bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4341 Location: Los Angeles, CA 90016
Posted: Sun Nov 12, 2017 8:06 pm Post subject: Preferred Tools To Make Chamber Radius |
What's a good tool/s to make a nice radius around the chamber ridge? I'm currently using an angle grinder with 1" discs to knock off the sharp edge. They look ok, but I'd like something that leaves a nicer finish. |
modok Samba Member
Joined: October 30, 2009 Posts: 26785 Location: Colorado Springs
Posted: Sun Nov 12, 2017 8:25 pm Post subject: Re: Preferred Tools To Make Chamber Radius |
1" cylindrical Flap wheel, or sanding drum, or Cratex..... you want to impress yourself try cratex |
Posted: Sun Nov 12, 2017 10:17 pm Post subject: Re: Preferred Tools To Make Chamber Radius |
I have a 1" flap wheel, but the shank is only about 1 1/2 inches. On the intake side it's hard to pivot to get a bunch of angles in. Sanding rolls are the same. I want to be able to nicely radius those areas too.
I need to Google Cratex. |
FeelthySanchez Samba Member
Joined: February 03, 2011 Posts: 1349 Location: Now is that a real poncho, or a Sears poncho?
Posted: Sun Nov 12, 2017 10:46 pm Post subject: Re: Preferred Tools To Make Chamber Radius |
Buy or make yourself a 4" long shank extension to fit the flap wheel. _________________
modok wrote: |
I would like if you had enough clue to communicate what you are doing. |
Ryan Tucker wrote: |
Enough clue..Whats that mean? |
OldIronSpine wrote: |
I'm not sure how compression works.
Turbos don't produce torque, they produce HP. Instead of torque.
The real problem with NA engines is you don't hear the nice whine of the turbo as it spools up.
Before I commit, I'm going to do more research because I don't really know what piston rings are. |
Floating VW Samba Member
Joined: April 28, 2015 Posts: 1596 Location: The South Zone
Posted: Mon Nov 13, 2017 10:15 am Post subject: Re: Preferred Tools To Make Chamber Radius |
You mean in the combustion chamber? It might be better to just leave the sharp edges alone. I've always understood that sharper edges help to improve the turbulence in the chamber. _________________ "It's time you started treating people as individuals, rather than mathematically predictable members of an aggregate set, regardless of how well that works." |
UK Luke 72 Samba Member
Joined: September 07, 2011 Posts: 2867 Location: Little Britain
mark tucker Samba Member
Posted: Mon Nov 13, 2017 10:43 am Post subject: Re: Preferred Tools To Make Chamber Radius |
there are places for sharp's and places not to have them. I would hate to see the ops heads after the disc...although sometimes looks dont matter. ...sometimes....... the preferred tools for me would be cnc mill....but my dirgrinder&carbides and abrasive rolls do just fine. I also do a lot on the mill to them. it all kinda depends on what you have and what you can do and how much$ your willing to spend to do it.sometymes the best $ s[ent is sending them off to somebodt that has the tools and knows how to not eff them up. |
Posted: Tue Nov 14, 2017 6:58 pm Post subject: Re: Preferred Tools To Make Chamber Radius |
Mark' I did a pretty clean job with the sanding disc. It's 80-grit, and tiny enough to get in hard to reach places. I just remembered I have sanding rolls in my Dremel case. I could use that. |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15303 Location: Deep in the 405
Posted: Tue Nov 14, 2017 8:42 pm Post subject: Re: Preferred Tools To Make Chamber Radius |
For a Harbor Freight item this can't be beat and do an awesome jobs for the price. https://www.harborfreight.com/sanding-cone-set-52-pc-62394.html _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
nsracing Samba Member
Posted: Tue Nov 14, 2017 9:06 pm Post subject: Re: Preferred Tools To Make Chamber Radius |
I got an electric Harbor Freight grinder. I exchanged about 4 or so of them before I found one that was super accurate and did not vibrate.
Now it is my main porting tool until I get my very large 100 gallon 3-Phase compressor back here in VA. I sold my smaller compressor 80 gal single-phase.
So far the grinder is plenty for me to use for all my porting and clearancing jobs. |
LOWE TECH Samba Member
Joined: June 22, 2016 Posts: 44 Location: SW Washington
Posted: Tue Nov 14, 2017 10:09 pm Post subject: Re: Preferred Tools To Make Chamber Radius |
A lot of whizz bang tools out there now days. Kinda sucks that you have to buy ‘em to see if they’re worth owning. One of the most “universal” widgets in my box is a 1/4” rod w/ a slot cut into the top using a thin zizz wheel or something. Make ‘em with different lengths, use different grades of emery and use different tools for rpm needs. |
