Posted: Mon Nov 20, 2017 10:34 am Post subject: Preemptive ECU repair |
I don't really know how many miles are on my 83 1/2 POS, but it is likely very high as the non working odometer read something like 250K miles when I bought it and the vehicle had already trashed its second coat of paint. I have added another 100K to it since. I am thus thinking of preemptively doing some resoldering of joints in the ECU and would also love to raise the decel fuel cutoff speed a bit while I am dinking around in there. We did have a mystery problem with the unit years back, where when on a long trip the engine would slowly drive worse and worse until it almost wouldn't idle and have very little torque down low. The problem would slowly improve with around town use until it would eventually disappear, only to come back on another 1000+ mile trip.
Looking for others thoughts and ideas |
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3796 Location: VA/TN
Posted: Mon Nov 20, 2017 11:43 am Post subject: Re: Preemptive ECU repair |
Why not reflow the solder. Practice on some old circuit boards. You could just add new solder, like I did. If you want to be a pro reflow all joints with flux solder then use a desoldering iron to remove all old solder and flux. Then put some good solder down (I don't know what to recommend here)
I used to sell these things at radioshack back in the day. They are great, I stocked up like 10 tips for this before they went bankrupts
_________________ Brandon
Instagram @joannthevan |
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Mon Nov 20, 2017 12:03 pm Post subject: Re: Preemptive ECU repair |
If it works, don't fix it. Buy a working ECU. Swap them to test. Keep a spare.
Aloha
tp |
ohhorob Samba Member
Joined: September 26, 2013 Posts: 212 Location: Santa Cruz
Posted: Mon Nov 20, 2017 1:06 pm Post subject: Re: Preemptive ECU repair |
Wildthings wrote: |
... would also love to raise the decel fuel cutoff speed a bit while I am dinking around in there. |
What are the possible ways of doing that with Digijet? Is it an analog part of the circuit where you can change component values to alter the cutoff?
I thought it would all be in the digital side of the ECU (programming of the intel processor)?
I took a copy of the program from a Digijet, but I haven't been able to decipher much of the code. One of the things I was hoping to find is a constant value that determines the decel fuel cutoff. _________________ "Gundy" - '85 Westfalia
GoWesty 2300cc, Digijet |
Howesight Samba Member
Joined: July 02, 2008 Posts: 3274 Location: Vancouver, B.C.
Posted: Mon Nov 20, 2017 1:21 pm Post subject: Re: Preemptive ECU repair |
Hey Wildthings:
Regarding re-soldering, I would suggest not doing so.
My "straw poll" suggests that the ECU "cracked Printed Circuit Board" phenomenon is more common on the 2.1 units than the 1.9. Your van's symptoms are also not consistent with the cracked PCB phenomenon.
Regardless, my theory is that if the ECU connector is provided with appropriate strain relief, so that the harness does not place twisting or bending forces on the printed circuit board, then the problem is highly unlikely to arise. Remember that unlike some other newer types of ECU, on the Digijet and Digifant ECU's the harness connector connects directly to the Printed Circuit Board.
So, the solution to this problem is prevention and is rather low-tech - - adjust the harness position and wiring position to eliminate bending and twisting forces at the connector. If at all possible, make the radius of the wiring bundle as large as possible. You can pull a bit more of the wire bundle into the under-seat area through the grommet to do this. _________________ '86 Syncro Westy SVX |
Posted: Mon Nov 20, 2017 5:40 pm Post subject: Re: Preemptive ECU repair |
Howesight wrote: |
You can pull a bit more of the wire bundle into the under-seat area through the grommet to do this. |
Do some Digijets live under the seat? Mine is '85 and it's in the engine compartment on the drivers side. _________________ "Gundy" - '85 Westfalia
Posted: Mon Nov 20, 2017 6:40 pm Post subject: Re: Preemptive ECU repair |
Howesight wrote: |
Hey Wildthings:
So, the solution to this problem is prevention and is rather low-tech - - adjust the harness position and wiring position to eliminate bending and twisting forces at the connector. If at all possible, make the radius of the wiring bundle as large as possible. You can pull a bit more of the wire bundle into the under-seat area through the grommet to do this. |
Thanks for the straw pole results, I will certainly keep that in mind. So the Digijet actually uses digital logic? I had kind of assumed it was all analog. Doesn't sound like there is any user friendly way to change the decel cutoff speed then.
Don't really have a clue as to what causes the strange symptoms my van experiences, but in general the problem isn't that hard to live with as the van only exceeds a thousand miles per trip once every year or two and almost never exceeds 2000 miles per trip when the symptoms are really becoming a PITA. Have thought about just swapping in a Digifant system to get rid of the odd problem, maybe some day. |
