Joined: August 15, 2002 Posts: 4256 Location: Brew City
Posted: Sat Nov 11, 2017 2:52 pm Post subject: MOFOCO 1914 Dyno #'s, EGT's w/050 Rassers & HYD Lifters |
So, everyone has been asking about the HP potential of some of my heads, along with cooling ability. I also have gotten a lot of questions about the limits of my hydraulic lifters. So, I built a 1914cc with a CW crank, lite FW, I-beam 5.4" rods, Engle W120H cam, hydraulic lifters, AA 94's, 050 Rassers, 9.0 to 1 CR, solid rockers with 1.1 arms, MST Serp belt kit, Dual Weber 44IDF's and a 1 5/8" header and sideflow muffler. I wanted to build a realistic street engine that didn't cost $10,000+ and use as few "race" parts as possible. For example, I only used a 009 Dist with points, Bosch blue coil and standard wires. The total cost to buy this engine from me with clutch is $6099, all brand new.
118.5HP
6167RPM
113.1FT/LBS
4700RPM
EGT's were 1300's at 6000rpm but held steady between 1150 and 1250 degrees between 3000rpm and 4700rpm where typically most people will be driving. _________________ Please "LIKE" us on facebook to see what we are working on.
https://www.facebook.com/mofoco?ref=ts&fref=ts
www.mofoco.com
Cylinder Head Reference Sheet |
fivelugshortaxle Samba Member
Joined: May 13, 2011 Posts: 4253 Location: Aumsville, Oregon
Posted: Sat Nov 11, 2017 2:55 pm Post subject: Re: MOFOCO 1914 Dyno #'s, EGT's w/050 Rassers & HYD Lifters |
Those are pretty good numbers for a mild 1915 _________________ Good things come to those who wait.
2332 with lots of goodies....
Rotating assembly balanced by Brothers VW
4340 84mm crank
AA 94mm p&c' s
Total seal 2nd ring, rest are Grants
5.5 h beams
Magnum straight cuts
Steve Long XR310 on a 106
CB 1.4 rockers
CB Magnaspark 2 distributor
NGK D7ea plugs
A1 lowdown 1 3/4 with single muffler
Dellorto 48's with 40 venturies
Kennedy Stage 2 with Daiken disc |
Motor60 Samba Member
Posted: Sat Nov 11, 2017 3:04 pm Post subject: Re: MOFOCO 1914 Dyno #'s, EGT's w/050 Rassers & HYD Lifters |
Are those tall manifolds? Would there be a difference between tall and short manifolds? I’d like to see the #s if you had time |
jpaull Samba Member
Joined: February 22, 2005 Posts: 2591 Location: Sacramento Ca
Posted: Sat Nov 11, 2017 3:27 pm Post subject: Re: MOFOCO 1914 Dyno #'s, EGT's w/050 Rassers & HYD Lifters |
Do you have your own Dyno now?
That's great your putting things to the test. I noticed in your Facebook video on this Dyno run you were doing lots of short revs instead of a long sweep. It takes awhile to get the hang of opening the water flow just the right amount to not load the engine to quick. In my first attemps, I loaded the engine prematurely to fast and got a high number at low rpms but it wasn't pulling higher rpms it just loaded hard and stopped pulling higher, so it wasn't a real hp number, just a braking load shock number.
Hope that your able to make more and more pulls, its a tool every builder should have. _________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), Ported Mofoco heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Transmission by MCMScott:
Rhino case, Klinkenberg 4.12, Superdiff, 002 mainshaft with 091 first idler. Weddle 1.48 Third & 1.14 Fourth. |
modok Samba Member
Joined: October 30, 2009 Posts: 23382 Location: Colorado Springs
Posted: Sat Nov 11, 2017 4:12 pm Post subject: Re: MOFOCO 1914 Dyno #'s, EGT's w/050 Rassers & HYD Lifters |
Good test. Fairly good considering.
The big torque dip at 3500 is not great for a street engine tho. I think it's the exhaust side of the engine is causing that. |
Posted: Sat Nov 11, 2017 4:35 pm Post subject: Re: MOFOCO 1914 Dyno #'s, EGT's w/050 Rassers & HYD Lifters |
jpaull wrote: |
Hope that your able to make more and more pulls, its a tool every builder should have. |
No, I went to a raceshop to have them dyno it. I have one but after seeing his, I still need a lot of work to get mine rolling. The video was just the warm up. I also only got a couple real pulls.....had to get home to take the wife and kid out to dinner. _________________ Please "LIKE" us on facebook to see what we are working on.
www.mofoco.com
Posted: Sat Nov 11, 2017 4:38 pm Post subject: Re: MOFOCO 1914 Dyno #'s, EGT's w/050 Rassers & HYD Lifters |
modok wrote: |
The big torque dip was only 2.5ft/lbs from 3400 to 3500. Otherwise it pulled steady torque and hp all the way. Again, not a race engine.
What do you think it should have pulled? I've seen almost the exact same combo advertised by another company using a cam with .100" more lift getting the same HP. _________________ Please "LIKE" us on facebook to see what we are working on.
www.mofoco.com
Alstrup Samba Member
Joined: July 12, 2007 Posts: 5180 Location: Videbaek Denmark
Posted: Sat Nov 11, 2017 6:57 pm Post subject: Re: MOFOCO 1914 Dyno #'s, EGT's w/050 Rassers & HYD Lifters |
Just about bulls eye for a medium set up 1914 with off the shelf parts. I have seen a lot of 1914 engines with that cam (in the solid version though) and and similar type heads pull in the 118 - 125 hp window.
Erhm, the torque dip is much wider, almost 500 rpm.
The dip in the curve is most certainly a combination of the header being on the large side for the engine and an intake resonanse.
Swop to a 1½" and rejet, and the dip will reduce a lot. Maybe even pick up a pony or two.
T
PS. I just copied and enlarged the screen print. The dip looks a bit odd. - Maybe it does not like the tall manifolds. I would definitely try a smaller header and shorter manifolds and see where that got me.
T
74 Thing Samba Member
Posted: Sat Nov 11, 2017 6:58 pm Post subject: Re: MOFOCO 1914 Dyno #'s, EGT's w/050 Rassers & HYD Lifters |
Alstrup posted some 1914 combos in the past on the Engine Builds/Combo sticky above (this one is on page 6, and he also has one on page 7 using a Webcam 163 making 136hp, and 192Nm of torque). He is using smaller valved heads (although ported) and a solid lifter camshaft. Did you do an A/F reading and jet and time that engine? I think there is more left in it.
This is a 1914 that was built over the last approx 2½ months for a VERY nice 1960 beetle.:
Line bored dual relief case, modified for full flow.
CB 69 mm counterweighted crankshaft
CB 200 mm flywheel. 13½ lbs.
KEP stage 1 Pressure plate
All dynamically balanced
Exedy super disc.
Unitech HD rods, ligthed 20 gr. (545 gr) Rebalanced.
Cam: A variant of the Web 110 cam. 256 degr. @ 0,050”. 0,495/0,435” lift. 108 LC.
CB lightweight lifters.
26 mm Shadek oil pump, blueprinted.
CB 1,3 l. thin line oil sump
CSP full flow cover.
CB Cromemoly 8 mm head studs.
AA 94 mm pistons and cylinders. Checked, but in balance.
CB 044 cylinderheads, 40 x 35 mm valves, Ported to my stage II. (170 cfm @ 25") Oteva sgl. valve springs, CB titanium retainers. 9,8 – 1 CR.
CB HD rocker shafts.
Porsche style adjusters.
ACN aluminium push rods.
German 009 distributor w. Ignitor module. Pertronix 3 ohm coil.
CSP 30 hp fanshroud w. doghouse & fresh air.
NOS dual 40 mm Dellorto´s on CB offset manifolds.
CSP 1½” street sport exhaust system
143.6HP and 189Nm of torque |
Erik G Samba Member
Joined: October 16, 2002 Posts: 11925 Location: Tejas!
vince1 Samba Member
Joined: December 14, 2003 Posts: 794 Location: Burgundy, France
Posted: Sun Nov 12, 2017 12:00 am Post subject: Re: MOFOCO 1914 Dyno #'s, EGT's w/050 Rassers & HYD Lifters |
A friend imported to France a 69 deluxe bay window equipped with a 1775 mofoco hyd lifters engine, never heard a flat 4 as quiet as this engine, you could barely listen any mechanical sound, just the single quiet pack caracteristic exhaust tone.
For family vans where you want to talk with your passengers I think it's a good selling point. _________________ my French blog https://vwpanelvan.wordpress.com/
Click here for my full pix detailed 2165 engine build with beehive valvetrain.
Sorry for my poor English, I'm a French guy ...  |
UK Luke 72 Samba Member
Joined: September 07, 2011 Posts: 2246 Location: Little Britain
Posted: Sun Nov 12, 2017 10:43 am Post subject: Re: MOFOCO 1914 Dyno #'s, EGT's w/050 Rassers & HYD Lifters |
Do your hyd lifters require machining the lifter bores larger (in the past I know of other companies using larger Ford hyd lifters), and do you have anything available that makes more power/is more aggressive than your hyd120 camshaft that is used in this build? |
drumbum68 Samba Member
Posted: Sun Nov 12, 2017 10:54 am Post subject: Re: MOFOCO 1914 Dyno #'s, EGT's w/050 Rassers & HYD Lifters |
Roy, curious to know why numbers are crossing over 5500 rpm's? |
Posted: Sun Nov 12, 2017 10:55 am Post subject: Re: MOFOCO 1914 Dyno #'s, EGT's w/050 Rassers & HYD Lifters |
74 Thing wrote: |
We are the only company in the world to manufacture drop in hydraulic lifters for type 1 aircooled engines. Others have tried unsuccessfully in the past to copy us. Currently, the most aggressive hyd performance cam I have is the W120H. I could have used 1.25's instead of 1.1's to give it a little more lift.
I also really appreciate everyone's feedback. This engine is a specific build I did for a customer that just happened to fit what I wanted to dyno for a 1914. I will be getting numbers on my 2110 and 2276 over the next 6 weeks.
Like I said, I've had a lot of questions on power potential for my heads and cooling ability and I think this test proves what I have been saying for a long time. _________________ Please "LIKE" us on facebook to see what we are working on.
www.mofoco.com
vwkirb Samba Member
Joined: January 16, 2007 Posts: 811 Location: Athens, GA
Posted: Sun Nov 12, 2017 11:52 am Post subject: Re: MOFOCO 1914 Dyno #'s, EGT's w/050 Rassers & HYD Lifters |
drumbum68 wrote: |
Torque is measured, horsepower is not.
HP = (TQ*RPM)/5250 _________________ Andrew Kirby |
modok Samba Member
Posted: Sun Nov 12, 2017 3:34 pm Post subject: Re: MOFOCO 1914 Dyno #'s, EGT's w/050 Rassers & HYD Lifters |
the torque scale is not same as HP scale, look at the numbers on the sides of the graph, that's why they don't cross at 5200 |
Posted: Sun Nov 12, 2017 5:00 pm Post subject: Re: MOFOCO 1914 Dyno #'s, EGT's w/050 Rassers & HYD Lifters |
modok wrote: |
Yeah, not sure why the graph looks a little strange. Maybe it's the DOS operating system along with the early 90's monitor.
Here is the numerical readout that shows the numbers crossing at 5250.
www.mofoco.com
mark tucker Samba Member
Joined: April 08, 2009 Posts: 22676 Location: SHALIMAR ,FLORIDA
Posted: Sun Nov 12, 2017 7:20 pm Post subject: Re: MOFOCO 1914 Dyno #'s, EGT's w/050 Rassers & HYD Lifters |
try some1.25& 1.34 rockers and see...and the small er header..... 40's might hep a tad too...find the best combo for a bus and a bug. there are somany diferent size intakes out there , tall short, offset, houmoungus and small streamlined runners. . and a dist with a good curve can do wonders. for those tq drops....get your dyno up and runnen and build your self a test mule....to be raffled off when it's done all the testing you need to do on that size motor. a good dynod motor thats proven & broken in should be a eazy raffel to do, then go on to the next size and do over. |
