fifthcenturycheese Samba Member
Joined: May 04, 2014 Posts: 172 Location: Pismo Beach
Posted: Sun Nov 12, 2017 5:35 pm Post subject: 1300 converted to 1600 makes "ratty"noise during excelleration |
I am trying a used 1300 that has been converted to a 1600 in my bug. The history on the engine is that it was taken out of a car by the German mechanic that performed the services on it. It's an F0 case with bigger cans added later, a 113 905 205K along with a brazilian solex 30/31 carb. I put a new repop Wolfsburg West muffler on but am having a hard time getting the exhaust donuts to sinch up tight enough to stop exhaust leaks. Everything concerning the exhaust system aligns properly, but still having minor leak issues. What is troubling to me is the engine or car makes a "deep ratty" kinda sound under load/ when accellerating or going up hill....the more gas I give it, that "rattier" the sound. ??? Timing was set at 7.5 advance for that particular distributor. What the hell is the sound? Thanks for taking the time to read this, Mike.
Last edited by fifthcenturycheese on Sun Nov 12, 2017 10:35 pm; edited 1 time in total |
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Sun Nov 12, 2017 5:50 pm Post subject: Re: 1300 converted to 1600 makes "ratty"noise during excelleration |
Might be detonation. You need to see how much total advance your getting. IDK if that carb is the right match with that distributor. You might be getting the totally wrong vac signal.
In wouldn't drive it until you make sure it's not detonation or you might be rebuilding that engine again quicker than you think. |
Posted: Sun Nov 12, 2017 6:13 pm Post subject: Re: 1300 converted to 1600 makes "ratty"noise during excelleration |
I forgot to mention, it has popped/sputtered coming down hill in gear as well.... |
iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9829 Location: Somewhere between Dubuque and Keokuk
Posted: Sun Nov 12, 2017 7:01 pm Post subject: Re: 1300 converted to 1600 makes "ratty"noise during excelleration |
I have no idea what a rat sounds like, but perhaps you are merely hearing your exhaust leaks. |
h~moto Samba Member
Joined: November 19, 2008 Posts: 317 Location: Northern Virginia
Posted: Sun Nov 12, 2017 9:32 pm Post subject: Re: 1300 converted to 1600 makes "ratty"noise during excelleration |
What kind a air filter is on your car? An engine without an air filter or a filter less restrictive than normal would make a sound that I would describe as ratty. |
Posted: Sun Nov 12, 2017 9:43 pm Post subject: Re: 1300 converted to 1600 makes "ratty"noise during excelleration |
Stock 67 air cleaner. |
bluebus86 Banned
Posted: Sun Nov 12, 2017 10:53 pm Post subject: Re: 1300 converted to 1600 makes "ratty"noise during excelleration |
iowegian wrote: |
YES, Please define the ratty noise?
detonation, also called pinging is like a rattling noise, like stones in a soup can being shock, usally worse under load, and not audiable when idling or engine under low load Its detonations are happening inside the cylinder head. Detonation happens when the explosion happens too soon, if you having this Detonation noise, thevrattling stones in a metal can sound which is most apparent under high load, then the use of higher octane fuel, back off timing, check mixture, check for over heating, are things to consider.
Exhuast Leaks........ have a mostly clank clack noise or rumbling and should be apparent at all motor operation condions, unlike detonation, which wont be audiable at idle or low load conditions, where as an exhast leak will be heard at idle, under load, under no load, in all conditions.
so listen for the two differences, Detonation, or Exhaust Leak.
tell us if it sounds like either.
The popping in exhaust sounds when you let off throotle might be a rich mixture applied when throotle is closed and engine is over running. That noise is NOT detenation, as Detonation happens worse under load, the opposite of what happens when you let of the throotle and unload the motor.
good luck Bug On! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Rome Samba Member
Joined: June 02, 2004 Posts: 9653 Location: Pearl River, NY
Posted: Mon Nov 13, 2017 8:25 am Post subject: Re: 1300 converted to 1600 makes "ratty"noise during excelleration |
Quote: |
I am trying a used 1300 that has been converted to a 1600 in my bug. The history on the engine is that it was taken out of a car by the German mechanic that performed the services on it. It's an F0 case with bigger cans added later, |
Did the German mechanic measure, write down; and provide you with the following data during the conversion work: deck height, and combustion chamber volume? If he started out with the 1300 heads which is most likely, he'd need to have the combustion chambers bored out to the larger outer diameter of the 1600's cylinders. If this work is not done to the 1300 head, the 1600's cylinder is simply too large to fit into the head. My concern is that the engine ended up with too high of a compression ratio (CR). The "ratty" sound you're hearing, and was described by bluebus as "rattling", could be caused by too high of a CR. |
Zundfolge1432 Samba Member
Posted: Mon Nov 13, 2017 10:10 am Post subject: Re: 1300 converted to 1600 makes "ratty"noise during excelleration |
Keep the throotle to the poodle |
Posted: Mon Nov 13, 2017 7:12 pm Post subject: Re: 1300 converted to 1600 makes "ratty"noise during excelleration |
So, I adjusted the Brosol/Solex H30/31 according to the Rob and Dave's page of carb adjusting. Did exactly as they listed and the car idles nicely at around 900 rpm. Where the heater boxes fit into the new aftermarket muffler, I was getting the exhaust leak "ticking/hissing" sounds. The new exhaust seal donuts and clamps were not pulling the gaps together so I cut some Coors light can material to fill in the gap between the donut and smaller diameter exhaust pipe...that seemed to get rid of the leaks! Simply going tighter with those clamps was not working. At this point I will ask that the beer snobs keep to themselves on the Coors Light business.....
The "ratty" sound as I call it... It is hard to describe a noise, maybe better would be a more solid rumbling when under load, going up hill and heavier acceleration when driving. The best I can do is a solid kind of gargling sound and vibration towards the back end of the car. I know I need to replace the rubber "body to chassis " pads that insulate the body from engine and road vibration. I know what detonation from fuel breaking down sounds like and this is a deeper sound than "pinging".
There is no paperwork on the 1300 to 1600 conversion work form the past so I would probably have to pull a head to see what size can is in there. I can't find the head number at the moment, but it seemed that I looked it up and they were 1600 sp heads.
Still getting the ratty noise, runs better with adjusted carb and quiet exhaust seals. Still slightly snaps when going downhill with car in gear, foot off throttle...
Still trying to diagnose ratty sound and eliminate.... |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Mon Nov 13, 2017 9:45 pm Post subject: Re: 1300 converted to 1600 makes "ratty"noise during excelleration |
The exhaust "doughnut" clamps are not the same size front to back. When you have a new set you have to look carefully with them layed on a flat surface. You'll notice that the front side of the clamp is smaller than the rear (front meaning the front of the car).
The smaller side is the heat-exchanger side of the clamp. Put the doughnut metal backing ring on the exchanger first then the doughnut. Slide those rearward into the flared inlet on the muffler then install the clamp smaller diameter on the exchanger and larger on the flared muffler. It should seal up well if the parts are in the correct orientation. No beer can band-aid needed
Good Luck. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Fri Nov 17, 2017 11:08 pm Post subject: Re: 1300 converted to 1600 makes "ratty"noise during excelleration |
There's a new twist to this engine! Did a compression test on the cylinders and found: #1 at 125psi, #2 at 135psi, #3 at 85psi, #4 at 130psi.
As you can see, I have a dead cylinder. First thing I am going to do is check the torque on the head bolts. If that doesn't produce a miracle, I will then do a cylinder leak down test to find the source of the problem.
I am slowly learning about all of this and want to figure out how to correct this issue. If its just a valve or a set of rings, can just those components be changed? How do you figure out sizes and all. Or is it cheaper to just get a set of heads?
Thanks for following this post and all your help, Mike |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
Posted: Sat Nov 18, 2017 6:54 am Post subject: Re: 1300 converted to 1600 makes "ratty"noise during excelleration |
Some parts can be repaired or refurbished without too much expense, some are better replaced. Find the issue first, then you can deal with how to repair it. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
