Retrovan Samba Member
Joined: July 15, 2011 Posts: 524 Location: Port Elisabeth - RSA
Posted: Sun Oct 21, 2018 3:03 am Post subject: Re: v8 fassty |
fassty v8 wrote: |
retrovan,
i have got a box of tricks that run the corsa b steering rack from a guy on ebay, i will put a pic on tomorrow.
Thanks, could you also give me his details by PM.
Thanks Herman _________________ 1968 Fastback Type 4 2 Lt. twin 34 ICT's (Red)
1952 Split Beetle 1835cc. twin 34 ICT's (Azur blue)
1975 Split Bus Type 4 1914cc. twin 34 ICT's (wh/aqua)
1972 Bay Panel-van with type 4 2 Lt. twin 34 ICT's (white)
2019 Beetle Flatbed Truck called MeFusco
1973 FT Hahn SP - Project 1776cc |
fassty v8 Samba Member
Joined: November 17, 2017 Posts: 67 Location: LANCASHIRE
Posted: Mon Oct 22, 2018 10:14 am Post subject: Re: v8 fassty |
made good progress over the last couple of days,
now have the bulkhead panel nearly done and started to make the corner pieces to jion it to the door pilliars, heres some pics.
really happy with how its came out, before i start the floors and trans tunnel i am going to get the rear wheel tubs made as the floors will tie into them so i need to get them done first. |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22425 Location: Kimball, Mi
Posted: Mon Oct 22, 2018 3:05 pm Post subject: Re: v8 fassty |
Is that going to be a "bolt in" panel? Just wondering where your steering column bit are going to pass thru. Looks good though. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sun Oct 28, 2018 9:54 am Post subject: Re: v8 fassty |
all the panels will be welded on once there all done.
bobnotch,
the steering goes through at a funny angle so it will pass through the bulkhead nearer the trans tunnel.
been a very busy week this week, got a lot done. first up was to make the rear wheel tubs.
started off by making some wooden templates to help form a rounded edge.
from this to this
then made up the tubs 17" wide to allow for trimming and fitted them in place.
then made up the centre panels to cover the inner chassis rails.
had to cut more into the body to get more wheel clearance to fit the tubs.
bit more to do with the rear panels and then i am on the main floor sections. |
Posted: Sun Nov 04, 2018 9:49 am Post subject: Re: v8 fassty |
more done this week, floors and the back part of the transmission done.
ordered the rear coil overs today so theres still loads to do but i have set my self the target of having it of the jig and sat on its wheels for xmas week. |
Jason37 Samba Member
Posted: Sun Nov 04, 2018 5:27 pm Post subject: Re: v8 fassty |
You’re a bead rolling maniac!!! Looks really good and keep the updates coming. |
Posted: Sun Nov 11, 2018 9:16 am Post subject: Re: v8 fassty |
bit more done, finnished of the trans tunnel.
and this weekends mission has been the bulkhead panel. this has took a good 12 hours of fabrication and im glad its 95% done.
and the rear coilovers came this week so there is them to make mounting brackets for.
Posted: Mon Nov 19, 2018 7:56 am Post subject: Re: v8 fassty |
folded up some channels, welded some 6mm thick by 50mm wide strip inside them and drilled and tapped them and these are the seat mounts.
im using mazda mx5 seats as they mount nice and low and are really compact.
i have also got the connection from the steering rack to the bulkhead done but before i connect that to the column i need to weld all the floors into the shell but again i cant do that untill i get the lower seat belt mount in as with the floors in i wont be able to weld them fully in.
more soon |
Posted: Mon Nov 19, 2018 2:28 pm Post subject: Re: v8 fassty |
fassty v8 wrote: |
more soon |
Are you really tall? Just asking, as it seems like the seats are sitting quite a ways back. It might just be the camera angle too. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Wed Nov 21, 2018 12:37 pm Post subject: Re: v8 fassty |
the seats are slide back, they will slide forward on the runners.
few pics from the last couple of days.
made up some rear inner panels, these still boxes welding in to take the seat belts.
audi tt handbrake fitted.
trimmed the rear wheel tubs which took forever
got the rear wings to fit but the tubs still need a little trimming but i think i will leave that untill its all welded. |
Posted: Wed Dec 05, 2018 11:32 am Post subject: Re: v8 fassty |
had a few days to get stuff done and made some really good progress.
had a list of jobs that wanted doing before i could cut it off the jig.
all the floors done, body mounts done, seat belts done, front shock mounts done, rear shock mounts done, and the front wings primered.
ride height is pretty spot on with ground clearance being 5" under the centre of the fassty.
fassty comes off the jig on sunday, more pics soon. |
dlmcclou Samba Member
Joined: November 12, 2018 Posts: 21 Location: Houghton MI
Posted: Wed Dec 05, 2018 12:05 pm Post subject: Re: v8 fassty |
Wow man!! You sir are an artist. I only wish I could fab that well. Great build so far. Finish it up so you can post videos of you doing smokey burnouts. _________________ '70 Type 3 Squareback |
Absoluteyeti Samba Member
Posted: Wed Dec 05, 2018 2:45 pm Post subject: Re: v8 fassty |
This is amazing! |
Posted: Sat Dec 08, 2018 8:33 am Post subject: Re: v8 fassty |
thanks for the comments,
took a bit of doing today but i managed to get the body of and get the chassis on its wheels on the floor, bolted the engine and box in place and it sits how i had planned it so thats a big thumbs up.
while chassis is body free i got the body mount brackets welded up.
while the body is off i may as well sort out some of the welding thats wants doing on the under side. |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3445 Location: San Diego
Posted: Sat Dec 08, 2018 8:54 am Post subject: Re: v8 fassty |
Your Fab and welding skills are off the chart! Great work |
oxsign Samba Member
Joined: February 19, 2006 Posts: 607 Location: Sanford, FL
Posted: Sat Dec 08, 2018 8:57 am Post subject: Re: v8 fassty |
Fantastic work as always. I do have to say, one of the coolest things (for me) is how natural the add 6" to the front looks now that it's all one color. It doesn't have that weird stretched look. Very cool.
Also, What are the seats out of that you have mocked up in there? _________________ 1971 Squareback, fully bagged, 1776.
Build thread here.....
https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 |
Posted: Sat Dec 08, 2018 9:21 am Post subject: Re: v8 fassty |
cheers.
seats are mk2 mazda mx5. |
Posted: Sun Dec 16, 2018 12:05 pm Post subject: Re: v8 fassty |
after a bit of welding on the inner sills it was time to sit the body on to see how it looked.
the most important thing about this car to me is the stance, it has just got to be right and as you can see from the pics its about spot on. |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22462 Location: Escondido CA
Posted: Sun Dec 16, 2018 12:22 pm Post subject: Re: v8 fassty |
Yeah that looks pretty sick brother. Nice attention to detail with that stance. I thought in the end that stretched front would look weird, but it doesn't. Looks killer.
Nice to be able to see what was going on in your head all this time. Keep it up and you'll be in all the mags for sure! _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
