sdthing Samba Member
Joined: October 01, 2017 Posts: 10 Location: San Diego
Posted: Sun Nov 19, 2017 6:39 pm Post subject: exhaust smoke after shut down |
So I recently noticed after shutting the Thing's ignition off, the left side exhaust pipe let's out exhaust smoke. not a ton but enough to notice. Last time I checked compression (about a month ago) it was even at all cylinders at 100 psi. The dual carbs seem to be running as they should, but I am no carb guru, timing is correct, recent fuel pump change. Thing gets parked on hill nose down. Oil level is good on flat surface. It never did this before.
Any ideas?
TIA
sdthing _________________ '74 VW type 181
1600 cc DP
dual Weber 34 ict carbs
electronic ignition
009 distributor
A/M exhaust
oil filter
cut and twisted beam
owned since 1983
In San Diego since it was new
No accidents
2nd owner
Other VW's I have owned: '74 Super beetle (bought new), '68 Baja (tilt Front, 1835), '64 Variant (factory sunroof), '69 slammed Cal look beetle, '62 slammed beetle (sunroof, built motor)
"Only the real messiah would say he's not the messiah" |
Posted: Mon Nov 20, 2017 9:03 pm Post subject: Re: exhaust smoke after shut down |
The temps are cooling off. How long have you owned and driven your Thing? |
Posted: Thu Nov 23, 2017 2:08 pm Post subject: Re: exhaust smoke after shut down |
I bought Thing in 83 and drove it for years. Then Thing sat for about 15 years, maybe more. Got it roadworthy with used motor and a bunch of work. Been driving it around for a month. Never noticed the exhaust smoke after shut down until now. And I would have noticed something like this.
Thankx
1600 cc DP
electronic ignition
009 distributor
A/M exhaust
oil filter
owned since 1983
No accidents
2nd owner
