1957 Oval Build
Page: Previous  1, 2, 3, ... 13, 14, 15  Next
VolkFanJefe
VolkFanJefe is offline
PostPosted: Fri Feb 09, 2018 8:24 pm    Post subject: Re: 1957 oval build Reply with quote
NICE WORK!!!
scotty timmerman
scotty timmerman is offline
PostPosted: Sat Feb 10, 2018 10:00 pm    Post subject: Re: 1957 oval build Reply with quote
Got the front beam pulled off tonight.
71 ghia coupe: Build thread http://www.thesamba.com/vw/forum/viewtopic.php?t=511738&highlight=
71 type 3 fastback auto
71 type 3 fastback manual
73 super beetle
57 oval: build thread: https://www.thesamba.com/vw/forum/viewtopic.php?p=8616563#8616563
63 beetle reassembly: http://www.thesamba.com/vw/forum/viewtopic.php?p=7458619#7458619
2332cc engine build: https://www.thesamba.com/vw/forum/viewtopic.php?p=8608429&highlight=#8608429
84 vanagon westfalia wolfsburg edition
scotty timmerman
PostPosted: Wed Feb 14, 2018 10:24 pm    Post subject: Re: 1957 oval build Reply with quote
Front brake hardware, lug nuts, beam bolts plated and painted.
73 super beetle
scotty timmerman
PostPosted: Sat Feb 17, 2018 9:53 pm    Post subject: Re: 1957 oval build Reply with quote
Steering box cleaned up and painted
73 super beetle
johnshenry Premium Member
johnshenry is offline
PostPosted: Sun Feb 18, 2018 9:31 pm    Post subject: Re: 1957 oval build Reply with quote
Good stuff. I spent 7 years restoring my '57, you might find the details at thebugshop.org interesting. Almost 19 years after finishing that restoration, I still have that car and love driving it. I have put about 1000 mi a year on it. Ovals are great drivers, you will love the day of your first drive!!!!
John Henry
'57 Deluxe
'56 Single Cab
VolkFanJefe
PostPosted: Sun Feb 18, 2018 9:51 pm    Post subject: Re: 1957 oval build Reply with quote
Your parts are coming out nice! Keep at it!
I can't wait to get to this point on my car.
VolkFanJefe
PostPosted: Sun Feb 18, 2018 9:54 pm    Post subject: Re: 1957 oval build Reply with quote
Your '57 came out Soooo nice! Thanks for sharing your website, I'll be looking at more stuff on it for sure!
My '57 was originally Diamond green as well, and I might eventually take it back to that color even though it was turned into a Baja in the 80's.
scotty timmerman
PostPosted: Mon Feb 19, 2018 2:15 pm    Post subject: Re: 1957 oval build Reply with quote
Thanks for the link to your site johnshenry. I'll be sure to check it out.
Got some drop spindles and the king and link brackets cleaned and painted.
73 super beetle
scotty timmerman
PostPosted: Sun Feb 25, 2018 4:54 pm    Post subject: Re: 1957 oval build Reply with quote
Got some pedal assembly parts from Wolfsburg West so I could assemble it. I don't like how the accelerator petal fits loosely and wobbles around. Is this just the way it is or should some spacers be used to get it to fit a little tighter? I'm looking for a used brake pedal rod. Hoping a used one would be a little cheaper then the new ones.
Also cleaned up and painted an original screw terminal starter. I did test it beforehand.
73 super beetle
scotty timmerman
PostPosted: Mon Feb 26, 2018 10:16 pm    Post subject: Re: 1957 oval build Reply with quote
Got the front control arms cleaned up and painted. Also got the pan separated from the body. It looks like it's going to need a napoleons hat and bottom plate. The fuel line is also rusted out.
73 super beetle
scotty timmerman
PostPosted: Wed Feb 28, 2018 10:09 pm    Post subject: Re: 1957 oval build Reply with quote
The only major rust on the chassis is the napoleons hat and bottom plate. Anyone have a bottom plate there not going to use? It looks like only one supplier makes them. Also will have to replace the fuel line down the tunnel because it has rusted off.
73 super beetle
scotty timmerman
PostPosted: Tue Mar 06, 2018 10:28 pm    Post subject: Re: 1957 oval build Reply with quote
Picked up some 1/4 poly armor brake line to use as the fuel line. I unpinched 2 of the 3 hooks that held the line and pulled the old one out. Also cut the ring at the back. Fed the new one threw and bent the front to get it threw the hole. The front hook can be accessed threw the pedal assembly hole to pinch it back down. The second I cut a small hole in the drivers side of the tunnel to pinch the hook. The 3rd hook is pretty much impossible to get to. I think it should be fine without it. Also made a new ring and welded it together.
73 super beetle
scotty timmerman
PostPosted: Sat Mar 10, 2018 10:08 pm    Post subject: Re: 1957 oval build Reply with quote
Installed new king pin bushings and reamed them out. Assembled the spindles with all new pins and bushings. The spindles are cb performance drop spindles.
73 super beetle
scotty timmerman
PostPosted: Thu Mar 15, 2018 6:22 pm    Post subject: Re: 1957 oval build Reply with quote
Been doing some rust repair to the frame head. The napoleons hat I got from cip1 is a terrible stamping. So I only used what I needed. Also I made a plate to fill in the hole on the bottom. I will weld that in after sand blasting.
73 super beetle
scotty timmerman
PostPosted: Sat Mar 31, 2018 3:39 pm    Post subject: Re: 1957 oval build Reply with quote
Picked up a later beam and I narrowed it 2 inches and added adjusters.
73 super beetle
scotty timmerman
PostPosted: Thu Apr 26, 2018 8:57 pm    Post subject: Re: 1957 oval build Reply with quote
Had the front backing plates blasted and noticed there was a lot of rust between the two plates. So I decided to cut them apart.
73 super beetle
scotty timmerman
PostPosted: Wed May 09, 2018 12:22 pm    Post subject: Re: 1957 oval build Reply with quote
The napoleons hat bottom plate was rusted out. The only one available is from finland. So I got a donor piece off of a ball joint bulkhead. It needed some massaging in the middle and ends to get the shape right. Overall I think it came out pretty good.
73 super beetle
scotty timmerman
PostPosted: Tue May 15, 2018 8:59 pm    Post subject: Re: 1957 oval build Reply with quote
Front backing plates and transmission support cleaned up and painted.
73 super beetle
scotty timmerman
PostPosted: Fri May 18, 2018 3:21 pm    Post subject: Re: 1957 oval build Reply with quote
Axle tubes painted
73 super beetle
scotty timmerman
PostPosted: Sun Jun 03, 2018 2:58 pm    Post subject: Re: 1957 oval build Reply with quote
Rear torsion bars, backing plates and steering column.
73 super beetle
Page 2 of 15
