/New-to-Me Engine, what's missing
KentPS Premium Member
KentPS is offline
PostPosted: Tue Jan 09, 2018 6:40 am    Post subject: Re: /New-to-Me Engine, what's missing Reply with quote
While you have the top accessible, remove the triple ground connection (where the three white wires attach) and clean all those points shiny and clean. That is a PITA to get to when needed, and rarely remembered since its buried.
-Kent-
1976 Riviera, my 1.8l FI chrome yellow VAN - "Chloe"
My top favorite Samba quote:
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. Its.... like driving a celebration!" -WildIdea
Wildthings
Wildthings is offline
PostPosted: Tue Jan 09, 2018 8:00 am    Post subject: Re: /New-to-Me Engine, what's missing Reply with quote
At the stage the OP is at, he could easily relocate the grounding point to somewhere with better access. I have seen a bolt brazed to the top of the #4 intake runner for this purpose.
Goach2
Goach2 is online now
PostPosted: Tue Jan 09, 2018 11:00 am    Post subject: Re: /New-to-Me Engine, what's missing Reply with quote
Ok, at the very least, these connections will be cleaned well. Any products I can put on them that will keep conductivity but hold off rust?
1977 FI Westfalia
KentPS is offline
PostPosted: Tue Jan 09, 2018 11:17 am    Post subject: Re: /New-to-Me Engine, what's missing Reply with quote
Dielectric grease available at all auto parts stores. Some manufacturers call it bulb grease.
-Kent-
Wildthings
PostPosted: Tue Jan 09, 2018 11:54 am    Post subject: Re: /New-to-Me Engine, what's missing Reply with quote
Some people have a fit because of the name "dielectric" grease believing that it will keep the electrical contacts from passing electricity. It is designed to prevent oxidation and to stay on the contacts at high temperature and is sold for the purpose of coating electrical contacts and promoting the flow of electricity. I have been using it for decades at this point in time on light bulb bases and all sorts of automotive connects and have never had it prevent the flow of electricity.
Goach2
PostPosted: Fri Jan 12, 2018 6:44 am    Post subject: Re: /New-to-Me Engine, what's missing Reply with quote
Doing some house cleaning while I wait for my GS order. Going back to an earlier post, can anyone identify the tan wire that is bundled with the oil pressure and booster fan wire?
1977 FI Westfalia
Wildthings
PostPosted: Fri Jan 12, 2018 6:52 am    Post subject: Re: /New-to-Me Engine, what's missing Reply with quote
Brown/tan is the color VW uses for ground wires. A white wire can also end up looking tan with age.
Goach2
PostPosted: Fri Jan 12, 2018 7:23 am    Post subject: Re: /New-to-Me Engine, what's missing Reply with quote
I can try cutting the sleeve back a bit to get a better idea of it's colour, but does anyone else have these three wires bundled in this way?
1977 FI Westfalia
Goach2
PostPosted: Fri Jan 12, 2018 9:08 am    Post subject: Re: /New-to-Me Engine, what's missing Reply with quote
Just thinking it through and one thing I noticed is that my 'triple-connection' ground on the case only has two wires. Chances of this wire needing to ground there as well?
1977 FI Westfalia
Randy in Maine
Randy in Maine is offline
PostPosted: Fri Jan 12, 2018 9:30 am    Post subject: Re: /New-to-Me Engine, what's missing Reply with quote
No. The three light brown "ground" wires are attached to 2 of the 3 possible connections at the ground block.
Looks sort of like this from the gallery. On mine I used my wire wheel to polish both the crimp connection and the copper connector until they shine.
Goach2
PostPosted: Fri Jan 12, 2018 11:05 am    Post subject: Re: /New-to-Me Engine, what's missing Reply with quote
Argh, too bad. I thought I had that one solved...
1977 FI Westfalia
Wildthings
PostPosted: Fri Jan 12, 2018 11:38 am    Post subject: Re: /New-to-Me Engine, what's missing Reply with quote
Spray the wires with WD40 and wipe them down.
Goach2
PostPosted: Sat Jan 13, 2018 8:46 pm    Post subject: Re: /New-to-Me Engine, what's missing Reply with quote
Ok, White with Green stripe is what it actually is....
1977 FI Westfalia
Abscate Premium Member
Abscate is offline
PostPosted: Sat Jan 13, 2018 8:59 pm    Post subject: Re: /New-to-Me Engine, what's missing Reply with quote
Great!! Now you can look on the wiring diagram for the WG wire to identify it.
Give a man a fish tape and he can pull a wire, teach a man to read a wiring diagram and can find a school of fishing wire
.ssS!
Goach2
PostPosted: Sat Jan 13, 2018 9:30 pm    Post subject: Re: /New-to-Me Engine, what's missing Reply with quote
Ya, it seems to go to the same side of the coil as the distributor wire. Other end goes to one of those big red dots.....
1977 FI Westfalia
Abscate is offline
PostPosted: Sun Jan 14, 2018 3:40 am    Post subject: Re: /New-to-Me Engine, what's missing Reply with quote
Is there a number on the red dot? That will help you trace it.
It might be part of the diagnostic plug which is a huge connector that VW would plug in tester for service.
.ssS!
Goach2
PostPosted: Sun Jan 14, 2018 7:37 am    Post subject: Re: /New-to-Me Engine, what's missing Reply with quote
Looks like it has a number, just an't make out the number. I'm not too worried about this then, I know it goes to the coil now and if the other end is the diagnostic port, then I'm good with that.
1977 FI Westfalia
lil-jinx
lil-jinx is offline
PostPosted: Sun Jan 14, 2018 8:21 pm    Post subject: Re: /New-to-Me Engine, what's missing Reply with quote
Doing wiring? read this
https://www.thesamba.com/vw/forum/viewtopic.php?p=8241067#8241067
1968 Dune Buggy
1974 parts bus
Goach2
PostPosted: Mon Jan 15, 2018 8:58 am    Post subject: Re: /New-to-Me Engine, what's missing Reply with quote
Thanks lil-jinx. I do have that diagram, but it's correct for my year. I just didn't know the purpose of the 'big red dots'. I would suppose that these wires are no longer required, if no technician will be plugging them in?
1977 FI Westfalia
Abscate is offline
PostPosted: Mon Jan 15, 2018 9:22 am    Post subject: Re: /New-to-Me Engine, what's missing Reply with quote
Down in the right hand lower corner the dots are explained
Your green/White goes to diagnostic plug connector pin 13 per the orange dot.
Print that sucker out, laminate it, and keep in car
.ssS!
Page 5 of 9
