything but the distributor adapter on the shelf. Call ahead and they can have it waiting when you get there, and maybe pick Rob's brain while you're at it -- he's put a TIICO or at least TIICO-style swap in his Adventurewagen. |
Posted: Wed Nov 15, 2017 6:09 pm Post subject: Re: 2.0 ABA Swap Planning |
So the kit from Quality German comes with the oil pan, filler tube (which I'm assuming uses the license plate door) and the oil pump pick up tube. I can get the dip stick tube and dip stick to go out the license plate door for another $125.
Worth it!?!? or just lift the engine lid to check the oil...
Maybe they'd swap the filler tube with the dipstick tube if I'm willing to fill the motor through the valve cover, but can still check the oil via the license plate door _________________ <<Tyler>>
CHC Top Thread
Posted: Wed Nov 15, 2017 7:37 pm Post subject: Re: 2.0 ABA Swap Planning |
h00drat wrote: |
Hey Neil, what hose kit did you use?
Haven't figured out hoses yet, not sure if I'll use the stock ABA "spider" hose. If you're using the ABA head and block..... search "ABA coolant hose" or variation of that here. I can never remember how to spell his samba handle (Ilcahan or something) but that fellow posted here about a VW hose combo that he used.
Did you look into the different coolant pump I pointed to?
VE7TBN |
Posted: Wed Nov 15, 2017 7:45 pm Post subject: Re: 2.0 ABA Swap Planning |
$300+ for a set of hoses sounds crazy to me, so I値l research the aba hoses a bit more.
I did see your comment a about the coolant pump outlet below the water pump. I知 assuming that is what you池e referring to.
I won稚 know how everything lines up until I get the carrier bars, water pump, power steering pump, etc all mounted up.
Some of the hoses on my ABA motor were cut, so they will at least need replaced. _________________ <<Tyler>>
CHC Top Thread
Posted: Wed Nov 15, 2017 8:03 pm Post subject: Re: 2.0 ABA Swap Planning |
h00drat wrote: |
Some of the hoses on my ABA motor were cut, so they will at least need replaced. |
No. Was referring to my post with images showing the 2 different designs of water pump impeller.
The pump with the smaller paddles will work (my other ABA vanagon has that type of pump) but would suggest the water pump with the more cone shaped impeller, like this type:
http://www.van-cafe.com/tiico-water-pump
is more efficient than the other type, which is what most NA parts stores carry.
I'm assuming that the "cone shaped" impeller pump exterior dimensions are the same as the pumps typically carried by FLAPS. (i.e. each style of pump I showed places the outlet in the same position)
You will find that hose combos can be cobbled together using VW hoses or if need be, VW hoses and FLAPS type generic hoses. _________________ 1981 Westy DIY 15コ ABA
VE7TBN |
Posted: Wed Nov 15, 2017 10:05 pm Post subject: Re: 2.0 ABA Swap Planning |
Vanagon Nut wrote: |
I bought that exact pump from van cafe (great vendor btw) and dry mounted it on my ABA. It fits fine but to be clear, given the interference I saw between the NON stock outlet and Mk3 PS bracket, theres a very remote chance the pump is slightly different (longer) than the more commonly available pump. I doubt it though.
As mentioned, the more commonly available style pump works ok.
Hope my nit picking with details isn't complicating things.
VE7TBN |
dkoesyncro Samba Member
Posted: Thu Nov 16, 2017 10:08 am Post subject: Re: 2.0 ABA Swap Planning |
I've done an ABA at 15ー in a Syncro, it's an excellent engine choice. I started down the obd1 path, in the end it's an obd1 engine with obd2 management. I chose this for a cleaner bay less cluttered.
I know you're feeling overwhelmed at this point, I was to! You mentioned having a good work space, I had a roof, daylight and gravel. This being said, take your time and build it. Hans J and Neil have both built engine carriers that look to perform well. Part of the 15ー install is you can look at the fox from the passengers fender and any other VW and know that's how it's going to look. No need for the shortened oil pump or an aluminum oil pan.
I'm in Oregon City if you have questions or would like a hand. I eventually built my own coolant lines out of steel and readily available rubber 90ー and regular coolant hose. |
Posted: Thu Nov 16, 2017 10:18 am Post subject: Re: 2.0 ABA Swap Planning |
dkoesyncro wrote: |
Thanks for the info and encouragement! Yes, feeling a bit overwhelmed, but excited at the same time.
I am going to pull the trigger on the following, today (from quality german):
Engine carrier and mount setup - stock diesel take offs
Oil pan
Dip stick and dip stick tube (behind the license plate)
Oil pump pickup tube
Going to pickup the following parts from Halsey in Portland the next chance I get:
Timing Belt
Water Pump
Thermostat
Gaskets
cam shaft
crank shaft (front)
rear main seal
intake gaskets (x2)
header gasket _________________ <<Tyler>>
CHC Top Thread
