scotty timmerman Samba Member
Joined: January 10, 2010 Posts: 997 Location: gigharbor W.A
sunroof Samba Member
Joined: October 06, 2006 Posts: 1747 Location: Winnipeg
Posted: Thu Nov 25, 2021 8:21 am Post subject: Re: 1957 Oval Build |
Is there somewhere a person does a complete high performance build on a 36 Hp? I am very curious about all the upgrades someone could do to make large reliable horsepower out of a 36er.
Don _________________ Better and better mistakes! |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9880 Location: Huntington Beach, CA
Posted: Thu Jan 06, 2022 11:56 pm Post subject: Re: 1957 Oval Build |
That is a NICE exhaust set up! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Rome Samba Member
Joined: June 02, 2004 Posts: 9602 Location: Pearl River, NY
Posted: Fri Jan 07, 2022 6:06 am Post subject: Re: 1957 Oval Build |
Quote: |
Installed the engine. It was a very tight fit. |
That first short sentence probably involves hours of work... Engine looks fantastic! What was your technique to get the engine in with or without the SG OKRASA manifolds? Both off, then install fan shroud in car, 1 side off, shroud loose; or...?
Really impressive fabrication of your exhaust system. It'll be "The Mouse that Roared" (title of a classic movie).
I sent you a pm. |
bwaz Samba Member
Posted: Fri Jan 07, 2022 9:38 am Post subject: Re: 1957 Oval Build |
Getting my 40 horse back in was tough with leaving the heater boxes on... I'd expect almost a short block going in would be the best if anything bigger than a stock 36 going back in |
Posted: Fri Jan 07, 2022 10:05 am Post subject: Re: 1957 Oval Build |
Rome wrote: |
I sent you a pm. |
I left 3/4 manifold on, the shroud bolted in place, the generator/fan off and 1/2 manifold off. I had to tip the engine a little to clear 3/4 manifold. With the generator and fan out I was able to get to that 3rd manifold nut to install 1/2 manifold. But now I have a problem with installing the spark plugs. The socket is to big and does not fit between the manifold and tin on number 1 and 4 and is very tight on 3 and 2. Working on finding a solution for this. _________________ 71 ghia coupe: Build thread http://www.thesamba.com/vw/forum/viewtopic.php?t=511738&highlight=
71 type 3 fastback auto
71 type 3 fastback manual
73 super beetle
57 oval: build thread: https://www.thesamba.com/vw/forum/viewtopic.php?p=8616563#8616563
63 beetle reassembly: http://www.thesamba.com/vw/forum/viewtopic.php?p=7458619#7458619
2332cc engine build: https://www.thesamba.com/vw/forum/viewtopic.php?p=8608429&highlight=#8608429
84 vanagon westfalia wolfsburg edition |
Posted: Thu Feb 17, 2022 9:15 am Post subject: Re: 1957 Oval Build |
WOW!!!!
How does it run? Did it go around the block under its own power?
Video of maiden voyage?
It looks great! Are you adding hub caps or leaving as is? _________________ Jimbo
TDCTDI wrote: |
tehillah1 Samba Member
Joined: August 23, 2009 Posts: 261 Location: Colorado
Posted: Thu Feb 17, 2022 9:33 am Post subject: Re: 1957 Oval Build |
That's a beauty! I love the header. What high quality work all through this build. It's great to have pros like you posting up their work to help us shade tree guys see what's possible and stay motivated. |
mkbug Samba Member
Joined: October 12, 2004 Posts: 145 Location: Northern California
5500 Samba Member
Joined: October 16, 2020 Posts: 112 Location: Cape Cod
Posted: Fri Feb 18, 2022 8:52 pm Post subject: Re: 1957 Oval Build |
Amazing! |
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4391 Location: Stuck in Ohio
Posted: Thu Mar 03, 2022 9:00 am Post subject: Re: 1957 Oval Build |
That’s a nicely detailed Birth Certificate! I especially like the “whiper-motor”! Funny stuff! _________________ Jimbo
TDCTDI wrote: |
5500 Samba Member
Posted: Thu Mar 10, 2022 12:35 pm Post subject: Re: 1957 Oval Build |
Looks great Scotty. Really like the stance. Is your front end narrowed? How much lower is the rear, and how did you determine how much length to add to the arms? |
