blue65 Samba Member
Joined: March 10, 2016 Posts: 123 Location: Melbourne Australia
Posted: Sat Nov 18, 2017 12:24 am Post subject: 1641cc Engine pinging/ rattle noise. |
Noise questions. There is a slight clatter when I start the engine and let it idle. Tinwear is all secure. I also get slight pinging or a rattle in the engine on 3rd and 4th gear when the revs are a bit low. On 3rd gear it noticeable only at low speed or at high speed when i reach the top of the hill. More noticeable in 4th gear when its under load and i try to pump extra gas. What could be the problem?
Ill be taking the beetle 1641cc engine to see my mechanic in the Monday morning. |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
Posted: Sat Nov 18, 2017 7:07 am Post subject: Re: 1641cc Engine pinging/ rattle noise. |
Your description sounds like "pinging" or pre-detonation. This can be improper timing, overheating, or too high compression for the fuel you are using (and maybe a couple other things) and can cause significant damage to the engine if not corrected.
I would take the mechanic for a ride to make sure the shop is aware of this issue before they get started on anything else. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Sat Nov 18, 2017 7:56 am Post subject: Re: 1641cc Engine pinging/ rattle noise. |
And when was the last time the valves were adjusted? You will normally get some tapping when idling until the car warms up some and then it should get quieter. But totally agree that it sounds like detonation...Don't drive it more than absolutely needed until you get this corrected. _________________ D-Dubya Manx clone - 63 Short pan,1914.
blue65 Samba Member
Posted: Sun Nov 19, 2017 7:03 am Post subject: Re: 1641cc Engine pinging/ rattle noise. |
The valves were adjusted 3000 miles back, or 4 months ago.
I blamed it on my driving style - pumping gas when the revs are not high enough.
But sometimes it can't be helped. I'm changed down to 2nd gear when going up a hill and it pings.
Its also noticable on 4th gear if I'm on a slight incline. |
blue65 Samba Member
Posted: Mon Nov 20, 2017 3:59 am Post subject: Re: 1641cc Engine pinging/ rattle noise. |
I sent it to my veteran vw mechanic this morning. He adjusted the carb jet by a bit to let in more fuel. But now the engine tends to stall when idle. |
Posted: Mon Nov 20, 2017 9:53 am Post subject: Re: 1641cc Engine pinging/ rattle noise. |
The only thing he can "adjust" is the idle mixture. Otherwise they would have needed to replace the main and or idle jet with larger ones to let in more fuel.
You sure this person knows what they are doing? _________________ D-Dubya Manx clone - 63 Short pan,1914.
Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5304 Location: Central Florida
Posted: Mon Nov 20, 2017 10:09 am Post subject: Re: 1641cc Engine pinging/ rattle noise. |
andk5591 wrote: |
You sure this person knows what they are doing? |
But he’s a veteran VW mechanic!!! _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
blue65 Samba Member
Posted: Thu Nov 23, 2017 1:52 pm Post subject: Re: 1641cc Engine pinging/ rattle noise. |
Hi all, works ok now. Mech fixed it.
To be fair to him, I'm probably translating his tech speak incorrectly. |
