scotty timmerman Samba Member
Joined: January 10, 2010 Posts: 1000 Location: gigharbor W.A
sled Samba Member
Posted: Sun Nov 29, 2020 8:05 pm Post subject: Re: 1957 Oval Build |
damn...1602cc's!
are you going to run stock okrasa heads or have them worked over? I have a guy who could work wonders.
what carbs? _________________ drive your split. |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9955 Location: Huntington Beach, CA
Posted: Mon Nov 30, 2020 9:05 am Post subject: Re: 1957 Oval Build |
This is pretty cool stuff! Looking good!
I use DPR for my machining, now. For over 30 years I always used Brothers. My last interaction with them was not good. Plus they are a solid hour drive away. So, I went searching for another VW machine shop. DPR came highly recommended by my old friend employer. Great place! They are closer to me, right at 20 minutes away, so that was an added bonus! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Rome Samba Member
Joined: June 02, 2004 Posts: 9641 Location: Pearl River, NY
Posted: Sun Dec 13, 2020 9:41 pm Post subject: Re: 1957 Oval Build |
Although I've never had my hands on a 36 hp case, your build and modifications are very interesting. Have you placed the 26 mm oil pump into the right case half to see how well the case's oil passage outlet hole lines up with the pump's inlet hole? I can imagine there is a bit of a diameter difference in that the case's hole is smaller than the pump's. You can make a small scribe by straightening out one leg of a paper clip and clipping the end with diagonal cutters so that you have a sharp tip, then run the leg through the pump's inlet hole so that the tip marks the case. If this marking shows that the case hole can be opened a bit, you can use a cone-shaped grinding stone for a hand drill to open up the case's hole to match the scribe marks. "Match porting".
Posted: Sat Jan 09, 2021 1:14 pm Post subject: Re: 1957 Oval Build |
Rome wrote: |
The pump is for a small oil passage case. It is only slightly larger then the case oil passage. _________________ 71 ghia coupe: Build thread http://www.thesamba.com/vw/forum/viewtopic.php?t=511738&highlight=
71 type 3 fastback auto
71 type 3 fastback manual
73 super beetle
57 oval: build thread: https://www.thesamba.com/vw/forum/viewtopic.php?p=8616563#8616563
63 beetle reassembly: http://www.thesamba.com/vw/forum/viewtopic.php?p=7458619#7458619
2332cc engine build: https://www.thesamba.com/vw/forum/viewtopic.php?p=8608429&highlight=#8608429
84 vanagon westfalia wolfsburg edition |
Rome Samba Member
Posted: Sat Jan 09, 2021 7:11 pm Post subject: Re: 1957 Oval Build |
Nice work with the intake port area welding and the porting itself. Cutting guide bosses for dual springs is usually only needed on "1600-based" heads with cams like Engle 120 with near 0.400" or more cam lift. Is there such an aggressive cam made for 36 hp engines?
I did not read back in your thread... will you be using dual-throat carbs on this engine? |
Rome Samba Member
Posted: Sun Jan 10, 2021 6:56 am Post subject: Re: 1957 Oval Build |
Thanks for clarifying about the springs/bosses. I found a photo in the classifieds of an NOS 36 hp head which has the valve spring seat area (and the "bare" guide) exposed; now I see how you modified your head. |
Brendel20 Samba Member
Joined: October 21, 2010 Posts: 300 Location: Troy, IL
Posted: Sun Jan 10, 2021 8:23 am Post subject: Re: 1957 Oval Build |
scotty timmerman wrote: |
Brored the case for the 83mm cylinders then I sandblasted it and went over it with a wire brush. I found a set of original vw pop out 1/4 windows awhile back and I just started to rebuild them. I used oven cleaner to remove the anodizeing. Next I sanded out any deep scratches or pitting. Then I used a buffing wheel to polish. I think I will be clear coating them to protect the finish.
Can you explain your process to sand and polish out the scratches in the glass? Products used? I have some original glass that needs some attention like this. Thanks! |
Volksvr6gti Samba Member
Joined: July 22, 2019 Posts: 298 Location: Jacksonville
Posted: Sun Jan 10, 2021 11:00 am Post subject: Re: 1957 Oval Build |
Brendel20 wrote: |
I believe he was talking about sanding out the scratches and pitting on the aluminum trim around the glass, not the actual glass itself |
Posted: Sun Jan 10, 2021 11:32 am Post subject: Re: 1957 Oval Build |
Volksvr6gti wrote: |
Brendel20 wrote: |
That is correct. I did not polish the glass I was talking about the aluminum frames. I know I’ve seen people post about polishing glass before. Try the search function. I’m sure you will find what you are looking for. _________________ 71 ghia coupe: Build thread http://www.thesamba.com/vw/forum/viewtopic.php?t=511738&highlight=
73 super beetle
EVfun Samba Member
Posted: Sun Jan 10, 2021 12:39 pm Post subject: Re: 1957 Oval Build |
83mm 40hp big bore cylinders. Turned 90 degrees, fins ground down and stud holes milled for clearance. Left: stock 40hp big bore. Middle: modified 40hp big bore. Right: stock 36hp
Time for me to ask a stupid question...
Why turn the cylinders 90 degrees before machining them to fit on a 36 horse engine. Another question, do you have to turn down the tail of the cylinder where it fits into the block? I understand that the 36 horse engine has smaller head stud spacing. _________________
Wildthings wrote: |
EVfun Samba Member
Posted: Sun Jan 10, 2021 2:54 pm Post subject: Re: 1957 Oval Build |
Do you mean the head stud pattern isn't 2 sets of 4 studs in a square pattern? _________________
Wildthings wrote: |
