scotty timmerman Samba Member
Joined: January 10, 2010 Posts: 997 Location: gigharbor W.A
sunroof Samba Member
Joined: October 06, 2006 Posts: 1747 Location: Winnipeg
Posted: Wed Jan 13, 2021 9:24 am Post subject: Re: 1957 Oval Build |
I love the idea of counter weighting the crank. With a properly balanced crank, pistons and con rods, a 36er would spin up very nicely. I bet just these simple mods and nothing else would give you another 10% more power, make it last longer and give better fuel economy. I think you would have to do a little first year physics math to calculate how much material to take off the flywheel to keep the reciprocating mass the same with the new counterweights added.
Keep it up, I'll be watching and waiting till dyno day to see what this little mill makes.
Don _________________ Better and better mistakes! |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9880 Location: Huntington Beach, CA
Posted: Sat Mar 27, 2021 10:30 am Post subject: Re: 1957 Oval Build |
Nice! Something I will need to take care of in the next 3 years! Ha ha ha! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
TinCanFab Samba Member
Joined: April 04, 2006 Posts: 2743 Location: Waterford, California
Posted: Tue May 04, 2021 9:22 pm Post subject: Re: 1957 Oval Build |
Rekeyed some reproduction door handles to work with an original key code from the ignition switch. Also did a T handle for the deck lid. that was much easier then the door handles.
First I had to drill the rivet end to remove the pin to disassemble the handle
Next is the hardest part. Removing the roll pin that holds the lock cylinder in. I used a series of small drill bits and picks to extract it.
I Inserted the key that i wanted to use before pulling out the lock cylinder. Then took a file and filed down the brass slats flush with the lock cylinder.
Reinstalled the lock cylinder and put a new roll pin in that I picked up at ace hardware. Then staked the roll pin so it will not come out.
Finally I used a roll pin that I got from ace hardware to assemble the handle. The holes needed to be enlarged so the roll pin slid through. I left one hole in the bezel smaller so the roll pin could grab and not fall out. Then cut the pin flush
It works perfect and now everything uses the same key. _________________ 71 ghia coupe: Build thread http://www.thesamba.com/vw/forum/viewtopic.php?t=511738&highlight=
71 type 3 fastback auto
71 type 3 fastback manual
73 super beetle
57 oval: build thread: https://www.thesamba.com/vw/forum/viewtopic.php?p=8616563#8616563
63 beetle reassembly: http://www.thesamba.com/vw/forum/viewtopic.php?p=7458619#7458619
2332cc engine build: https://www.thesamba.com/vw/forum/viewtopic.php?p=8608429&highlight=#8608429
84 vanagon westfalia wolfsburg edition |
EverettB Administrator
Joined: April 11, 2000 Posts: 69734 Location: Phoenix Metro
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9665 Location: Oregon
Posted: Fri Jun 18, 2021 1:18 pm Post subject: Re: 1957 Oval Build |
EverettB wrote: |
Nice work on the wipers, what paint did you use?
I've heard Wurth Silver is a good match but I haven't tried it. |
EB, do you know the paint code for the Wurth Silver?
If the shade on those wiper arms is a match. I need some better silver than what WW sells for my bumper supports. _________________ I have learned over the years.
Buy Once, Cry Once!
Posted: Fri Jun 18, 2021 1:31 pm Post subject: Re: 1957 Oval Build |
scotty timmerman wrote: |
EverettB wrote: |
I used krylon metallic aluminum (2766). I matched it to the reproduction blades. It is pretty close. The reproduction blades are a little brighter silver. |
Awesome. That is so close to the 67 bumper support color.
I'm gonna get a couple cans from HD.
My supports are rusted through the paint from WW.
Thanks for posting the paint code. _________________ I have learned over the years.
Buy Once, Cry Once!
Posted: Fri Jun 18, 2021 1:46 pm Post subject: Re: 1957 Oval Build |
Looking great Scotty! Keep on, keeping on!!!
I know that all of these tasks you are tackling will soon be my tasks to complete. Thanks, in advance, for the knowledge! _________________ Jimbo
TDCTDI wrote: |
Busstom Samba Member
Joined: November 23, 2014 Posts: 3790 Location: San Jose, CA
Posted: Fri Jun 18, 2021 9:08 pm Post subject: Re: 1957 Oval Build |
Being a non-expert in such things, I am surprised to see that Wolfsburg West didn't attempt to reproduce their part to appear more accurate: the OE arms have asymmetric lobes on the blade clevises, where WW's are symmetrically rounded. Weird
Posted: Sat Jun 19, 2021 11:40 am Post subject: Re: 1957 Oval Build |
What was the pre-paint surface prep on the arms and blade bits?
Edit: I see that you bought new blade holders.
The Krylon 2766 is advertised as an all in one paint. Prime, coat, and finish.
I'm gonna blast my parts and paint them. Unless you have a better idea Scotty.
Buy Once, Cry Once!
Posted: Sat Jun 19, 2021 12:52 pm Post subject: Re: 1957 Oval Build |
Gotcha!
Thank you for the response. _________________ I have learned over the years.
Buy Once, Cry Once!
