gregaz Samba Member
Joined: May 22, 2012 Posts: 407 Location: Phoenix, AZ
Posted: Sun Nov 19, 2017 10:18 am Post subject: Trans Tunnel Insulation 2017 |
I have my engine and trans out for a Bostig conversion (yay!), and decided to address the flaking and peeling insulation at the same time.
I am wondering, what are some year 2017 solutions for replacing it? Many new products are now readily available, including some advanced ones that we didn't have a few years back.
Over on VOG someone recommended 3M #08883 - and this sounds like a GREAT solution to me! Easy to "install," and add in the future if needed. Any thoughts on this? Anything else I should be considering?
THANKS IN ADVANCE!!!! |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17114 Location: Retired South Florida
Posted: Sun Nov 19, 2017 3:05 pm Post subject: Re: Trans Tunnel Insulation 2017 |
Can't recommend a particular one, but look in the Marine Industry. There are some good sound/heat products that hold up to damp environments. _________________ ☮️ |
WillSharp Samba Member
Joined: November 02, 2016 Posts: 199 Location: US 80424
Posted: Sun Nov 19, 2017 5:32 pm Post subject: Re: Trans Tunnel Insulation 2017 |
Here is what I did recently:
The insulation I got from Amazon for about $25. Is a fire proof foam insulation with an aluminum foil on it. It has a adhesive back which is nice. Getting it in was a b*tch with it sticking to everything. Sits in tight and looks good.
_________________ 1889 Syncro Adventure Wagon 3.3 SVX |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9798 Location: Mt Lemmon, AZ
gregaz Samba Member
Posted: Mon Nov 20, 2017 10:15 am Post subject: Re: Trans Tunnel Insulation 2017 |
WillSharp wrote: |
The insulation I got from Amazon for about $25. Is a fire proof foam insulation with an aluminum foil on it. It has a adhesive back which is nice. Getting it in was a b*tch with it sticking to everything. Sits in tight and looks good. |
That looks really good! |
