Mikedrevguy Samba Member
Joined: October 15, 2008 Posts: 2240 Location: Medford, OR
Posted: Tue Nov 14, 2017 3:14 pm Post subject: Installing fuzzy window scrapers on 914 |
Are the fuzzy scrapers intended to be longer than the rail they are installed in? If so, which direction should the extra length be oriented? Toward front of car or the rear?
Is the rail intended to be installed first and then the fuzzy scraper worked into the channel so the screws are covered up, or are the screws installed through the scraper?
Any sealer used when installing the rail?
Thanks,
Rev.[/img] _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
"The wise speak because they have something to say; while the foolish speak because they have to say something." Plato
Illigitimi non-Carborundum!! |
Joined: December 28, 2016 Posts: 279 Location: atlanta ga
Posted: Wed Nov 15, 2017 8:19 am Post subject: Re: Installing fuzzy window scrapers on 914 |
the rail is longer for the 73-76 cars and shorter for the 70-72 cars as the rear window end cap changed to accommodate the felt window guides in 73 after the 1000th car was built Therefore the fuzzy is cut to length to fit the appropriate aluminum holder |
Posted: Wed Nov 15, 2017 9:18 am Post subject: Re: Installing fuzzy window scrapers on 914 |
Thank you, Dr.
and, the screws go through the fuzzy?
How does the rubber scraper get cut to fit properly? _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
Posted: Wed Nov 15, 2017 11:48 am Post subject: Re: Installing fuzzy window scrapers on 914 |
the three screws go through the fuzzy and into the upper door shell. The squeegee inchworms in and left at current length. Will shrink to proper size |
