rtcwhunter Samba Member
Joined: February 13, 2016 Posts: 2 Location: South Carolina
Posted: Fri Nov 17, 2017 9:20 pm Post subject: Part numbers for engine harness connectors and pins |
Looking to see if anyone has a complete listing of part numbers for the engine harness connectors and pins (minus the ECU and ICSU plugs). Looking to build a new harness from scratch and have only been able to find the FI plug number and the pin numbers for the ICSU. Any help would be greatly appreciated |
ohhorob Samba Member
Joined: September 26, 2013 Posts: 212 Location: Santa Cruz
Posted: Sat Nov 18, 2017 8:33 am Post subject: Re: Part numbers for engine harness connectors and pins |
Not sure there's any real difference between Digijet and Digifant, but you haven't mentioned which ECU you're working with (appears to be Digifant, based on tracking down stabiliser parts, which Digijet doesn't have).
This post should get you started .. https://www.thesamba.com/vw/forum/viewtopic.php?p=8515208#8515208
These kind of specialist tools are silly expensive, so you might try and rig up something that works similarly instead of purchasing -- https://www.digikey.com/product-detail/en/te-conne...-ND/688340 (not required for insertion, only removing the wire & contacts from the connector) _________________ "Gundy" - '85 Westfalia
GoWesty 2300cc, Digijet |
plummerdesign Samba Member
Posted: Thu Nov 23, 2017 9:09 am Post subject: Re: Part numbers for engine harness connectors and pins |
Just a thought...KYLE Automotive in Ohio does a great job on harnesses at a very affordable price. Have purchased two from them (one for each bus) and relished the time saved at the workbench. _________________ It is old and green and it makes me grin.
1984 Westfalia 1.9 |
