hazmatty3614 Samba Member
Joined: June 07, 2016 Posts: 252 Location: Wanaque, New Jersey
Posted: Wed Nov 15, 2017 4:37 am Post subject: Distributor issue/question |
I posted recently about the 1600 not running well after a tune up kit from JBugs. I learned from the PO that he put a tune-up kit in it that is intended for an 009, but this is an SVDA. The JBugs site says it will only work with an 009.
http://www.jbugs.com/product/VW_TUNE_UP_KIT_3.html
I assume this is the root of my idle and stalling issues. Why would the rotor, cap, and Pertronix points conversion be so incompatible with the distributor?
I have ordered a Pertronix 12v SVDA distributor with electronic ignition pre-installed, and a new Bosch blue can coil just to have all new. Can I expect this to improve how the car runs? |
bhartwell59 Samba Member
Joined: December 28, 2014 Posts: 792 Location: dallas, tx
Posted: Wed Nov 15, 2017 6:43 am Post subject: Re: Distributor issue/question |
maybe... what carb do you have? _________________ '74 Zambezi green Ghia vert, autostick, 101k
'87 Jeep Wrangler, 4.2, 330k |
Posted: Wed Nov 15, 2017 7:10 am Post subject: Re: Distributor issue/question |
It’s a Chinese H30? Knockoff. |
Figment Samba Member
Joined: October 27, 2016 Posts: 218 Location: Connecticut, USA
Posted: Wed Nov 15, 2017 7:30 am Post subject: Re: Distributor issue/question |
Never afraid to ask the dumb question: Did you check/reset the ignition timing after changing out all of those ignition parts? _________________ '71 Ghia coupe |
Posted: Wed Nov 15, 2017 7:50 am Post subject: Re: Distributor issue/question |
Yes I timed it to 7.5 BTDC. Tried 0 TDC also. |
NOVA Airhead Samba Member
Joined: July 20, 2005 Posts: 5221 Location: Richmond, VA
wcfvw69 Samba Purist
Posted: Wed Nov 15, 2017 8:12 am Post subject: Re: Distributor issue/question |
hazmatty3614 wrote: |
All the Pertronix distributors are made in China and have poor reputations. Many previous threads on this site with folks struggling to make them work.
My question is what is your end goal here? If it's for a reliable, easy to start and run VW engine with excellent drivability, you should consider stock. Many folks are selling restored Bosch SVA distributors for $100-150. You can buy a restored , original German Solex carb from Tim at Volkzbitz.com as well.
The carb needs to match the distributor. Many people have done exactly this and are now rewarded with excellent running engines. _________________ Contact me at [email protected]
The Samba member since 2004.
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6621 Location: Houston, Texas
Posted: Wed Nov 15, 2017 10:33 am Post subject: Re: Distributor issue/question |
Buy a restored distributor, rebuild your own, or have someone rebuild one for you. _________________ www.vwnos.com [email protected]
c21darrel Samba Member
Posted: Wed Nov 15, 2017 12:28 pm Post subject: Re: Distributor issue/question |
As you can all tell, I’m new to this. I apologize for not knowing the answers. I appreciate the feedback. I think I’m going o get the car to the nearest expert even though it will cost me $150 to get it there. |
heimlich VWNOS.com
Posted: Wed Nov 15, 2017 1:59 pm Post subject: Re: Distributor issue/question |
There are some good new parts. There are better NOS parts. Just come and ask around here and folks can help you out. _________________ www.vwnos.com [email protected]
fes Samba Member
Joined: January 26, 2011 Posts: 999 Location: Prince Edward Island
Posted: Wed Nov 15, 2017 2:17 pm Post subject: Re: Distributor issue/question |
X2^^
Before you start playin "parts darts" and paying $150 to get it to wherever,
Let's go through some things together..
First,give us some history..did the car ever run right and what has been done since..
I looked through your gallery and it seems you have some sort of generic PICT 34-3..and an Svda dizzy..
Lets start here..
Get the car running and start searching for vacuum leaks,use unlit propane,starter fluid or carb cleaner (messy)..start at the throttle shafts on the carb, around the base and so on..cheap carbs can be known for having cheesey play in certain areas and a warped base.. just spray all over the fasteners/visible connections of the carb, and listen for RPM change. (having a non KIDDE fire extinguisher near never is a bad idea)
Its hard to tell from your photo,but it looks like you have a dual port..spray around the rubber or silicone boots,,then work your way down to the manifolds where the connect to the heads..
No air leaks? good..shut her down
Now take the hose off the carb from the vacuum can on the distributor and take the cap off..manually move the advance plate and suck air with your mouth through the hose..like a straw and hold your tongue on it..then let go of the advance plate and see if it stays..let the pressure go from your mouth and see if it snaps back....this sounds easier than it is sometimes..
Assuming your points gap/dwell are correct,the felt on the shaft under the rotor is lubed with a couple drops of oil,advance plate G spots are lubed.. and every thing seems sound, put everything back together,disconnect the hose from the vacuum can and plug it (the hose)with a golf tee,(after hooking the hose back up to the carb..)
The timing should now be set to 28 degrees +/- BTDC at over 3000 rpm..this is tricky to do on a stock pulley and there are measurements you use and also a template that can be downloaded..personally,I swear by quality degree mark pulleys,not for everyone though..where the timing lands at idle after this procedure is where it lands..
There is also other things to be tested,like the condenser and the coil..but we will let you fill in the blanks a little first as to what has been changed since you've had the car etc.
There is so much info out there,and if you don't have the proper tools,(timing light,dwell meter) and manuals..save your $150 for that kind of long life investment..Good Luck!!
PS,get that acorn fuel filter far away from the distributor,make sure all your fuel lines and connectors are sound and try and block off the random sheetmetal holes in your engine tin..the idea is to hold a work light under the motor in the dark and see as little light above as possible
Sorry for the long winded post
-Matt _________________ '68 Campmobile-Pedro
'15 Golf-Stella Blau
'56 Oval-The Turd (for now) |
KGCoupe Samba Member
Joined: July 01, 2005 Posts: 3580 Location: Putting the "ill" and "annoy" in Illinois
Posted: Thu Nov 16, 2017 9:57 am Post subject: Re: Distributor issue/question |
c21darrel wrote: |
Quote: |
It’s a Chinese H30? Knockoff |
Someone should be waving a red flag.
So you're saying that it's no coincidence that the Chinese flag looks like this?
Posted: Mon Nov 20, 2017 12:20 pm Post subject: Re: Distributor issue/question |
Today I swapped out the SVDA Distributor with a brand new one and a brand new blue Bosch coil. The coil was not reading within the ranges in the Bentley.
Static timed it all to 7.5 BTDC and cranked it up.
Set the idle at 950 with the dwell tach. It was running better. No missing at least. (My smoke issue is an ATF leak onto the exhaust.)
As soon as I gave it a touch of throttle, it died and wouldn't restart. It's sounding more like a carb issue to me now.... |
fes Samba Member
Posted: Mon Nov 20, 2017 12:35 pm Post subject: Re: Distributor issue/question |
[quote= It's sounding more like a carb issue to me now....[/quote]
It's likely..did you test for air leaks? I ask this because air leaks cause the car to run lean.. And with the choke closed,it's enriching the mixture,essentially tricking the engine into running normal..as soon as you kick the throttle down,it opens the choke and leans everything way out again..causing the engine to stall usually..You still don't say what manufacturer of that carb you have now..It is possible that the idle circuit passages are blocked with crap internally,the jets (main volume jet and idle jet )are incorrect..
Also,you should test the idle shut off solenoid as well.
Not sure of your local VW community,but is it possible to borrow a known good carb from someone for the test? _________________ '68 Campmobile-Pedro
Posted: Mon Nov 20, 2017 12:43 pm Post subject: Re: Distributor issue/question |
Pertronix SVDA with Ignitor module.
Bosch Blue Coil
No-name carb??
What I checked today is the coil output, static timing, and the accel. pump is squirting. I also adjusted the idle to 95 for the Autostick.
The carb has no markings on the sides. Not sure if there is something on the back. I think this may be part of the problem.
When I bought the car it ran. Really poorly, but it ran.
I haven't observed a vac leak when spraying the connections.
I don't know if I should pull the carb and rebuild or buy one. |
Posted: Mon Nov 20, 2017 12:53 pm Post subject: Re: Distributor issue/question |
did you spray around the carb throttle shaft bushings? those pesky things wear and start to leak _________________ '74 Zambezi green Ghia vert, autostick, 101k
fes Samba Member
Posted: Mon Nov 20, 2017 12:57 pm Post subject: Re: Distributor issue/question |
Well If you say it always ran like crap,then you're kind of between a rock and a hard place as far as diagnosis goes.
Call me crazy,but maybe the PO was having same problems as you have,decided to buy a new carb,thinking it was the problem,didn't fix it and gave up..
You can never go wrong with a known,rebuilt and tested proper Solex from some of the suppliers like Volkbitz,He tests and tunes before sending it off..
IT is possible that that carb you have now is garbage..Chinese copy's are only as good as the young child getting paid dick all a day to put it together.some are better than others.
I am however,finding good results with the newer Empi pict 34-3s _________________ '68 Campmobile-Pedro
