epowell Samba Member
Joined: September 23, 2015 Posts: 4733 Location: Czech (mostly) Vancouver (sometimes)
Posted: Thu Nov 16, 2017 5:34 pm Post subject: Re: Rebuilding 091 DM transmission (early diesel) |
Waldi wrote: |
Do you have a 5,43 r+p ? |
Yes _________________ www.edwardpowell.com |
Posted: Thu Nov 16, 2017 5:52 pm Post subject: Re: Rebuilding 091 DM transmission (early diesel) |
DanHoug wrote: |
if you have 'the knack' you can do this, and as an instrument builder you probably do. i did my 091/1, first trans ever, and so far so good. did i miss some things an experienced builder would do, sure. but i spent the labor money on parts and possibly ended up with a better trans than if a builder had rushed thru one for me. worst case scenario, you screw up a transaxle. whatever, buy a different one. none of this is like it is flight related, where if you break down, you're quite possibly screwed for life. inconvienient and expensive, yes. life threatening, rarely.
Wow, your trans look beautiful - that is incredibly inspiring!
Yes, the most difficult thing about teaching is patience. I absolutely struggle with this when teaching music - however when I can fight being triggered, and allow the student to progress at his/her own rate, amazing achievements are possible. _________________ www.edwardpowell.com |
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Thu Nov 16, 2017 6:09 pm Post subject: Re: Rebuilding 091 DM transmission (early diesel) |
Waldi and I have both been doing waterboxer transaxles (091/1 & 094) almost exclusively for years, and these models do not require a jig. The earlier 091 DOES require a jig to do the job properly .. the risk being that an improperly positioned fork will cause the trans to pop out of gear or prematurely wear out the fork. I know. I've done MANY 113, 002, and 091s in a past life.
While the previous position of the fork can be measured on the shift rail (some have done this and gotten away with it), a jig is required to do the job correctly. This assures not only proper forward-aft position, but also the proper rotation on the rail.
With 4 transaxles available to you, you obviously have a spare housing. So, if you're confident that you're going ahead with the job, why not do it correctly? It would actually be easier.
While I can't explain exactly how to make your jig this moment, I will be able to photograph one for you in early December. As they say, a photo (or two) is worth 1,000 words. _________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
AndyBees Samba Member
Joined: January 31, 2008 Posts: 2331 Location: Southeast Kentucky
Posted: Thu Nov 16, 2017 7:32 pm Post subject: Re: Rebuilding 091 DM transmission (early diesel) |
ePowell,
Allow me to clarify.
I "mark" the position of the forks on the shifting rods...... at least two marks for reference. It is a very good idea to take pics for reference... pics that clearly show the marks and their relationship to the forks on the rods.
Yes, I have two Bentley Manuals, 80-84 and 80-91, that have complete info to disassemble and re-assemble the various Vanagon trannies.
No PayPal on the Pinion Nut socket ......... got to come up with those references, as, my socket is not for sale, loan only! The cash (PayPal) would be useless to me when I need the socket.
The suggestion to pressure wash is so that you will have a clean tranny to work with ....... paint it, sand blast, etc., is your decision! Pressure washing is all that's necessary in my opinion.
Here are the only pics of my tranny uploaded to the Samba Photo Gallery..
Below, empty case pushed against a Diesel Bell Housing and no carrier on the other end.
Below, is the carrier without the shifter nose. This is where the metal plate goes that I mentioned in the other post. I have photos somewhere...
EDIT: This info may already be posted somewhere... excuse me if it is. Anyway, this may be helpful to you and those following.
Below is a list of Vanagon Transmission codes with gear ratios, etc. (my tranny is the last one on the list)
Below, is a reference as to where you can find your Tranny code and build date.
Hope this is helpful.. _________________ '84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
1983 Air-cool, 225k miles, 180k miles mine. Seven trips to Alaska from 1986 thru 2003. |
Waldi Samba Member
Joined: February 28, 2014 Posts: 1752 Location: Germany
Posted: Fri Nov 17, 2017 1:25 am Post subject: Re: Rebuilding 091 DM transmission (early diesel) |
Waldemar Sikorski wrote: |
Tell me more. |
I use the transparent oil.
https://owatrol.com/en/owatrol-oil/ |
Posted: Fri Nov 17, 2017 2:06 am Post subject: Re: Rebuilding 091 DM transmission (early diesel) |
gears wrote: |
While I can't explain exactly how to make your jig this moment, I will be able to photograph one for you in early December. As they say, a photo (or two) is worth 1,000 words. |
Thanks Gears, I have no doubt what you are saying is completely true. Once I get deeper into the project I will know for certain which housing to use as a jig, and I won't need that until at least March so there is no hurry THANKS! _________________ www.edwardpowell.com |
Posted: Fri Nov 17, 2017 2:50 am Post subject: Re: Rebuilding 091 DM transmission (early diesel) |
gears wrote: |
Waldi shows all but the last one (jig), which can be made by cutting windows in an old main case. |
I see, so essentially the jig made from a housing simulates the 'real' housing, and in the jig housing you cut holes/windows to be able to see what you are doing as well as get your hands in there.
In these photos I can see that the 'shift end' of the tranny has 2 short separate mini-housing which both can come off... the inner is called the 'gear carrier' and the outer is the 'shift housing'.
gears wrote: |
That jig is a precision machined tool meant to bolt the two shafts and intermediate housing to. |
When you say "intermediate housing" - I guess you mean the 'gear carrier'/'shifthousing' unit? [anyhow, your pics will clarify all I'm sure ]
Here is that jig in action.
gears Samba Member
Posted: Fri Nov 17, 2017 9:07 am Post subject: Re: Rebuilding 091 DM transmission (early diesel) |
Yes, exactly. Both VW and translation have changed nomenclature over the years (gear carrier / intermediate housing).
You can see from that photo exactly where you would cut a large section of the main case away to simulate a jig. The larger the window, the more light gets in to really see what's going on. So a window on the opposite side is a good idea, too.
I'd highly recommend that you obtain a Bentley. That's the first "tool" you should consider. Anyone working on their own car needs a factory level manual for reference. The Bentley has errors in it, but we've already cataloged most of them. _________________ aka Pablo, Geary
'87 Syncro GL 2.5
Posted: Fri Nov 17, 2017 9:56 am Post subject: Re: Rebuilding 091 DM transmission (early diesel) |
gears wrote: |
I'd highly recommend that you obtain a Bentley. That's the first "tool" you should consider. Anyone working on their own car needs a factory level manual for reference. The Bentley has errors in it, but we've already cataloged most of them. |
AndyBees wrote: |
OK, I have this manual...
...I just now realized that in fact it does contain a huge amount of material pertaining to gearbox rebuilding > gonna study that now.
What about this manual...
...is it wise to get this one too? _________________ www.edwardpowell.com |
Posted: Fri Nov 17, 2017 10:32 am Post subject: Re: Rebuilding 091 DM transmission (early diesel) |
I have practically every Bentley manual from 2005 back on VWs, including those pictured.... and a few on BMWs. _________________ '84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
Posted: Fri Nov 17, 2017 10:48 am Post subject: Re: Rebuilding 091 DM transmission (early diesel) |
As well as the 4 trannys I have, I also have the innards of a slaughtered DK 091 excluding the RP + housing. Right now I am slowly slowly working thru this pile of parts - along with the diagnostic section of the LONG CD --- and attempting to learn more about what is and what is not acceptable.
Here are 15 photos - can anyone find anything unacceptable in these?
I myself could not yet find anything obviously unacceptable --- some of the bearing surfaces seems slightly worn, but they still seem nice and smooth.
The gears I have looked at don't show any defects.
The tiny little gear teeth on 1st gear don't look perfect - but still the ware does not seem extravagant - there still seems to be some definition in the tooth flanks.... but perhaps this amount of ware in not acceptable?
I show one synchro here which to me seems pretty healthy, but I guess in any case all synchros should be replaced?
Finally, I show 1st gear needle bearing... which to my eyes also looks OK, but I'm also assuming that all needle bearings should also be replaced?
gears Samba Member
Posted: Fri Nov 17, 2017 11:09 am Post subject: Re: Rebuilding 091 DM transmission (early diesel) |
I'm gone for the rest of the day, but a couple comments:
It is quite difficult to "OK" parts based on photos.
New operating sleeves (sliders) are among the parts that should be replaced in every rebuild (along with bearings etc).
Some of these early 091 idler gears are silly cheap right now from Weddle.
The gear below would be rejected because of the wear on the engagement teeth. This will likely begin popping out of gear pretty soon.
'87 Syncro GL 2.5
Posted: Fri Nov 17, 2017 12:02 pm Post subject: Re: Rebuilding 091 DM transmission (early diesel) |
gears wrote: |
Sorry for silly question, but when you say "idler gear" > does it work something like this: A "gear" is in fact a 2 gear set (one on each shaft) which are running together all the time. One gear in these pairs is always permanently attached to 'a' shaft (1 - 2 to the main shaft... 3 - 4 to the pinion shaft), while the other gear of a particular pair is by default NOT attached to a shaft, therefore when that 'free-floating' gear is NOT "engaged" it is "idling" > therefore these free-floating gears are the Idler gears.
gears wrote: |
It is quite difficult to "OK" parts based on photos. |
Of course - it was more just to give me a rough idea of how to evaluate things.
gears wrote: |
New operating sleeves (sliders) |
"Slider hubs" is another term I assume.
gears wrote: |
OK... I didn't know how much ware can be tolerated... the wear here doesn't seem to me too extremely, but I trust what you are saying. _________________ www.edwardpowell.com |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17153 Location: Retired South Florida
Posted: Fri Nov 17, 2017 12:29 pm Post subject: Re: Rebuilding 091 DM transmission (early diesel) |
When you go to select a gear, the shift fork moves the slider/operating sleeve towards the gear you intend to select. That movement forces the brass syncro ring onto the cone of the gear you intend to select. That stops the gear from rotating so that the slider/operating sleeve can move up over the brass syncro ring and on to the little teeth Gears pointed out. At that point the gear is selected.
You will rarely see the outer teeth of a gear wear unless they sheared off, normally the wear is on the engagement teeth, the syncro ring, and the slider operating sleeve.
To practice, there would be nothing wrong with doing your first rebuild with old parts just to gain familiarity, but for a rebuild, you'd want to change all the wear items.
Also, gears are in pairs one gear is fixed and the partner is on a needle bearing free to float until selected. Reverse is a little different in that it adds a 3 rd gear to a pair which in physics changes the final rotation direction. _________________ ☮️ |
Posted: Fri Nov 17, 2017 1:58 pm Post subject: Re: Rebuilding 091 DM transmission (early diesel) |
MarkWard wrote: |
When you go to select a gear, the shift fork moves the slider/operating sleeve towards the gear you intend to select. That movement forces the brass syncro ring onto the cone of the gear you intend to select. That stops the gear from rotating so that the slider/operating sleeve can move up over the brass syncro ring and on to the little teeth Gears pointed out. At that point the gear is selected. |
Thanks for clarification... I have all these spare gears sitting here now in front of me (like toys ) and I am fitting them together and visualizing how it all works. One thing I'm still confused about it that, as I can see is that both 'partners' of all the 'gear pairs' are at all times engaged with eachother however (while in neutral or otherwise) one partner is 'fixed' and the other is 'free' >>> but still they are both always engaged with eachother which means that when revs are high the fixed partner will cause the free partner to spin faster and vise versa. So how can it be that when the slider forces the syncho onto the cone it "stops the gear from rotating"? If it would stop the gear from rotating then wouldn't that force the entire engine from rotating since the fixed partner would simultaneously be forced also to stop because they are engaged at all times together? >>> ....isn't it more accurate to say that the synchro will cause the slider to begin to spin at the same speed as the idler gear so they can be connected (thereby engaging the gear to both shafts)? Probably I'm still missing something here....
edit: wait a minute > I forgot that the shift happens when the CLUTCH is engaged thereby disconnecting the main shaft from the engine (momentarily)... so that means that in fact it would be OK to "stop" both shafts with clutch engaged. Wow..... is that what actually happens?
1) clutch engages
2) slider hub pushes synchro over cone thereby STOPPING the gear (and consequently both shafts > and fully engaging the new gear
3) clutch is released which send power again thru both shafts and thereby to the wheels.
But what I still don't 'get' is this... obviously the 'free' gear partner effectively becomes "fixed" (to the shaft) when the slider engages with it > this means that in some way the slider must be also 'fixed' to the shaft (as well as being able to 'slide' back and forth. I have a slider in my hand right now and I can't see how it can 'fix' to the shaft.
MarkWard wrote: |
Hey that's an excellent idea.... do a full practice run "rebuild" with all old parts. I will do that!
MarkWard wrote: |
but for a rebuild, you'd want to change all the wear items. |
So that means it is a must to change all:
- idler gears
- slider hubs
- synchros
- bearings _________________ www.edwardpowell.com |
Posted: Fri Nov 17, 2017 2:20 pm Post subject: Re: Rebuilding 091 DM transmission (early diesel) |
Maybe "slows" would be a better description.
Yes, all gears sets are always meshed. Just not "engaged". If you somehow engaged two gear sets at the same time, the transmission would be "frozen". Nothing would turn. Shifting/selecting a gear is actually "locking" a set. When you miss a shift, the grinding noise is the slider slipping past the engagement teeth on the floating gear.
It is always best to replace gears in sets even though the wear is on the floating gear engagement teeth. The reason is over time, they wear into each other. Introducing a non matched gear could make some noise that may not be desirable.
In my racing gear box. There are no synchronizer rings. There are large lugs on the face of the gear and matching lugs on the slider. You actually force the shift. I also shift with no clutch. These are sometime referred as dog boxes or crash boxes. Lots of fun to race, but would be terrible in city traffic. The other main difference is the gear teeth are straight cut not helical like stock gears. They make a lot of noise. It is almost deafening.
edit: the slider has several other pieces. The hub it slides on is splined to the shaft. Look at the inside of the slider and you can see the splines it moves on. There are also 3 metal lugs around the center of the slider, that are spring loaded and are forced against the brass syncro ring when the slider is moved forward. These are what fix the brass syncro ring to the slider assembly and keep it from spinning.
Here is an assembled slider assembly.
Posted: Fri Nov 17, 2017 2:43 pm Post subject: Re: Rebuilding 091 DM transmission (early diesel) |
MarkWard wrote: |
Wow they must be made so incredibly precisely to all 4 be emeshed... but that is clearly why the gears over time get worn in to eachother (as pairs) because of the microscopic inaccuracies in the sizes of the gears would force that.
MarkWard wrote: |
Yes yes! It is all finally clear now... I found the OTHER part of the slider hub, and can clearly see now how it both affixes to the outer part of the slider and to the shaft via these splines... mine is missing the lugs.
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4790 Location: Bemidji, MN
Posted: Fri Nov 17, 2017 3:10 pm Post subject: Re: Rebuilding 091 DM transmission (early diesel) |
this is the 3/4 slider hub that was cracked in my 091/1... a pre-emptive rebuild at 225K miles on a perfectly functioning transaxle. the replacement slider has rounded holes vs the square cut and hence less focal stress. it's an absolute must to replace the old style with the new.
-dan |
gears Samba Member
Posted: Fri Nov 17, 2017 3:58 pm Post subject: Re: Rebuilding 091 DM transmission (early diesel) |
Edward, that is a 1st/2nd slider hub, which doesn't have a full compliment of teeth like the 3rd/4th hub has.
Dan, that is a cracked 091/1 slider hub. The 091 hubs don't readily crack like the 091/1 (094) hubs. That doesn't mean they've never cracked or that they can't wear out .. just that cracking isn't a common problem with those. _________________ aka Pablo, Geary
'87 Syncro GL 2.5
Waldi Samba Member
Posted: Fri Nov 17, 2017 4:06 pm Post subject: Re: Rebuilding 091 DM transmission (early diesel) |
You dont need to replace the needle bearing from 1st and 2nd gear if the inner and outer surface is ok.
3rd needle bearing is 3€, 4the metal cage needle bearing is 12€.
This surface lookis not good on the pic
https://www.thesamba.com/vw/gallery/pix/1713601.jpg
Also this one from 4th gear with length stripes. If they go away in a drill bench with water sand paper the shaft can be used. Hard to say from here.
https://www.thesamba.com/vw/gallery/pix/1713590.jpg
The idler gear showed by Gears is a risk. If didnt drive this box before without out jumping gear, i would not install it.
To check the messing synchron rings you need to messure the distance between the synchronring and the gear.
Everything over 1mm is good. 0,5mm is minimum.
You can buy all parts from me.
Edit:
You can ask for the maual in the Austrian forum.
I have the pdf somewhere, but cant find in atm. |
