igotta40 Samba Member
Posted: Mon Nov 13, 2017 8:48 pm Post subject: Best replacement window crank |
I see a wide variety in pricing on the subject part. Advice please and thank you.
1973 Bay Window
igotta40 |
SGKent Samba Member
Posted: Mon Nov 13, 2017 9:02 pm Post subject: Re: Best replacement window crank |
even the originals broke once in awhile. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
airschooled Air-Schooled
SGKent Samba Member
Posted: Mon Nov 13, 2017 9:45 pm Post subject: Re: Best replacement window crank |
finished the rhyme for you Robbie - ...and ....
This little piggy went to the market,
this little piggy stayed home
this little piggy had roast beef,
this little piggy had none.
And this little piggy went wee wee wee all the way to buy this style handle:
Posted: Mon Nov 13, 2017 10:03 pm Post subject: Re: Best replacement window crank |
Was actually looking for input on vendor offerings from Bus Depot & Wolfsburg West
Good intel so far thanks |
Posted: Mon Nov 13, 2017 10:44 pm Post subject: Re: Best replacement window crank |
igotta40 wrote: |
Bus Depot is the US retailer for most of JustKampers products I liked above. Chances are, WW sells the same products, since WW and BD aren't manufacturers themselves.
www.airschooled.com |
Posted: Mon Nov 13, 2017 11:33 pm Post subject: Re: Best replacement window crank |
asiab3
Thanks, good to know |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6620 Location: Houston, Texas
Posted: Tue Nov 14, 2017 1:10 am Post subject: Re: Best replacement window crank |
Those look like the same ones as for Beetles. _________________ www.vwnos.com [email protected]
CanStan Samba Member
Joined: October 16, 2005 Posts: 1039 Location: Calgary, AB
Posted: Tue Nov 14, 2017 8:56 am Post subject: Re: Best replacement window crank |
I bought the cheap $3 handles. I think 2 of them broke this summer. They're cheap enough that I put a couple spares in the glove box for when they inevitably break again. I should just put a pair of the $50 ones on my wish list and not have to deal with it ever again. I think it's definitely one of those 'you get what you pay for' things. |
Joined: August 31, 2013 Posts: 12858 Location: North Carolina
tristessa Samba Member
Joined: April 07, 2004 Posts: 3992 Location: Portland, OR
Posted: Tue Nov 14, 2017 10:17 am Post subject: Re: Best replacement window crank |
Only if you hate the splines on your window regulator... |
russwiththebus Samba Member
Joined: September 25, 2007 Posts: 930 Location: Chattanooga, TN
Posted: Tue Nov 14, 2017 1:54 pm Post subject: Re: Best replacement window crank |
I've concluded they are all junk. Even Ratwell agrees: http://www.ratwell.com/technical/EssentialUpgrades.html#cranks
He recommends ones made by BugPack, but it seems like BugPack was sold to Empi a couple years ago.
Recently fitted some from a Mk2 Jetta and they're just about perfect. They included a spacer on the back to give it the proper distance from the door card, and even though they're all plastic, they feel much sturdier. Fits on the splines perfectly and still has a VW "look".
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Tue Nov 14, 2017 2:12 pm Post subject: Re: Best replacement window crank |
TDCTDI beat me to it... |
wcfvw69 Samba Purist
Posted: Tue Nov 14, 2017 2:28 pm Post subject: Re: Best replacement window crank |
From experience, what can 'contribute' to any window crank handle breaking is a hard to roll up window. Examples that cause this are the window regulators are not adjusted correctly. New glass felts are not seated all the way in the door. The window regulator mechanism is not cleaned of the 40 plus years of dirt/junk and old grease and then re lubricated.
After rebuilding my drivers door mechanism and insuring I did all the above, the window was still not rolling up and down very easily. I used good replacement parts as well. I still don't think the best "new" window felts are as correct as the original VW ones. I broke a couple of window winders handles too.
I then bought a can of silicone spray. I sprayed all the felt channels. I rolled the window up so the silicone would get on the glass in the channels as well. I then let the silicone dry and set up. It made the glass slide in the felts channels 100% easier. The window goes up and down almost perfectly. _________________ Contact me at [email protected]
The Samba member since 2004.
static Samba Member
Joined: March 22, 2002 Posts: 1831 Location: The High Desert
heimlich VWNOS.com
Posted: Tue Nov 14, 2017 5:01 pm Post subject: Re: Best replacement window crank |
That's ridiculous but I bet they will never break again. _________________ www.vwnos.com [email protected]
Hoody Samba Member
Posted: Wed Nov 15, 2017 9:41 am Post subject: Re: Best replacement window crank |
Genuine VW Brazil are readily available but you have to do a little searching. |
static Samba Member
Posted: Wed Nov 15, 2017 9:57 am Post subject: Re: Best replacement window crank |
There are also these (as seen on AliExpress). They look rugged enough, but they're not particularly attractive. I may consider the black ones.
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Wed Nov 15, 2017 12:38 pm Post subject: Re: Best replacement window crank |
If I were shopping for cranks, I'd spring for the GoWestys.
My philosophy is: "Do it once; do it right."
They are obviously robust in appearance, and should outlive any VW ever built. And they are made to fit the VW, not just a universal fit that may end up stripping out the splines on the door.
That's my $.02, which includes a 100% discount! _________________ -Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!" ---WildIdea
Bus ownership via emoticons:
---williamM |
airkooledchris Samba Member
Posted: Wed Nov 15, 2017 1:05 pm Post subject: Re: Best replacement window crank |
Be careful, every time someone around here says a well made product is too expensive certain folks will throw the entire community under the bus (see what I did there) and say it's the cheap owners who ruin everything/always/forever/harumph. |
