68IHscout Samba Member
Joined: March 10, 2010 Posts: 3122 Location: santa ana ca
Posted: Sat Nov 18, 2017 10:13 am Post subject: Starter solenoid? |
On my second starter (rebuilt) once in a while the starter fails to engage i can hear the solenoid click but the starter does not engage ,battery fully charged we push start it and the starter will work for about a week more less then it happens again ,could this be the solenoid any input would appreciated |
mukluk Samba Member
Posted: Sat Nov 18, 2017 10:54 am Post subject: Re: Starter solenoid? |
Could be a solenoid issue, but more likely it's either a problem with getting sufficient volts/amps to the solenoid (wiring problems), or a mechanical problem with the starter bushing.
Did you replace the starter bushing when you replaced the starter? Have you verified you are getting 12V to terminal 50 on the solenoid when you turn the ignition to START? _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Sat Nov 18, 2017 10:59 am Post subject: Re: Starter solenoid? |
Forgot to mention ,it is a 74 sb ill check the wiring and volts. |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6616 Location: Houston, Texas
Posted: Sat Nov 18, 2017 10:33 pm Post subject: Re: Starter solenoid? |
Could be the wiring. Keep up with the push starting and you will be replacing the clutch too. _________________ www.vwnos.com [email protected]
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
Posted: Sun Nov 19, 2017 4:51 am Post subject: Re: Starter solenoid? |
kawfee wrote: |
Could be the wiring. Keep up with the push starting and you will be replacing the clutch too. |
Push starting a car will have absolutely no ill effects on the clutch. Especially since a stock clutch is designed to handle 60+ HP. How much force can three people have on push starting a bug? Maybe a third of a HP.
As far as your starting problem, You need to safely jack up the car and take two voltage readings. Have someone turn the starter over and measure the voltage at the starter solenoid. During the same process, you also want to measure the voltage where the battery cable connects to the starter. Give us these numbers, and we can go from there. In reality, a current (amps) measurement would be better, but most people don't have a meter that can do this. _________________ 69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight= |
Posted: Sun Nov 19, 2017 7:54 am Post subject: Re: Starter solenoid? |
kawfee wrote: |
with in the last year i push started the car 2 times |
Posted: Sun Nov 19, 2017 7:58 am Post subject: Re: Starter solenoid? |
Multi69 , should the wire to starter be disconnected from solenoid when i run the starter test? |
Posted: Sun Nov 19, 2017 10:57 am Post subject: Re: Starter solenoid? |
Multi69s wrote: |
kawfee wrote: |
As far as your starting problem, You need to safely jack up the car and take two voltage readings. Have someone turn the starter over and measure the voltage at the starter solenoid. During the same process, you also want to measure the voltage where the battery cable connects to the starter. Give us these numbers, and we can go from there. In reality, a current (amps) measurement would be better, but most people don't have a meter that can do this. |
the wire at solenoid (disconected from starter )measurea 11.6v when turning key to starter ,the big wire to starter measures 12.3 v |
bluebus86 Banned
Posted: Sun Nov 19, 2017 11:27 am Post subject: Re: Starter solenoid? |
68IHscout wrote: |
Multi69s wrote: |
kawfee wrote: |
Now measure the voltage on the same terminal from the key switch with the wire connected to starter. make sure Bug is very secured, in neutral, attach your test leads and attempt to start her. observe voltage, it will drop a lot, but how much?
by meauring the voltage under load, rather than ot underload, as was done in your first test, you can determine if the circuit is capable of delievering enough current (amps) to operate the solinoid. a bad circuit with say a crummy single strand of wire left from the key switch, can deliver a full 12 volts when tested not under load, same for a dirty contact, or loose crimp joint.
Now even though that tiny single strand of wire delivered 12 volts under no load, the moment you put a load on it, such as having it attempt to operate the solinoid, or maybe light a bulb, or turn a motor, the moment a load is put across, if the supply circuit, the input wires, are not good enough, big enough, clean enough, crimped enough, etc.. then load draws the voltage down, this we call VOLTAGE DROP. now a fat wire with good connections will also give a nice 12 volt reading un loaded, but when you load it, that fat wire and clean contacts flow the large current need with ease, so there is very little drop in the voltge.
So retest with someome cranking the key switch tostart, and observe if you have lot of drop or not. If little drop is found, then you KNOW you key switch, and all the associated wireing is probably just fine. If you get a huge drop, thatbis an indiaction of either a short in the circuit to ground, or a bad connection in the circuit
goodmluck, now hunt down for drops! Bug On! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
wcfvw69 Samba Purist
Posted: Sun Nov 19, 2017 12:07 pm Post subject: Re: Starter solenoid? |
It's always a great idea to remove the transmission ground strap and clean it squeaky clean and to bright metal. Reinstall it. The, remove all the wires from the starter posts and clean them squeaky clean and to bright metal. If your battery cables are old, replace them. They are not expensive and they make a BIG difference in getting the proper voltage to the starter.
While you have the wires loose at the starter, make sure the connections are solid with no corrosion in them.
Most often doing these things above will dramatically improve starter issues. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Sun Nov 19, 2017 12:34 pm Post subject: Re: Starter solenoid? |
bluebus86 wrote: |
68IHscout wrote: |
Multi69s wrote: |
kawfee wrote: |
goodmluck, now hunt down for drops! Bug On! |
with wire hooked up to solenoid and working the starter it drops to 6.5 under load |
Posted: Sun Nov 19, 2017 12:36 pm Post subject: Re: Starter solenoid? |
wcfvw69 wrote: |
Most often doing these things above will dramatically improve starter issues. |
ground strap is new and clean ,negative at battery is alao new and clean ,positive cable is good and clean |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31378 Location: Hot Arizona
Posted: Sun Nov 19, 2017 12:53 pm Post subject: Re: Starter solenoid? |
68IHscout wrote: |
Yipes - should be over 9.6 volts (measured across battery terminals) while trying to start. So suspect a battery that fails under load.
Did you try a jump start from a running vehicle? _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Sun Nov 19, 2017 1:36 pm Post subject: Re: Starter solenoid? |
Cusser wrote: |
68IHscout wrote: |
Did you try a jump start from a running vehicle? |
i just fixed a small connection and now under load it givea me little over 9.5 |
Posted: Sun Nov 19, 2017 1:47 pm Post subject: Re: Starter solenoid? |
68IHscout wrote: |
Cusser wrote: |
68IHscout wrote: |
no jumping from other vehicle , i tested the battery under load it drops to 10.4 with a nice starter crank, it stopped working so i smacked the starter solenoid and it cranks fine after that |
sb001 Samba Member
Posted: Sun Nov 19, 2017 2:54 pm Post subject: Re: Starter solenoid? |
68IHscout wrote: |
68IHscout wrote: |
Cusser wrote: |
68IHscout wrote: |
But still no start?? Or is it working now? _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Posted: Sun Nov 19, 2017 2:59 pm Post subject: Re: Starter solenoid? |
sb001 wrote: |
68IHscout wrote: |
68IHscout wrote: |
Cusser wrote: |
68IHscout wrote: |
But still no start?? Or is it working now? |
it starts fine ,just once in a while the solenoid has a tantrum and it doesn't want to work |
Starbucket Samba Member
Posted: Sun Nov 19, 2017 3:09 pm Post subject: Re: Starter solenoid? |
Replace the solenoid they are cheap, yours has a problem internal, rust, varnish, etc. and sticks every so often, or think of the health benefits of pushing and run with it. |
Posted: Sun Nov 19, 2017 3:23 pm Post subject: Re: Starter solenoid? |
Starbucket wrote: |
will do |
