The Volkswagen Ranch Samba Member
Joined: November 24, 2002 Posts: 704 Location: Arizona
Posted: Fri Apr 02, 2021 8:04 am Post subject: Shifter bushing replacements ? |
Here are the old ones.
These are the new replacements from WW
This is as “ tight “ as I can get them, they are pinned in the holes , the front bushing has the metal ring inserted. However , take a look at the “ gap” where they go together. Is this acceptable ? Your opinions and experience GREATLY appreciated. This project has taken on a life of its own, and I really don’t want to do it twice! I will lube the tube and the bushings with Superlube, and found the older post from Amskeptic on using compressed air to blow a glob of lube in each end of the ( VERY CLEAN) tube to lubricate. Thank you, Bob
_________________ 1963 Convertible (Lizzie) and 1964 Convertible (Patience) 1976 Westfalia (Winnie) |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Fri Apr 02, 2021 4:37 pm Post subject: Re: Shifter bushing replacements ? |
I’ve found that the tits on the new bushings sometimes need to be filed in order to mate well with the holes in the rod. Then I squeeze them in with a pair of channel lock pliers. It’s the best we have with available parts _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
busdaddy Samba Member
Posted: Fri Apr 02, 2021 7:12 pm Post subject: Re: Shifter bushing replacements ? |
I wouldn't worry about the gap, as long as the tittie is fully in the hole and the bushing is tight to the tube it'll do it's job. "One size fits most". _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Apr 02, 2021 9:13 pm Post subject: Re: Shifter bushing replacements ? |
Aeromech and Busdaddy, I sincerely thank you both for your replies. The bushings ( after a bit of careful coaxing) did finally snap in pretty flush with the curvature of the rod. I will try a little more “ persuasion “ with some padded channel locks tomorrow morning. I will use the Superlube with compressed air to push the lube into the bushings and hopefully coat enough of the tube to make them slide. This has been an amazing journey. Could not do it without all of the combined knowledge and experience of guys like you! Thanks. Now I can sleep tonight ! Tomorrow the shaft goes in, and just maybe the transmission might get bolted back in too. Fingers crossed! Bob _________________ 1963 Convertible (Lizzie) and 1964 Convertible (Patience) 1976 Westfalia (Winnie) |
germansupplyscott Samba Member
Posted: Sat Apr 03, 2021 5:37 am Post subject: Re: Shifter bushing replacements ? |
The WW bushings are good. It's hard to tell from the photo but the one with the ring inside looks like it might be different from ones I am used to. That ring-middle one has never been reproduced well. The moulding is poor and there is tons of flash around the nubs that locate into the rod, the flash has to be removed carefully before installing the bushing. The one without the ring made by WW got a lot better several years ago when it seems like they made a new mould and started using better (harder) plastic. The WW ones can be identified by the slightly amberish plastic, the crappy bushings are milky white.
I'd be a touch worried about the paint on the shift rod. There is no paint on the rod from the factory and this is going to upset the dimension of the rod slightly. Seems trivial but might not be, tolerances matter. _________________ SL |
Posted: Sat Apr 03, 2021 7:03 am Post subject: Re: Shifter bushing replacements ? |
Don’t know if would make a difference . The WW bushings are well made ( in my opinion) the molding is sharp , no flash whatsoever. So, now do I remove the bushings and remove the paint below where they mount? I will hold until we have a consensus on this. Once the rod is in, pretty sure would break bushings to take it out. Scott, important point, was in the back of my mind , but saw that Aeromech had painted a set. I will PM plywood kid and see how his worked out, as he just did. Bob _________________ 1963 Convertible (Lizzie) and 1964 Convertible (Patience) 1976 Westfalia (Winnie) |
Posted: Sun Apr 04, 2021 9:14 am Post subject: Re: Shifter bushing replacements ? |
So.... I’ve decided to just remove the paint under the bushings. That way back to original “specs”. Area will be protected with Superlube anyway.
Wishing you all a Happy and safe Easter Holiday . Bob _________________ 1963 Convertible (Lizzie) and 1964 Convertible (Patience) 1976 Westfalia (Winnie) |
Posted: Mon Apr 05, 2021 8:31 pm Post subject: Re: Shifter bushing replacements ? |
Well, wish me luck. Tomorrow the rods go back in , and the transmission gets bolted back in. Hard to believe how long this has taken, but cold weather really slowed things down. Also many, many “ well, why we’re here might as well” collateral damage repairs were done. _________________ 1963 Convertible (Lizzie) and 1964 Convertible (Patience) 1976 Westfalia (Winnie) |
Posted: Mon Apr 05, 2021 9:20 pm Post subject: Re: Shifter bushing replacements ? |
